Old 05-29-2015, 05:22 PM   #2101
Do the front spools fit the rear?(as a replacement for the gear differential)
cbs007 is offline   Reply With Quote
Old 05-30-2015, 06:55 AM   #2102
wtcc's Avatar
They do.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 05-30-2015, 07:13 AM   #2103
wtcc's Avatar
Just want to give a feedback to the before shown conversion:
The weather in southern Germany was cold and cloudy, but allowed about 4-5 runs before the rain soaked the track.
After one initial run with my T4'15, I changed to the 6.2. It was a different experience to what the 6.2 was before! The rear is planted, even in fast direction changes, but follows the front nice. If it starts to get loose then in a soft and easy to control manner.
The front is better in corner entry and much better in the middle.
11.79s was my best lap so far this year in warmer, higher grip conditions. Today I drove a best lap of 11.6s and was consistent in the 11.7-11.8s range for the whole run. The conversion gave me an easy, consistent and fast car!
Let me say thank you to Randy and Sean for helping me to realize the conversion in every detail
Old 05-30-2015, 08:07 AM   #2104
bertottius's Avatar
Trader Rating: 19 (100%+)
Do you or any of the team guys know if this setup works on carpet or is it strictly for asphalt? Also, is there any way you could give a parts breakdown as to what was used? I know TC4 rear arms and Yokomo sway bars...
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 05-30-2015, 08:16 AM   #2105
When is an update coming for the kit so everyone can do upgrades?
Surrey is offline   Reply With Quote
Old 05-30-2015, 10:23 AM   #2106
wtcc's Avatar
This suspension parts will work on carpet too. Of course you will have to adjust droop, camber, diff oil, or whatever for the specific track.
I used:
TC4 rear arms graphite
TC5 front arm hard
TC5 4* C-hub hard
TC5 inner sway bar mounts 1 dot x4
Yokomo BD7 rear hub
Yokomo BD7 rear swaybbar set
and
a lot of 3x6mm shims (you need 12 3x6x2.5mm for the shimming of the rear arms)
That is all.
Old 05-30-2015, 06:21 PM   #2107
bertottius's Avatar
I used:
TC5 front arm hard
TC5 4* C-hub hard
Yokomo BD7 rear hub
and
That is all.
Thanks for the advice!
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
Old 05-31-2015, 06:36 AM   #2108
WTCC please post setup
Old 05-31-2015, 11:22 PM   #2109
Default TC6. 2,5
I have using this modification since one year, and the improvement is huge ....
(TC5 arms in the front, Spec R arms in the rear, and yokomo bars)
I don't know if it is the size, the rigidity or the weight that is making the different but it is realy better
Fred
fredB is offline   Reply With Quote
Old 06-01-2015, 12:32 AM   #2110
wtcc's Avatar
This is my actual setup:
The servo mount brace setup is different from Randy Caster and Ryan Cavalieri. They use a floating steering.
Old 06-01-2015, 11:44 AM   #2111
Send a message via Yahoo to nomaak
Default back in time
Why is AE going backwards 10 years or so to make "today's" car perform? If they really want to go retro with their tc....why not revamp the tc4's drivetrain with a lower internal ratio and sealed gear diffs! The definitely have the car to do battle with that other "A" car so why not freshen it up? (Hey Bob, you listening? Lol..this Pete from florida aka the guy in the green shirt). Heehee
nomaak is offline   Reply With Quote
Old 06-01-2015, 03:14 PM   #2112
Send a message via ICQ to MattW
It's not a case of "going backwards" It's about testing to go forwards. If you want to test a wishbone that is different length to your standard one, and you already have one that happens to be the length that you want to test, then surely that's the one that you're going to test?? The TC4 rear arm is shorter than the stock 6.2 and the TC5 front arm is longer than the stock 6.2.
MattW is offline   Reply With Quote
Old 06-01-2015, 03:18 PM   #2113
@Randy: If you stop by, feel free to check for mistakes or strange settings. Thanks!
Edit: Just found one myself... Rear inner armmount insert should be -3dot (not +3dot).
thats a nice setup sheet ! did you make it or is there a new AE one ?
Ed
Edwin Pibal is offline   Reply With Quote
Old 06-02-2015, 12:05 AM   #2114
wtcc's Avatar
No, it was Arn0 (Arnaud) from petitRC idea to arrange it new to make it overall more clear to read.
Old 06-02-2015, 02:54 PM   #2115
its soo much easier to follow!
thanks for the info
