Old 03-09-2015, 04:20 PM   #1846
chasingthepack's Avatar
Originally Posted by BulletMan View Post
what do i need to BUY to make my 6.2 strong and fast?
an xray
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 03-09-2015, 06:13 PM   #1847
DARKSIDE's Avatar
thanks for the replies.
i run 17.5 blinky with handout tires (sweep 32) my lap times are consistent and clean (usually ) top 15 laps are in the .1 to .2 spread.
as with stock being super competitive i need to be tight to the boards. i don't usually tap OUT! i guess i am frustrated by the X cars bouncing off the walls with no damage.
does the RSD021-4 work with the associated DJC coupler & axle?
I know where you are coming from, Im solo at my track against a fleet of brand X. But I hold my own...trial and error is my poison lol
not sure about the RSD parts...I try not to used to many aftermarket parts anymore if AE has them. I however been using the Tuning Haus c-hubs and going to try the CVA bones too..
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 03-09-2015, 06:15 PM   #1848
DARKSIDE's Avatar
Originally Posted by chasingthepack View Post
an xray
no bad no bad
Old 03-09-2015, 07:34 PM   #1849
BulletMan's Avatar
Originally Posted by Edwin Pibal View Post
Are you running a spool or a diff in the front ?
when I ran a spool the DCVDs I used to blow them apart on our long sweeping corner, changed out the spool to a diff with 300K oil and have never blown one since
ed
interesting... yes i run a spool. mostly because i don't like a lot of steering.
our tracks are small as well. 36x50. i put in the new axles to get rid of the front chatter.
Martin Vannieuwenhuizen
ASSOCIATED 2wd B4.2... BACK TO MY ROOTS
ASSOCIATED TC6.2, REEDY 6500, TEKIN RSX, 17.5 D4
ASSOCIATED RC-12R5.1 (lipo chassis), REEDY 7000, TEKIN RSX, 13.5 D4 1s
"racing since the 80's an XRAY was something you needed when you broke a bone."
BulletMan is offline   Reply With Quote
Old 03-09-2015, 07:39 PM   #1850
same size as our track.
id give it ago, its worked for all the tc6 drivers at our track
ed
Edwin Pibal is offline   Reply With Quote
Old 03-10-2015, 03:11 AM   #1851
ViperZ's Avatar
I find with the AE DCV you have to check the capture rings on the coupling tubes from time to time. They do tend to pop out of the channel allowing the pins to slip out. This is even when they are oriented the correct way. I was considering a set of RSD as they use a set screw like a MIP CV, however it looks like RSD has gone to the capture ring as well.
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 03-10-2015, 05:36 AM   #1852
NutDriver's Avatar
Trader Rating: 15 (100%+)
Maybe I'm out in left field, but would shrink wrap help retain the rings? Is there room?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 03-10-2015, 05:49 AM   #1853
ViperZ's Avatar
That's a great idea provided it clears the CHubs. My Tuning Haus aluminum. Ones I've already cleared aluminum away with dremel to stop binding. What's a bit more..
On my TC6.1 for VTA, I ended up removing the DCV and using the single. I don't think there is enough room with the plastic CHubs and I would not remove any material for clearance. Those break often enough. The one DCV on one side would alway pop apart. It may have been a faulty coupling tube, however I tired of not finishing so took them off that car. I can't say I miss them
Old 03-10-2015, 01:39 PM   #1854
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Sorry I haven't been on much this past week or so, been super busy. Got back to running outdoors this past Saturday and will be spending the next 2 Saturdays at Tamiya Raceway. Just practice this week but the following has a club race that has an extremely impressive entry list so far with 19 mod sedan entries. With the Reedy Race and ROAR Nationals both being held at Tamiya this year I'm sure everyone will have their game face on and the competition should be great!
Old 03-10-2015, 09:36 PM   #1855
BulletMan's Avatar
i do heat shrink them... lots of room! my problem is i broke the little end stub on the dog bone.
Old 03-10-2015, 09:41 PM   #1856
BulletMan's Avatar
hey randy... send me/us you test setting for Tamiya track. i have some buddy's on the waiting list
Old 03-10-2015, 09:58 PM   #1857
BulletMan's Avatar
hey tc6.2 owners... need some help on spool vs. gear diff in the front.
i DON'T LIKE a super twitchy/steery car. So i understand that a spool will make the front end a little "pushy". that's what i run. can i get that same feeling from a gear diff... with 1-2 million fluid? will a gear diff save my djcv from blowing up?
i run 90% of my races on a 36x50 carpet. traction is LOW to medium by the 3rd round and mains. i need ALOT OF GRIP.... right at the 1st time the car gets on the track.
any help is appreciated!
Old 03-11-2015, 04:18 PM   #1858
depending on temperatures, if its cold 300K if hot 500k
1m for me blew the dcvds apart as well
Old 03-11-2015, 07:52 PM   #1859
Are you guys using low profile servos in this car?
im just starting my build tonight.
thinking of using the savox SC-1251MG Low Profile servo
macscac is offline   Reply With Quote
Old 03-11-2015, 08:06 PM   #1860
ViperZ's Avatar
I'm using a Airtronics 94647 Low Profile Hi-Speed in my TC6.2.
I was thinking of trying this Lee Martin Xpert PI-3401 in my next TC6.x
