Old 05-26-2015, 09:34 AM   #2071
Originally Posted by S_fender View Post
Which app ?
Was team associated R.C. Cheat Sheet app
tbamsey is offline   Reply With Quote
Old 05-26-2015, 09:43 AM   #2072
NutDriver's Avatar
Trader Rating: 15 (100%+)
Christian,
Will replacement arms be available seperately? I have your kit, but don't want to have to replace the whole thing if I break an arm.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 05-26-2015, 09:45 AM   #2073
Originally Posted by NutDriver View Post
Christian,
Just contact RSD directly; they have arms sold seperately.
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 05-26-2015, 01:31 PM   #2074
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by irvinew View Post
How is arm sweep different than toe? If I want .5 deg toe out, is it better to make sure everything is straight (ie steering arm linkages confirmed by the hudy setup board) and then simply put a 2 dot in the FF, 1 dot FR?
Typically to induce Toe on the rear, you will use arm sweep to add or subtract Toe angle rather than change hub angle but in the front you use the steering turnbuckles to induce toe change since the hubs are pivot-able. Arm sweep in front just changes the dynamics of the lower arm movement and I don't know of anyone trying what you have suggested.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 05-26-2015, 07:15 PM   #2075
3srcracing's Avatar
Trader Rating: 25 (100%+)
I have the Tc6.1 but was just wondering what is a good motor fan to run in 17.5? Indoor carpet... Also good starting point for 17.5?
(off A Main)
Think I'm 43/100, w/ 37.5 wt oil all the way around.
3srcracing is offline   Reply With Quote
Old 05-26-2015, 08:04 PM   #2076
azeroth's Avatar
Trader Rating: 20 (100%+)
(off A Main)
46-48/95-96
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 05-26-2015, 10:59 PM   #2077
Hey dude I see u a regular here do you think the arms, springs fo
Shock tower from tc6.2 fix on the apex touring sedan I want to put the tc6.2 suspension on my apex touring sedan
munger is offline   Reply With Quote
Old 05-27-2015, 12:05 PM   #2078
Any chance to have one top guy setup at the reedy race ?
Thank a lot
Fred
fredB is offline   Reply With Quote
Old 05-27-2015, 12:56 PM   #2079
wtcc's Avatar
Randy, Rick and Keven we need you now!
And please be honest and include all the hardware changes you made.
I have a hard time to competetivly drive this car outdoor. The rear is just not planted and the front end not as strong as it should be! In comparison my Xray T4'15 is, after one day of training, as fast as my 6.2 after 6 months (but much much easier to drive). I ordered all Yokomo, TC5 and TC4 parts I recognized from the pictures of your cars to finally make this car fast and comfortable to drive.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 05-27-2015, 01:14 PM   #2080
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Christian,
buy replacement arms from Spec-R they are making the arms anyhow....
http://www.spec-r.com/default/index....roducts_id=658
C-hubs....
http://www.spec-r.com/default/index....roducts_id=660
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 05-27-2015, 02:12 PM   #2081
how is this fan mounted exactly?
it looks like only two screws... but angled?
could i see a side shot of this car?
thank you
Originally Posted by Randy Caster View Post
Well this Thursday starts my favorite race of the year, the Reedy TC Race of Champions! Got a brand new car built up for the race and have high hopes for an excellent weekend. Check out the action on LiveRC if you aren't local, it's one of those few races of the year that spectating is almost as good as racing.
macscac is offline   Reply With Quote
Old 05-27-2015, 02:16 PM   #2082
Id upgrade the shocks through reflex racing, springs, bladders and pistons.
For this car; not sure what else but tires (perhaps sorex 28's) and shocks are the biggies.
Old 05-27-2015, 03:09 PM   #2083
NutDriver's Avatar
Thanks, KevinK!
USVTA member #111
Old 05-27-2015, 04:29 PM   #2084
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'll be as honest as I can be for you, but can't really speak for things that haven't already been shown in pictures or answered in other interviews.
First off, measure your rear toe and make sure it is where it should be, I recommend using the same inserts on the rearward pivot block, but you may have to use different inserts, or shift the front pivot blocks around before tightening them to get the desired toe. Start with 3*. I like running the rear pivot blocks shimmed up .5mm and the front pivot blocks low. I prefer the car to have a lot of entry steering, at Reedy I ended up with 1mm anti-dive on my car and Cavalieri's car. Rick used my setup on one of his cars but I'm not sure if he was running .5 or 1mm of anti-dive. Some of the guys liked the front arms flat. This is a pretty big change and you basically just have to try different settings and see which feeling you like best.
Front arms use the inner hole with 2mm spacing in front of the arm, rear arms use the outer hole with 5mm spacing in front of the arm. Yokomo hubs will be the inner hole and just center those, 1.25mm on either side should do it, file the hub a hair if it's bound up.
My shock setup is AE 42.5wt oil, Yokomo 3x1.1 (drilled) pistons, AE X-Rings, HPI Silver springs (try the new HPI Green springs for lower grip tracks and drop the oil a bit until it feels right on the track) build the shocks with about 3-4mm of rebound and drill a 1mm hole to vent the shock caps. I have tried a few different bladders and keep going back to the stock bladders, they feel the best on every surface so far for me. I use Yokomo shock collars, shock bottoms and spring retainers, these fit the HPI springs better than the stock pieces. Some of the guys are using AE TC5 shock ends with the Yokomo or HPI retainers. I like running the 3 hole on the front and rear shock towers.
If the rear of your car isn't planted try using 1.5* front camber and 2* rear camber. If it's still not planted take the front camber down to 1*.
For weight bias I like the front of my car to be slightly heavier than the rear, I run 51/49 front to rear bias. Talking to Sean a while back he preferred 50/50. Side to side is close to 50/50 but don't sweat it if it's a little off, you can adjust this with spring preload.
There's some info to get you going, hope this helps!
Old 05-27-2015, 04:30 PM   #2085
thank you
I used the WTF angled fan mount on my and Cavalieri's cars. With the Orion ESC it allows us to upgrade from a 25mm to a 30mm fan and runs much cooler.
