Team Associated TC6.2 Touring Car
#1816
Starting to run on road again.
D4 1s short stack 17.5 starting gearing point? Running the 106 64 pitch spur on a small track (8.8-9.2 lap times) where should I start?
#1817
Kevin TC6.2
I saw the Kevin car, with RSD servo mount and top plate, SPEC-R front arms and perhaps alloy under plate ....
Kevin, Can you talk about your feedback ?
Fred
Fred
#1819
Keven is running one of our Snowbirds edition bottom decks on his car. Along with a few other bits. The chassis is available by request only through the shop. The chassis has a few tweaks to increase on power rotation on the car. The chassis works fantastic, but it also requires a different top deck.
#1823
can you elaborate on much easier to drive?
#1825
The Evicerator
Regarding the post modification:
When I originally did it, I thought the biggest change for me was that when the car was changing direction, or transitioning from corner entry to mid corner, or mid corner to corner exit, the car stayed more consistent for a given steering input. Essentially, it can help keep the car from over-rotating without necessarily reducing steering input in certain circumstances.
It allowed me to drive my car harder, more confidently, and more consistently because of the more predictable attitude of the car after the change.
It's not a huge change, but sometimes the subtle changes are ones that make the difference.
Those with stock bellcrank posts will probably need about 4.5 mm worth of shims between the brace and the bottom of the top deck. Your millage may vary a bit on this... always test fit what you're going to try to sandwich between the two pieces of graphite because you could very easily induce some sort of undo tension in the top deck if you have too much, or too little spacing.
#1828
this CF brace you made..
does the servo not stay solidly in place under stress and that is why you made it?
Hi Randy,
you made quite some big changes compared to to 6.2 out of the box.
What front arms did you use? TC5?
Caster blocks?
What rear arms (TC4?) and carriers did you use?
Which parts did you use for your servo mount and steering posts?
Could you also say a few words why you made those changes?
Thanks!
Caster blocks?
Thanks!
#1829
I may rewire the motor, as once I got into the programming card I seen I can reassign the ABC timing and positions on the ESC. I don't mind it as it is now, but I may play around.
