Old 03-30-2015, 04:05 AM   #1936
SWTour's Avatar
Talk to Don Natale at Associated (customer service) - he'll tell you what he does I'm sure... he did my car, and it's sweet.
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 03-30-2015, 06:43 AM   #1937
DARKSIDE's Avatar
Originally Posted by macscac View Post
anyone using a velcro strap to hold their battery down...
what did you add to hold the straps front and back?
this glass tape is kind of a PITA to use and i don't want to carry the roll of it back and forth to the track
I have been using straps since TC5 days..I never could get the tape to work like others...no idea...but anyway the Hook and Loop kit from AE works flawless. Ive been using it since the release and have not lost a battery not once.
http://www.teamassociated.com/parts/details/31645/
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 03-30-2015, 10:02 AM   #1938
YoDog's Avatar
Trader Rating: 26 (100%+)
If you keep the tape clean, you shouldn't have to replace it so often.
Although it is a pain at times, it's still the best method for securing the battery.
I see batteries falling out of cars all too often when using the velcro straps but that's just my observation.
AE makes straps specifically for the TC6.2 if that's still the direction you want to go. I prefer the tape method as it has an adhesive attachment to the battery rather than just using tension to hold the battery in.
On the other hand, I also use my CF battery stay kit which secures the battery much better than the stock plastic bits.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 03-30-2015, 10:21 AM   #1939
thanks for that link!
macscac is offline   Reply With Quote
Old 03-30-2015, 07:15 PM   #1940
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Tape can actually last longer than you think. If it begins to lose some of it's stickiness just spray a towel with motor spray and wipe it on the adhesive side of the tape. Cleans it off and makes it sticky again. I don't think I've ever ejected a battery while using tape.
Old 03-30-2015, 11:58 PM   #1941
Rick, or Juho, or Keven,
Can you please tell us what servo are you using ?
As the floating servo mount is just 20.5 mm height we can not use all the aitronics / Sanwa range ?
( 21 mm servo height )
Thank you for your help.
Fred
fredB is offline   Reply With Quote
Old 03-31-2015, 12:38 AM   #1942
G-kenny's Avatar
Fred
You can simply shim the mount up, the KO propo servo was a little tight, A 0.5mm shim lifted it up
G-kenny is offline   Reply With Quote
Old 03-31-2015, 02:46 AM   #1943
SWTour's Avatar
I believe when Don put the velcro strap setup in my car, he said he shims up the battery braces which helps keep the battery in the car more securely. I can testify that I crash the heck out of my car at times..and that battery don't move w/ the velcro. (I was happy using the Tape and was able to get many re-uses from it, but the Velcro has been so much nicer/cleaner.)
Joe Myers
Old 03-31-2015, 11:14 AM   #1944
YoDog's Avatar
This is actually a bit more difficult since the steering rack is attached to the servo mount however, if you have cut the servo mount top plate, shimming is easier. It's also better to shim the plate vs the servo mount block. You don't loose as much rigidity.
Old 03-31-2015, 02:46 PM   #1945
For the Sanwa servo question, I'm using the Sanwa ERS-971 with no modification at all.
Old 04-01-2015, 01:09 AM   #1946
El Nitro's Avatar
Why Different Gear Diff Builds TC6.1 VS TC6.2.
Just building a TC6.2. Also built an extra TC6.1 Gear Diff.
They appear to be exactly the same however,
The 6.2 does not use any shims on the outdrives (outside diff), but uses two inside (on the deep half) and one inside (on the cover).
They supply 4 shims (two of each).
Anyone know why they are saying to build them differently to the previous TC6 gear diffs.
EDIT:
I just downloaded the latest manual from the website. It differs from the printed manual that came with my Kit.
It says put one large and one smaller shim on the inside of the diff on each side.
They must be trying to reduce the width of the outdrives by a VERY small margin.
Anyone know why?.
Cheers.
QRCCRA, QLD Radio Circuit Car Racing Association, England Park Raceway, Brendale, Brisbane North, Australia.
RCORRSC, Radio Control Off Road Racing Sunshine Coast, (Mooloolah Valley), Australia.
El Nitro is offline   Reply With Quote
Old 04-01-2015, 04:22 AM   #1947
Thank you for your answer.
I know that 971 is just 20,2 mm height, but I found this servo has a lot of play !
Did you feel any influence of this play on your steering precision ?
Fred
Old 04-01-2015, 10:27 AM   #1948
YoDog's Avatar
EDIT:
Anyone know why?.
Cheers.
I considered it a typo and built mine according to the TC6.1 manual. They work just fine. The only reason I can see adding both shims to the inside of the diff would be to tighten the gear mesh. If the smaller shim is put outside, I imagine that the shim will eliminate the outdrive contacting the plastic housing as well as supporting the outer O-ring seal. Hopefully Rick will chime in.
Old 04-01-2015, 01:42 PM   #1949
turtlehill's Avatar
EDIT:
Anyone know why?.
Cheers.
The 6.1 build had the small shim outside and the large shim inside. Moving the small shim inside tightens the gear mesh in the diff removing some play between the gears. It is intended to remove slop and make the diff smoother.
Team Associated TC 6.1 VTA, TC 6.2 TOURING, TC4 VTA
Tekin RS Gen2 Spec
APEX RC supporter
turtlehill is offline   Reply With Quote
Old 04-01-2015, 04:29 PM   #1950
AE-Reedy
There have been a few people that stripped diffs with the original shimming so it was adjusted to make it full tight, all shims inside.
My new way is to build the diff with all the shims inside, assemble the diff with no lube then feel it. Normally I will move 1 shim back to the outside but not always. It really is just a feel for how all the gears mesh.
I do think that the old way, 2 out and 2 in, is probably loose but if you run 17.5t most likely it will never hurt the diff.
Sean Cochran is offline   Reply With Quote
