Old 06-18-2015, 07:58 AM   #2146
Castradamus's Avatar
Trader Rating: 53 (100%+)
Originally Posted by wtcc View Post
Don't mix up the TC5/6 parts with the TC6.1.
Thanks good point.
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 06-18-2015, 07:08 PM   #2147
bertottius's Avatar
Trader Rating: 19 (100%+)
I'm trying to find 3 x 6 x 2.5mm shims to fit the TC4 rear arms on my 6.2. Anyone know who has them and what part # they are?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 06-18-2015, 07:18 PM   #2148
bertottius's Avatar
double post
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
Old 06-18-2015, 07:25 PM   #2149
I bought a ton of the yeah racing dark blue shims, I got 3mm, 2.5mm and 2mm
I got them from rc mushroom as I couldn't get them in New Zealand
ed
Edwin Pibal is offline   Reply With Quote
Old 06-19-2015, 08:30 AM   #2150
I use these and they sell each size individually:
Aluminum M3 Flat Washer 0.25 / 0.5 / 1 / 1.5 / 2 / 2.5 / 3mm 10pcs Set Light Blue (Yeah Racing YA-0390LB)
http://www.tqrcracing.com/shop/produ...asp?p_id=10069
Old 06-19-2015, 10:45 AM   #2151
bertottius's Avatar
Thanks!!
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
Old 06-22-2015, 12:47 PM   #2152
Sorry for the stupid question here; pretty sure I have it right though.
I have the RSD c-hubs preset at 4deg. I almost missed it but one is designated left and the other right; so which left is it? If you were sitting in the car the left C-hub would be your left; conversely the right c-hub is your right; again if you were sitting int the car most likely looking at an x-ray in the rear view mirror. That's the way I have it right now.
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 06-22-2015, 01:10 PM   #2153
scoyle's Avatar
You have it correct... Left and right as seen from the driving seat or with the rear of the car pointing towards you.
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 06-23-2015, 07:36 PM   #2154
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
So what are the gains of the of using the tc4\5 parts on a 6.2. I ask this because I'm seeing how this setup would help in 17.5
racer034life is offline   Reply With Quote
Old 06-23-2015, 10:39 PM   #2155
wtcc's Avatar
Check some pages ago. I made the conversion with the help of Randy and wrote down my experience.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 06-24-2015, 09:42 AM   #2156
Trader Rating: 18 (100%+)
What's a good starting setup for a very tight indoor carpet track? 9 second laps for USGT...
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 06-27-2015, 07:09 PM   #2157
dirt42fan's Avatar
Trader Rating: 135 (100%+)
New to on road. Question, and sorry if its already been covered.
Where are racers putting weight in the cars to meet minimum weight and are you achieving 50/50 front/rear and crossweights?
When I weigh my car I am still short on the RF and LR and it has about 54/46 crossweight
Could you post pics of where you had to put weight at?
Thanks in advance!
"Never apologize for hard racing" Scott Bloomquist
dirt42fan is offline   Reply With Quote
Old 06-28-2015, 01:05 PM   #2158
wtcc's Avatar
It is not easy to tell where to place the weight as it depends on the electronics and battery you use.
I run a 7000mAh Reedy lipo (connectors in front) with LRP Flow, Sav÷x low profile, Sanwa receiver and X20 17.5t.
My car is now perfectly balanced. I used corner weight scales without springs on the car to make sure the overall car is straight and then with electronics I needed to add around 27gr. between motor and esc.
Old 06-30-2015, 03:51 PM   #2159
YoDog's Avatar
Trader Rating: 26 (100%+)
Something new to replace the stock floating servo mount top plate.
Much stronger, 3mm thick carbon fiber mounting plate designed with additional strength and rigidity. Shortened crank posts to decouple the steering assembly from the chassis that minimizes steering input due to chassis flex. Directly replaces the stock components with no modifications.
Please PM me for more info.
Team Associated TC6.2 Touring Car-img_20150625_081649-800x600-.jpg   Team Associated TC6.2 Touring Car-img_20150625_082030-800x600-.jpg   Team Associated TC6.2 Touring Car-img_20150513_202510-800x600-.jpg
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 06-30-2015, 04:18 PM   #2160
The Evicerator
Looks very nice!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
