Old 11-24-2014, 08:34 AM   #1576
Originally Posted by ViperZ View Post
@ Irvinew, I heard Moose Jaw's track is bigger than Saskatoon's. On our track it is said that 4.09 is ideal, and its a small tight track. Yet you are running a 5.5?
You must be alabout that torque
I don't remember precisely the reasons why I put the fdr higher; its just a guess based on size of track and speed I can handle; its been awhile but speed hasn't been the reason why I don't get tq all the time; its only my 3rd year back driving an rc car.
I know that 4ish is about what you before your 17.5 melts but if your running that high of a gear on a track that is smaller than ours I'd appreciate your input on proper gearing; sorry no sarcasm this time.
TC7 TC6.2 Tamiya Mini RC12r5.2 Reedy FUTABA RSD
irvinew is offline   Reply With Quote
Old 11-24-2014, 09:14 AM   #1577
ViperZ's Avatar
I was able to run at the Moose Jaw track on Sunday. I can sort of understand the lower gearing now. Although your track is bigger than ours you have a very tight infield with lots of switchbacks. It was fun to drive it.
Sorry I don't have any real recommendations as I'm no expert.
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 11-24-2014, 09:45 AM   #1578
samnelso's Avatar
The track I typically run at is around 70'x35' if I had to guess. Between a 4:1 and 4.2:1 FDR seems to work well. Motor temps are not too high - maybe ~130F. We use strong fans of course.
For a larger track, say 100'x48', I'd start with my 17.5 Reedy around a 3.8-3.9.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 11-24-2014, 10:53 AM   #1579
Great to have you guys down; I'll have to come up sometime; good to see someone else driving blue.
Sorry to see about Tuning Haus; Looks like they have good customer service; maybe you got a bad batch. I saw a video where this one person tapped a set screw into the castor blocks; I wonder how many people actually do that or do most people live with X amount of slop of which might be normal in any kit.
Old 11-24-2014, 10:56 AM   #1580
Is that Fitchburg MA? Looks really nice; yes I can see where a 4 would be desirable; maybe in WCICS early next year I will run that setup.
I travel to Swampscott MA every year; maybe I can stop by and watch some racing.
Old 11-24-2014, 11:19 AM   #1581
ViperZ's Avatar
Looking at your track that sounds about right or close enough then as it looks
Like a fast flowing track.
The Moose Jaw track is 60' x 50' and has a real tight infield. I had lots of low speed torque with 4.09 and enough speed on the straight.
Moose Jaw Fastraxx
Old 11-24-2014, 03:29 PM   #1582
DARKSIDE's Avatar
Report...the C-hubs worked great even after a couple of really good hits. They stayed true at 4 deg. The work to get them right was for mine I took my Dremell and hooked the pin to it and ran it in the hole with white grease.
checked them after the race and they are still good and loose. Without the slop that the originals have.
I would say they are worth it at this point. A few more race weekends and Ill check back...I will be looking to get 2 more sets for my other 6.2's
Note. Also ran the Reedy Blackbox this weekend as well in my GT car...omg.. its a very nice esc...been running the LRP, and switched over.
Team Associated TC6.2 Touring Car-esc.jpg   Team Associated TC6.2 Touring Car-esc2.jpg
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
Final On-Road Race
Summit RC Raceway June 17th
Ft. Wayne IN
DARKSIDE is offline   Reply With Quote
Old 11-24-2014, 05:36 PM   #1583
aliencehobbies's Avatar
ive been wanting a blackbox as well heard they are super smooth
aliencehobbies is offline   Reply With Quote
Old 11-24-2014, 06:12 PM   #1584
ViperZ's Avatar
Thanks! It was good to race with your club and meet new people!
I think the slop is less important as we make it out to be.. But I'm just a club racer, and can't discern between the .003 lap difference it may make.
What did you do to fix the binding of the hub to steering black on the bottom screw? I think I may have to remove a bit of metal...
During the race this Sunday in practice, I hit a car that was stopped on the straightaway, it resulted in a broken C-Hub.. This got me thinking if I had the Aluminum on in, it would not have broke, but then I wonder what else would have broke. As it was it was simple to replace, but had it been the A Arm that broke, that would have been more of a paint to replace I think...
I was looking at a Reedy Black Box for my W-GT as it does 1s....
Old 11-24-2014, 06:27 PM   #1585
samnelso's Avatar
This one is RC Madness in Connecticut. Fitchburg has a track as well, RC Excitement. It's predominantly offroad, but we're trying to revive their carpet program.
Old 11-24-2014, 09:00 PM   #1586
True. I run a 3.8FDR currently with my Reedy 17.5. Our track is ~100x48.
https://www.youtube.com/watch?v=hCkM...0h0LR7kdbdA3BQ
Andrew Cartwright
A_Cartwright is offline   Reply With Quote
Old 11-26-2014, 05:29 PM   #1587
ViperZ's Avatar
What an awesome track and race video!! That looks like a fast track!
Who here has drilled the top of their shock caps to allow for a zero rebound setup?
Is it recommended, and can you show me a picture of where it's drilled?
Old 11-26-2014, 06:19 PM   #1588
ViperZ's Avatar
I just went for it! Drilled the top of the cap with a 1mm bit, rebuilt with 35wt and RSD bladders = Zero rebound
Old 11-26-2014, 06:48 PM   #1589
NutDriver's Avatar
Trader Rating: 14 (100%+)
I look forward to hearing what you think of this change. :-)
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 11-26-2014, 08:00 PM   #1590
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Great video! Your car was dialed.
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
