Old 05-22-2015, 11:52 AM   #2056
CristianTabush's Avatar
We at RSD came out with a different suspension geometry package a while back. The geometry on the TC6.2 is not quite right. If it were, the team guys would not be changing the parts over to what they are.
The AE mod is a little more complex as you have to re-drill the rear arms to mount a swaybar mount and I believe also to match hinge pin size. They are also using Yokomo rear hub carriers to match up with the TC4 rear arms.
Our conversion is a little more straight forward and more plug and play. Our geometry (click on the link to the left) mimics the Yokomo's more closely, especially in the front. The results are more predictable handling, better mid corner rotation and more overall bite. Additionally slop is drastically reduced and durability goes way up.
Many people will say "I'm not good enough for it to make a difference". This is not the correct train of though. An easier car to drive will make you a better driver.
The swaybars are changed because they are easier to set up and the feel is more consistent. Due to the threads on the rod holders, the swaybars on the TC6.1/.2 are always cocked to one side. An easy way to mitigate this is to put in one set screw from the top and one from the bottom on the swaybar tube. This makes sure that as the set screw drives into the wire, it spins it in the right direction.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-22-2015, 01:21 PM   #2057
wheelz's Avatar
The TC4 rear and Tc5 front arms are the closest match to a yokomo with using standard Associated parts.
I have the RSD suspension conversion on my sedan and never looked back from the tc4 rear arms. one of the best/easiest changes you can make to improve the consistency of the car.
Aaron
Aaron Lane
Team Associated | Reedy | Jconcepts | Exotek Racing | Airtronics l OCRC l Sticky Kicks l
B6 | B64 | F6 l TC7.1
AE Design Engineer
wheelz is offline   Reply With Quote
Old 05-22-2015, 01:26 PM   #2058
Cosmo's Avatar
Will the conversion work on an original TC6? Or just the TC6.1/.2?
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 05-22-2015, 02:44 PM   #2059
It should work on the original TC6, but it is not ideal because of the suspension mount on the original TC6. With the narrower arms front to rear, the suspension mounts can come loose, but they will work.
Old 05-25-2015, 08:19 AM   #2060
Bubblehead's Avatar
Default Stronger Caster Blocks
I'm still running the box setup with the front spool and I have broken the right front caster block about four times with the minor of hits.
Are the TC5/TC6 caster blocks any stronger?
Bubblehead is offline   Reply With Quote
Old 05-25-2015, 08:23 AM   #2061
patorz31's Avatar
the best option.
Tuning Haus
Scroll down 3rd item down.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 05-25-2015, 09:30 AM   #2062
Default team associated app
I noticed after i updated my team associated app i have for the ipad under car selection has tc 6.3 listed any word on when this updated kit is due to be released
tbamsey is offline   Reply With Quote
Old 05-25-2015, 10:37 AM   #2063
Bubblehead's Avatar
Originally Posted by patorz31 View Post
the best option.
Tuning Haus
Old 05-25-2015, 02:53 PM   #2064
Castradamus's Avatar
Trader Rating: 53 (100%+)
Does anyone know if Mike Haynes and Juho was running that modified geometry on there cars?
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 05-25-2015, 05:43 PM   #2065
Send a message via Yahoo to nomaak
Default reedy setups,tips, modds
Lets have 'em!.. The AE cars looked good at the reedy race. Cant wait to see the team setups and tricks! I still run the tc5(heavily tweaked of course but i aint done) and im thiiiiis close to a newer more current car. Had my eye on three and the 6.2 is looking to be the best car of the bunch.
nomaak is offline   Reply With Quote
Old 05-25-2015, 05:50 PM   #2066
hanulec's Avatar
Trader Rating: 27 (100%+)
dont have the answer to this-- but i know Haynes found 0.5s/lap by the removal of a single screw from his motor mount. hopefully these guys post up the info for everyone.
super hard track. really made some of the best struggle..
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-25-2015, 07:23 PM   #2067
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Mike and Juho were both on the modified suspension geometry you can see on Rick and Ryan's cars on the RedRC chassis focus.
Old 05-25-2015, 10:04 PM   #2068
samnelso's Avatar
Not an asphalt setup, but this has been working really well for me on carpet. My current mod and 17.5 setups are very close.
The TC4 rear arms allow the car to be driven very aggressively without the rear stepping out. There is a bit of work to get them on though. More wheelbase shims are required, a new droop screw hole needs to be drilled in the arms, the arm hinge pins need to be drilled, and some sanding may be required to provide clearance for the hub.
For those that like to play with setup, these arms are definitely worth trying out.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 05-25-2015, 10:38 PM   #2069
S_fender's Avatar
Which app ?
S_fender is offline   Reply With Quote
Old 05-26-2015, 07:56 AM   #2070
How is arm sweep different than toe? If I want .5 deg toe out, is it better to make sure everything is straight (ie steering arm linkages confirmed by the hudy setup board) and then simply put a 2 dot in the FF, 1 dot FR?
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
