Old 11-30-2014, 07:39 PM   #1606
samnelso's Avatar
Originally Posted by teknorookie View Post
Quick question-trying to use a savox 1258 but the top of the case hits the steering bellcrank post. Any one have a fix around this other than a different servo? Appreciate the feedback.
Could sand the servo ears with a dremel. I think if you take around 1mm off the ears it'll fit.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 11-30-2014, 09:10 PM   #1607
I'll give that a shot. Thanks!
Enjoying this rc hobby while I can!
teknorookie is offline   Reply With Quote
Old 12-01-2014, 07:36 AM   #1608
Trader Rating: 14 (100%+)
Hello fellow tc6.2 drivers. Do any of you have a spare top hat for the shocks and or an extra 1 dot arm mount? I don't want to spend $20 for parts for those two small things. I can trade other small misc parts for those, or give someone a couple of bucks for the parts. I have extra bushings for the c-hubs, 2mm blue shims, turnbuckle ends, etc...
trilerian is offline   Reply With Quote
Old 12-01-2014, 02:11 PM   #1609
Originally Posted by jpx View Post
So do I.
I use Hudy gauges measuring 0.2mm increments with 10mm blocks in conjunction with the droop gauge. I was aalways happy with that throughout the past years at clubracing level running 17.5T.
I think the most important thing is, that you allways use the same method of pressing down and measuring. That's the only way you will be able to track and understand your changes on your setup. And you'll allways be able to return to an older setup of yours which you documented earlier.
Thanks for the advice. To be honest I never calculated droop that way; it was always mm over ride height. To do this it is an art of trying to see when the set screw hits the chassis; I really don't think it is precise; but I think it is the preferred method amongst xray drivers in our club. I don't want to start a debate since it is outside the scope of this forum but don't most people do mm over ride height? or this just a simple preference.
I do have the Hudy setup station for touring; so when Hebert posts in his setup that say his value in the rear is 5, then that is the value on guage of which his car is sitting on his 10mm blocks? Sorry I've never used a droop guage before.
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 12-02-2014, 06:51 PM   #1610
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Just a suggestion on how to measure droop that will be sure you always have the same droop from car to car. I put the car on 10mm blocks and measure to the top of the axle right where it meets the hex. A good baseline setup for this on any car would be 5mm ride height with 34mm rear droop and 35mm front droop. My settings as of late have been 34.5mm rear and 36mm front but this is pretty aggressive and may be hard to drive.
Old 12-02-2014, 07:01 PM   #1611
Also, couldn't be happier to announce that I've signed with Team Associated for 2015! I had taken roughly a 5 year hiatus from TC but when they announced the Reedy Race was going to be held at Tamiya America again I couldn't resist coming out of retirement for that race. I missed finishing where I wanted by 1 spot but it was still enough for me to catch the racing bug again and I'm excited to see what I can do in 2015 with some amazing sponsors backing me!
Although I've only got a couple club races under my belt with the 6.2 I feel like it really fits my driving style very well. I'm still learning the car and have yet to nail my setup but I will still be on here often to answer any questions I can!
Old 12-03-2014, 03:55 AM   #1612
G-kenny's Avatar
Have you guys any idea's what gearing combo would work to get a FDR of 4.5-4.6ish. Having a look at the Standard TC6.2 gear chart are there is no options that can get close.
G-kenny is offline   Reply With Quote
Old 12-03-2014, 05:20 AM   #1613
104/46 will give you a 4.52 fdr, 104/45 willbe a 4.62 fdr
Old 12-03-2014, 07:05 AM   #1614
Hi Randy, I'm just curious how much camber would effect the droop measurement when doing it this way. Not saying its right or wrong but thinking the camber could effect droop when measuring off the axle. Whats your opinion? Congrats on your AE signing as well.
Rodney Racer is offline   Reply With Quote
Old 12-03-2014, 11:05 AM   #1615
well if you have an Iphone; there is a app called ratio calc; has all the makes of brands including the 6.2 as well as the ability to input other variables (Tire size etc). I think its only couple of bucks for the app; makes things so simple.
Of course there are free things on the internet as well; hope that helps.
Old 12-03-2014, 02:32 PM   #1616
Glad you pointed that out because I did forget to bring it up. I always set my camber before setting droop, this way I can ensure the right and left sides will be measured accurately. I rarely venture outside of 1.5-2* of camber so although it will affect the measurement it will only be by maybe a tenth of a millimeter or so.
Thank you, still very excited to be a part of Team AE!
Old 12-03-2014, 08:47 PM   #1617
samnelso's Avatar
Interesting approach. I may have to give it a go and see how it compares to my traditional method of dialing in the sides by measuring under the arms then adjusting ORH. Consistency is key as stated before and the comparison will be interesting.
Welcome to the team Randy!
Old 12-03-2014, 10:29 PM   #1618
It's just another way of doing the same old thing, but just nice to not have to change your settings from car to car as new kits are released.
Thank you!
Old 12-04-2014, 09:42 AM   #1619
Thanks for the advice, I assume you are measuring that value with a set of digital calipers and with the shocks off?
Thanks and it is good to have you with the AE team.
Old 12-04-2014, 09:50 AM   #1620
I've attached a picture for visual reference only, obviously you would use a setup board. But any calipers will do, I just set the caliper to the desired height and then adjust the droop until it's correct. I set the droop with the shocks on, typically in the front the springs will be pre-loaded which will press down on the arms at full droop so I want to make sure the droop is set correctly with that load applied.
Edit, go figure the picture is sideways but you can still see how I check.
