Old 04-01-2015, 06:13 PM   #1951
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by fredB View Post
Thank you for your answer.
I know that 971 is just 20,2 mm height, but I found this servo has a lot of play !
Did you feel any influence of this play on your steering precision ?
Fred
I was actually surprised at the amount of slop in the servo, however I honestly don't feel it on the track at all. My car is able to track dead straight on the straightaway lap after lap...
Old 04-01-2015, 08:48 PM   #1952
El Nitro's Avatar
Originally Posted by YoDog View Post
I considered it a typo and built mine according to the TC6.1 manual. They work just fine. The only reason I can see adding both shims to the inside of the diff would be to tighten the gear mesh. If the smaller shim is put outside, I imagine that the shim will eliminate the outdrive contacting the plastic housing as well as supporting the outer O-ring seal. Hopefully Rick will chime in.
turtlehill
The 6.1 build had the small shim outside and the large shim inside. Moving the small shim inside tightens the gear mesh in the diff removing some play between the gears. It is intended to remove slop and make the diff smoother.
Sean Cochran
There have been a few people that stripped diffs with the original shimming so it was adjusted to make it full tight, all shims inside.
My new way is to build the diff with all the shims inside, assemble the diff with no lube then feel it. Normally I will move 1 shim back to the outside but not always. It really is just a feel for how all the gears mesh.
I do think that the old way, 2 out and 2 in, is probably loose but if you run 17.5t most likely it will never hurt the diff.
Thanks Guys,
I have since downloaded the latest Manual from AE.
Its different from my Manual that came with the kit.
It now says use 1 x large and 1 x small shim inside the Diff on each side.
I hadn't heard of diffs stripping. May be happening in Mod.
Thanks for the replies. Ill RE-build both diffs the new way.
Cheers
QRCCRA, QLD Radio Circuit Car Racing Association, England Park Raceway, Brendale, Brisbane North, Australia.
RCORRSC, Radio Control Off Road Racing Sunshine Coast, (Mooloolah Valley), Australia.
El Nitro is offline   Reply With Quote
Old 04-02-2015, 11:26 AM   #1953
AE-Reedy
Originally Posted by El Nitro View Post
Thanks Guys,
Cheers
Maybe stripping is the wrong word but I have had the diffs skip on high grip with mod. So now I have modified how I use the shims in the diff. Diffs seem a touch smoother when the gears are meshed better also.
Sean Cochran is offline   Reply With Quote
Old 04-03-2015, 03:59 AM   #1954
El Nitro's Avatar
Wow, surprised they could 'skip' without stripping.
I've built them the new way.
Cheers.
Old 04-08-2015, 12:01 PM   #1955
BulletMan's Avatar
Thumbs down
super bummed that our carpet season is over... and no asphalt tracks in a 3 hour radius.... bummmmed!
Martin Vannieuwenhuizen
ASSOCIATED 2wd B4.2... BACK TO MY ROOTS
ASSOCIATED TC6.2, REEDY 6500, TEKIN RSX, 17.5 D4
ASSOCIATED RC-12R5.1 (lipo chassis), REEDY 7000, TEKIN RSX, 13.5 D4 1s
"racing since the 80's an XRAY was something you needed when you broke a bone."
BulletMan is offline   Reply With Quote
Old 04-08-2015, 12:10 PM   #1956
Randy:
I have to ask; I think somewhere; though I haven't found it yet; is that you used a yokomo sway bar on your car. Other than the sway bar itself (I assume it is a BD7) any other mods to make that work? Did you find it worked better for you?
Unrelated question to someone else in the AE part shop: (Part 31269 Bar pivot mound) I thought mine was kinda loose; Why don't you sell this little plastic piece on its own? Right now I would have to buy the whole sway bar assembly. I guess if it became totally unworkable I could always use a bigger screw. Has anyone had to fix this?
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 04-09-2015, 10:52 AM   #1957
Donn's Avatar
Originally Posted by irvinew View Post
Randy:
Randy,
We do offer the mounts #31264 they are $3.99 per package.
Donn is offline   Reply With Quote
Old 04-09-2015, 11:04 AM   #1958
jamminjim's Avatar
Hey Martin move here.....lots of racing.
Know racing, know life. No racing, no life.
jamminjim is offline   Reply With Quote
Old 04-10-2015, 09:09 AM   #1959
Originally Posted by Donn View Post
Randy,
Hi Don,
Thanks for the input and sorry for the spelling error; but the attached image shows what I mean. Unless the part you are mentioning are to be used with the more conventional sway bar as seen in the TC6 and TC6.1
Old 04-14-2015, 12:00 PM   #1960
Cosmo's Avatar
Can someone give me a good place to start as far as gearing (64 pitch) for a TC6 running 17.5t? Carpet track, medium length. Non-timing ESC.
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 04-14-2015, 12:33 PM   #1961
4.0-3.8
Team Integy .. Speedtechrc.com .. Gridworksracing .. .. Tq raceway ..Roudrunner raceway
AE6.1wc and 6.2
Awesomatix
johnsonthai is offline   Reply With Quote
Old 04-14-2015, 12:58 PM   #1962
Trader Rating: 41 (100%+)
Originally Posted by johnsonthai View Post
4.0-3.8
markpoleon is offline   Reply With Quote
Old 04-14-2015, 01:07 PM   #1963
Cosmo's Avatar
4.0-3.8
Thanks.
Old 04-16-2015, 12:19 AM   #1964
JasonR/C's Avatar
Who's got a good starting asphalt setup for modified? Big outdoor track long straight
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 04-16-2015, 07:13 AM   #1965
Got to run mine for the first time yesterday. Finally!
Really it's a great car!
Perhaps I got a 'bad batch' of turnbuckle eyelets tho.
I had three of them just completely split in half while practicing.
Not even on hard hits to the boards
Hobby shop only had T5 eyelets so I subbed in a few of those
Their considerably larger than stock
Anyone else have issues like this?
macscac is offline   Reply With Quote
