Old 06-30-2015, 04:42 PM   #2161
Trader Rating: 27 (100%+)
Product looks great Rick.
Ryan George
Forum Administrator of www.LocalRCRacing.com
Central California's premiere source for Radio Controlled Racing!
rgirocz28 is offline   Reply With Quote
Old 07-01-2015, 12:00 PM   #2162
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Steve Weiss View Post
Looks very nice!
Thanks Steve, How'd your day end up last Sunday? I saw you had some tough runs.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 07-01-2015, 01:21 PM   #2163
The Evicerator
Saturday was a bit of a rough day for sure, but I bounced back to qualify and finish 2nd.
Got the car working pretty well, and happy to continue to move forward with the car!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 07-01-2015, 06:09 PM   #2164
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Something new to replace the stock floating servo mount top plate.
Much stronger, 3mm thick carbon fiber mounting plate designed with additional strength and rigidity. Shortened crank posts to decouple the steering assembly from the chassis that minimizes steering input due to chassis flex. Directly replaces the stock components with no modifications.
Please PM me for more info.
Got to check this out in person last weekend and this is definitely a durable/ridgid looking piece!
Old 07-01-2015, 06:55 PM   #2165
YoDog's Avatar
Thanks for the nod, Randy.
Just to be clear... I'm just sharing my ideas with my fellow AE enthusiasts and not using this thread to advertise a product. That would be against the forum rules and I wish to treat this venue with the utmost respect. However, if anyone would like to learn more about the specificity of the items I have designed or share some insight with me directly, please feel free to PM me anytime. I'm always eager to talk about innovative solutions to problems we can all benefit from.
Old 07-04-2015, 11:38 AM   #2166
So, I bought the RSD light weight suspension, is there a base setup for carpet out there? I'm looking for shock to arm position or all suggestions if anyone can chime in.
daveb is offline   Reply With Quote
Old 07-13-2015, 12:06 PM   #2167
Castradamus's Avatar
Trader Rating: 53 (100%+)
I started from the outer most hole testing. Got comfortable with position 'C' and it seemed to give me consistent traction. I ran a modified version of a setup that Christian posted on the RSD thread. Here is mine:
Front:
Piston 3x1.15
Oil 32.5wt
Shock position OOXO OXOO
Arms: RSD "c" position
Suspension mounts:
FF: ( ..)(.. )
FR: ( ...)(... )
0.5mm under all suspension mounts
Spool
Yokomo Blue
Short camber link. 0 outside 2 mm inside
WB 1mm short from std.
Rear:
Piston 3x1.15
Oil 32.5wt
Shock position OXOO OOXO
Suspension mounts:
FR: ( . )( . )
FR: ( . )( . )
0.5mm under all mounts.
Yokomo Black
1000cst rear diff
Short links 2mm inside 1mm outside
Click Here for original
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 07-13-2015, 03:34 PM   #2168
protc3's Avatar
I got to run my car for the 2nd time yesterday. I went 17.5 as the track is pretty small but It worked really well. This was my 1st pack. I needed to get my gearing set.
https://m.youtube.com/watch?v=5d_DsO...ature=youtu.be
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-13-2015, 07:33 PM   #2169
DARKSIDE's Avatar
looks pretty good...look like it was a little loose in the rear at times.
Also it seem to be a little flat on the back straight.
What esc/motor/fdr are you running?
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 07-13-2015, 09:01 PM   #2170
protc3's Avatar
Yeah, It was brand new carpet. It was a tad loose but bite picked up as the day went on. I was running a D4 short stack motor. It was flat. I was having a problem with heat as it was 95 degrees in the building and absolutely no breeze. I wound up running 100/48 with 48 degrees of timing and got the motor temp to 190. Im putting a fan on the motor next time out. It was only my 2nd time out with the car and my 2nd pack on this layout so im still finding its sweet spot for set up but overall, It was really good. Especially once we got a little traction in the track.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-16-2015, 01:21 PM   #2171
DesertRat's Avatar
I have a question for the Associated TC6 faithful; should I get a 6.2 over its competitors, and is there going to be a special edition or a 6.3 in the near future that would make me hold off on getting a new car for a while?
For background, I had an original TC6, and it was garbage to me, inferior in every way to my ancient Losi... BUT, most of the problems were in the steering and suspension arm mounts, which have been fixed in the new car so it makes me give it a second look. I have also seen and appreciated the work done on the HPI Pro 5 concept car, the Mi5, and others, so I am really entirely on the fence and don't know what to do, except that I think I need a new touring car.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 07-16-2015, 01:28 PM   #2172
wtcc's Avatar
If you want to race competetivly I would suggest to wait for the 6.3/7 or to go for a T4'15.
The car out of the box is ok but lacks the final speed and consistency.
The 6.3 or 7 should be out between november and january if AE stays in its usual rhythm.
wtcc is offline   Reply With Quote
Old 07-16-2015, 01:50 PM   #2173
Hey, I have been car testing a few different brands and had a opurtunity to pick a 6.2 up for a good price. I can tell you I am quite surprised how well the car runs, even without the DJC. The car is as competitive as any of the others out there. The only mods I did to the car are the ones Chris Granger posted with the flipped steering assembly and the seperate steering from the servo mount. Im on carpet and run the Yokomo springs, just tightening the lower coil to the lower spring support. The car is one of the easier ones to drive that I have, not necessarily the single fastest lap car of the bunch I have, but its so close and a lot more consistant. (I know you from the MHIC races and IIC)
Rodney Racer is offline   Reply With Quote
Old 07-16-2015, 04:54 PM   #2174
Default Shimming the RSD Arms
I have the RSD arms, I am shimming +3 on to the original spacers, so that makes 4mm front, 5mm rear of the arms.
I may be going crazy but the right side is going to take an additional shim of some sort; I put a king pin shim but there was still a tiny play on that arm. The other arm is fine.
Has anyone seen this inconsistency? It kinda unerves me that one arm spacing to make the rsd arms work is a fraction of a millimeter (it might take 2 shims)
Maybe something is worn out, any thoughts?
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 07-16-2015, 05:44 PM   #2175
YoDog's Avatar
Double check to make sure the pivot block inserts are fully pressed in. they can be a little tight sometimes.
