Old 11-27-2014, 06:39 AM   #1591
3 quick questions; setting up ride height and droop.
Whenever I'm setting ride height; invariably I get different answers each time I double check my work. I'm wondering if when I'm setting my TC6.2 on the hudy board I'm not letting it settle correctly; At first I just press down each end and then adjust accordingly. I'm wondering if I have to press each end of the car down a few times and then adjust the spring collars appropriately.
What do other people do?
I'm using the AE ride height guage, should I just break down and get the stepped hudy one? I do have the graduated one.
Also setting the droop settings; I do it by eye as I think alot of people do; looking at the droop set screws, lifting up the chassis slightly until the scews hit the chassis.
There is this video: http://www.youtube.com/watch?v=dYLvImYUBt4
Gills here uses the hudy setup blocks and droop guage; is that the way to go? or is my way (I assume most peoples) the easier way.
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 11-27-2014, 03:48 PM   #1592
ViperZ's Avatar
Hi Irvin,
When ever I set-up ride height, I will always press down on the front and back of the car to make sure it's set. After each adjustment and turn of the collar, I will press down on the front and back shock towers again before making a measurement.
I use a Dynamite and Integy gauge. The Dynamite is a precision gauge in that it measures 0.5mm increments, and is a straight ramp on the other side. The Integy ride height & droop gauge measures in 1mm increments. For droop I use EDS 10mm blocks in conjunction with the Integy droop gauge. It sets-up really well and I prefer this way with blocks.
I find my adjustments don't deviate at all during set-up and after running.
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 11-27-2014, 10:36 PM   #1593
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by ViperZ View Post
Thanks! It was good to race with your club and meet new people!
I think the slop is less important as we make it out to be.. But I'm just a club racer, and can't discern between the .003 lap difference it may make.
What did you do to fix the binding of the hub to steering black on the bottom screw? I think I may have to remove a bit of metal...
During the race this Sunday in practice, I hit a car that was stopped on the straightaway, it resulted in a broken C-Hub.. This got me thinking if I had the Aluminum on in, it would not have broke, but then I wonder what else would have broke. As it was it was simple to replace, but had it been the A Arm that broke, that would have been more of a paint to replace I think...
I was looking at a Reedy Black Box for my W-GT as it does 1s....
Good thing you had that bumper brace on! Lol
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 11-28-2014, 12:37 AM   #1594
ViperZ's Avatar
For real!
Old 11-29-2014, 02:32 AM   #1595
jpx
jpx's Avatar
Hi Irvin,
So do I.
I use Hudy gauges measuring 0.2mm increments with 10mm blocks in conjunction with the droop gauge. I was aalways happy with that throughout the past years at clubracing level running 17.5T.
I think the most important thing is, that you allways use the same method of pressing down and measuring. That's the only way you will be able to track and understand your changes on your setup. And you'll allways be able to return to an older setup of yours which you documented earlier.
AE TC7 / 17.5T blinky GT
WRC f-one '016 / 21.5T F1
jpx is offline   Reply With Quote
Old 11-29-2014, 11:07 AM   #1596
ViperZ's Avatar
Originally Posted by jpx View Post
So do I.
Agreed, consistency is key. I really like using the droop blocks for set-up
Old 11-29-2014, 11:11 AM   #1597
Wazza22's Avatar
Trader Rating: 22 (100%+)
Hi there,
I am considering purchasing a 6.2 to run outdoors on medium to low grip asphalt. I have noted in previous posts some of you guys are fitting alloy front C uprights etc. Are the standard kit parts too fragile?
Many thanks
Essential RC Australia
WRC Racing Australia
Teamsaxo Australia
Wazza22 is offline   Reply With Quote
Old 11-29-2014, 11:53 AM   #1598
wtcc's Avatar
If you are crashing hard the c-hubs can break. They are not fragile but also not as bulletproof as the Xray ones. For the last two years I didn't break one... So this is just a problem if you frequently hit the boards hard
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 11-29-2014, 12:07 PM   #1599
Wazza22's Avatar
I don't crash often either, so that sounds like they will be ok. I have read that the spool outdrives wear quickly, so are the steel ones a good upgrade or is the wear not that bad!
Many thanks
Teamsaxo Australia
Old 11-29-2014, 12:29 PM   #1600
wtcc's Avatar
My steel outdrives lasted the whole summer season with a 10.5t motor. For the winter I changed them plus the axles.
Old 11-29-2014, 04:50 PM   #1601
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I've got 3 full days of racing on the steel outdrives and they show practically no wear at all yet. Use a good thick grease on the universal drive pins to help with friction and wear, I use Tamiya Anti-Wear Grease personally but plenty of others will work fine.
Old 11-29-2014, 08:13 PM   #1602
Wazza22's Avatar
Thanks for your info, are there any other gotcha's I need to know about?
Cheers
Teamsaxo Australia
Old 11-30-2014, 12:46 AM   #1603
wtcc's Avatar
ReflexRacing has some nice option parts. A must have are the bladders.
Old 11-30-2014, 01:40 AM   #1604
Wazza22's Avatar
Thanks so much for the advice
Teamsaxo Australia
Old 11-30-2014, 02:35 PM   #1605
Quick question-trying to use a savox 1258 but the top of the case hits the steering bellcrank post. Any one have a fix around this other than a different servo? Appreciate the feedback.
Enjoying this rc hobby while I can!
teknorookie is offline   Reply With Quote
