Old 02-21-2015, 07:34 AM   #1801
Cridd's Avatar
Trader Rating: 16 (100%+)
In off-road I lower ride height or make turnbuckles longer or stiffer spring all for less body roll. On road will be interesting to hear.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 02-21-2015, 09:49 AM   #1802
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by ScottZ View Post
anybody got a fix for trackshon rolling getting way to much tractshion in fast corners thanks in advance
Couple easy tricks that you can do without changing your setup are sauce less of the front tire (maybe the inner 3/4) and if that doesn't work put glue on the outer sidewall of the front tires.
Another trick that worked great for me on the 6.2 is connecting the steering brace with the upper deck. This really mellowed out the steering response a lot and made the car much easier to drive.
Old 02-21-2015, 10:35 AM   #1803
Got a couple videos from practice this past Thursday at TQ Raceway. Ive got the car working very well but I still feel like theres a bit left in it. My guess is to compete with the top guys in the US I've gotta find about another .2-.3 consistently... so I'll be back next Thursday with a new list of things to test!
Sorry for the low quality vids.
[YOUTUBE]http://youtu.be/PmGnPCWfEy0[/YOUTUBE]
[YOUTUBE]http://youtu.be/48DVBrF_3KA[/YOUTUBE]
First time posting a YouTube video on here, anyone have an idea why the code didn't work correctly?
Old 02-21-2015, 04:41 PM   #1804
YoDog's Avatar
Trader Rating: 26 (100%+)
This is a common question but there is little anyone can suggest until we know what your setup is.
Please post the suspension settings and we can go from there.
Some of the most common things to change when traction rolling is to lower ride height, lower roll center and reduce droop. After that, softer springs and more negative camber.
By the way... right click your mouse over words that have a red squiggly line under them to see correct spelling suggestions.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 02-21-2015, 04:58 PM   #1805
Cridd's Avatar
Yo dog would softer springs make the car dig in more and roll?
Chris
B6D / T5M / SC5M
Old 02-21-2015, 06:12 PM   #1806
YoDog's Avatar
The key is to get the car to roll more. Softer springs will ultimately allow that to happen.
Think of it as the car lifts on the inside, the softer outside springs will lower under the weight transfer of the car rather than act as a high pivot point whereas harder springs won't compress as much. That being said... It would be best to lower the roll center first so that there is more force initiating chassis roll rather than making the suspension too squishy with soft springs. The second thing would be less droop as this will reduce the tendency of the springs to lift the inside of the car when turning.
Old 02-21-2015, 10:21 PM   #1807
Cridd's Avatar
Thanks for explanation.
Chris
B6D / T5M / SC5M
Old 02-24-2015, 02:23 PM   #1808
JasonR/C's Avatar
Looking for a starting spur pinion setup for stock 17.5.
Running a novak vulcan motor.
I race at leisure hours raceway in joliet. Big asphalt track.
New to onroad so any advice would be awesome
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 02-25-2015, 07:06 AM   #1809
Johnny Wishbone's Avatar
Not sure what pitch your running but start at 3.90 FDR and check your temps, depending on how big and flowing the track is, you may be able to run a lower FDR (smaller number).
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-25-2015, 07:15 AM   #1810
tbrymer's Avatar
You might try changing the oil.
tbrymer is offline   Reply With Quote
Old 02-25-2015, 06:36 PM   #1811
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default steering
hi Randy just wondering where can i get the cf part that you have for the steering and did you use the stock standoff and go threw the upper and lower chassi
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 02-26-2015, 03:47 AM   #1812
jpx
jpx's Avatar
Just use and cut the kit parts. 😉
jpx is offline   Reply With Quote
Old 02-26-2015, 08:48 AM   #1813
Running 1 dot all around for inserts. Our club track is back to its smaller more tighter chicane version. Just looking for suggestions if any on the insert choices if needed; the turning I like; at first I thought it was a little more aggressive but I think I like it now. Droop is 35mm front, 34mm rear which really translates to 1.5mm ORH front, 2mm ORH rear. 3 hole 1.1 piston 35 wt oil in shocks. Low grip track
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 02-27-2015, 06:25 PM   #1814
BulletMan's Avatar
Default setups
hey folks... got my new tc6.2 built and run one day.
where are some setups for LOW grip carpet? the associated site doesn't have any
Also were are you getting shock pistons... 1.1 x 3 hole?
thanks!
Martin Vannieuwenhuizen
ASSOCIATED 2wd B4.2... BACK TO MY ROOTS
ASSOCIATED TC6.2, REEDY 6500, TEKIN RSX, 17.5 D4
ASSOCIATED RC-12R5.1 (lipo chassis), REEDY 7000, TEKIN RSX, 13.5 D4 1s
"racing since the 80's an XRAY was something you needed when you broke a bone."
BulletMan is offline   Reply With Quote
Old 02-28-2015, 09:01 AM   #1815
ViperZ's Avatar
I'm using Reflex Racings 1.1 x 3 holes pistons.
https://reflexracing.3dcartstores.co...es_p_1318.html
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
