Old 03-14-2015, 07:12 PM   #1891
JasonR/C's Avatar
Thanks to those who gave me some pointers to start with! Appreciated
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 03-15-2015, 01:37 AM   #1892
jpx
jpx's Avatar
Originally Posted by macscac View Post
this rear toe looks off....
its two dots on the outside on each side
is that too much?
what are you guys running on concrete? no carpet
Sorry, no ideas what to run on concrete.
But basically I'm running the same inserts on asphalt as on carpet.
Currently I'm fine with:
front of the car
rear of the car
(which is 2.5 toe-in at the rear)
3 in th rear should also be ok - but you might try to narrow the rear (one dot front and rear carriers in the rear)
AE TC7 / 17.5T blinky GT
WRC f-one '016 / 21.5T F1
jpx is offline   Reply With Quote
Old 03-15-2015, 04:22 AM   #1893
ViperZ's Avatar
is that too much?
I'm running on carpet using 1 dot (0 deg) on all for corners, this gives me 3 degrees rear toe. I think you with 2 dot (+1/2 deg) to the outside on all fours would work out to the same as mine, just with a slightly wider stance.
I was just re-setting my car for today's race.
3 degrees toe with 1 dot inserts on inner & outer
Angle of the hinge pins look similar to yours
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 03-15-2015, 09:07 AM   #1894
ok it does.. thanks
what setup kit is that
macscac is offline   Reply With Quote
Old 03-15-2015, 03:35 PM   #1895
ViperZ's Avatar
ok it does.. thanks
It setup station is an Integy TC kit.
The setup board is a Team Powers.
Old 03-18-2015, 07:47 AM   #1896
Originally Posted by azeroth View Post
spares drive cups, and pin cushions for the front spool and c hubs and locktight the steering rack posts
+1 on the posts; almost got burned by that one.
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 03-18-2015, 06:42 PM   #1897
TC5Driven's Avatar
Yep I agree. Two screws fell off during practice laps last weekend. Time to tear it down this week a thread lock all screws on steering linkage. Rookie mistake.
TC5Driven is offline   Reply With Quote
Old 03-18-2015, 08:32 PM   #1898
BulletMan's Avatar
well it took till our last indoor carpet race last Sunday (why did it have to end ) but... I LOVE THIS CAR (4th race day with the 6.2 ... sold my 6.1w.2 that i loved)
I was very frustrated initially... but with some tuning (extra help from Luke,, thank you! ) the car felt so dialed and was fast on our low/med grip carpet (36x60), 17.5 D4, RSX, BLINKY, Sweep 32's.
i can post my setup if anyone wants it BTW its all ASSOCIATED PARTS on the chassis! No aftermarket mods!
Martin Vannieuwenhuizen
ASSOCIATED 2wd B4.2... BACK TO MY ROOTS
ASSOCIATED TC6.2, REEDY 6500, TEKIN RSX, 17.5 D4
ASSOCIATED RC-12R5.1 (lipo chassis), REEDY 7000, TEKIN RSX, 13.5 D4 1s
"racing since the 80's an XRAY was something you needed when you broke a bone."
BulletMan is offline   Reply With Quote
Old 03-18-2015, 10:18 PM   #1899
ViperZ's Avatar
Good to hear the TC6.2 came into tune for you.
Old 03-18-2015, 11:36 PM   #1900
JasonR/C's Avatar
Post setup! lol
Old 03-19-2015, 08:32 AM   #1901
Hi Bing, been googling for info on Tekin vrs Orca, specifically the VX3. I have a gen2 as well; Hows that new speedo doing for you?
Old 03-19-2015, 08:45 AM   #1902
ViperZ's Avatar
Hey Irvine, I've only ran one day of qualifying and Mains with it. I was slower by about 3 laps, however it's probably not all due to the new speed controller. The VX3 does feel smoother overall and less digital on/off, which affected my timing in throttle control. I can see it helping with my bad habit of pulsing the throttle. However is a change from a Tekin G2. Time will tell if its a good change.
Old 03-20-2015, 09:27 AM   #1903
TJames987's Avatar
Trader Rating: 10 (92%+)
Has anyone had any luck placing ships on the pin that holds the front castor blocks to reduce the crazy amount of slop it has by following the kit build? there is a lot of play along the pin when u push the castors fwd and back
Also would the old TC6 caster blocks that dont have the inserts reduce slop as well?
TJames987 is offline   Reply With Quote
Old 03-20-2015, 09:53 AM   #1904
Add a set screw to the caster block. Thread the set screw in till it contacts the hinge pin. This should eliminate most of the slop.
malkiy is offline   Reply With Quote
Old 03-20-2015, 11:33 AM   #1905
wtcc's Avatar
You can work with a shim there, but the effect is just for a short time. Using a setscrew helps. Just make sure the c-hub moves free.
I for myself gave up and just live with the slop. It stays that way (not getting more) and does not affect the performance.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
