Team Associated TC6.2 Touring Car
#166
The TC6.2 being a new improved plateform I am sure the car will be better suited for most track out of the box. Unfortunately at this point I am not quite sure what the kit setup will be but once the car is out there will be setups online for it, rick already has an outdoor setup and there will be 2 or 3 of my latest setup I ran at the last few races I need to send in this week.
on a good note, I can see a lot of part in stock on team associated website, heard only a few minor things missing to seal the boxes and ship them !
#169
his car was definitely the best looking however it did look like he could use a bit of throttle expo, a bit slow to get up to speed is what i mean, you can really see this around the 4 min mark when the yellow car is starting to follow/catch up with him
#170
Thanks Logi maker for the video... Perfect lines from Herbert, and Volker like Performance... I believe the Herbert/tc6.2 combo will at last challenge Volker, should they meet.... Good Job Keven !!!!!
#172
#174
#175
front spool cup durability?
has anyone tested the car doing mod? Is the front spool holding up to the abuse without breaking? I'm looking for a very durable car for 4.0 turn motors in parking lot racing.
very excited about this car
#177
The spool itself is fine but I prefer the metal outdrives for better durability. I pretty much only use the TC6 slipper spool on pavement exclusively as it has proven to be very reliable.
The Associated team has been running the TC6.2 in mod but from what I gather, most has been on carpet thus far.
#178
For improved durability, AE now offers optional steel spool outdrives. These are not only themselves stronger, but the plastic blade which is also prone to breaking is eliminated. This will be your most durable spool setup and what most if the team drivers will use when they choose to use a spool.
You might not even want to use a spool. The use of gear diffs is pretty common for asphalt racing so you might want to look at that as an alternative.
#179
The TC6.2 comes with a spool equipped with plastic out drives. Spool outdrives are stressed when you hit a board. The harder you hit and the more solid the board, the easier it is to break something. The power of a 4.0 is no problem for the spool. You are not going to break it unless you hit something.
I have actually had nothing but trouble with the plastic outdrives breaking blades. Even during a clean run one would fail. Is this a symptom of the track width in the front being too narrow? I quit using them before testing a little shimming of the arm mounts. Once I switched back to the diff or slipper spool, the problem went away. I know I'm not the only one with this problem. I usually run the diff for 17.5 but prefer the spool for mod.
#180
Thanks for the clarification Rick.
