Old 11-20-2014, 03:53 PM   #1561
ViperZ's Avatar
@ Irvinew, I heard Moose Jaw's track is bigger than Saskatoon's. On our track it is said that 4.09 is ideal, and its a small tight track. Yet you are running a 5.5?
You must be alabout that torque
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 11-20-2014, 04:02 PM   #1562
Rugspin's Avatar
Default Almost ready to roll
Just waiting on my electronics to arrive. LRP Flow Works Team and Futaba Servo.
Steve Burgess
Rugspin Graphix http://www.rugspingraphix.com
FB http://facebook.com/rugspingraphix
Email rugspinner@aol.com
Rugspin is offline   Reply With Quote
Old 11-20-2014, 04:10 PM   #1563
ViperZ's Avatar
Rugspin, Looks awesome!!!
Old 11-21-2014, 08:59 AM   #1564
ViperZ's Avatar
I picked up the Tuning Haus Aluminum C-Hubs and Rear carriers for the 6.2. Let me start by saying I'm disappointed in these I was looking to tighten up the front end a bit using these, but was more just looking to upgrade something...
I tried to install the right side first and after a few test fits decided to abandon them for the time being. They will need some work to make them work properly. That's not performance.
The first problem is the lower screw that holds the steering block into the C-Hub binds when tightened up. You have to loosen it a few turns before it frees up the block, but then the screw is too loose. I need to look at this closer to understand why it's binding, however I assume I may need a washer under the screw, or remove material from the shoulder of the C-Hub. The top ball stud threads in and does not bind the steering block when tightened.
Next the hinge pin would not slide into the C-Hub with out tapping it in with a hammer. This removed some aluminum and anodizing from the hole, but it was still a tight fit. There is no way this is coming out easily if pressed through the A-Arm, through the C-Hub and in place. It will require reaming out to larger than 2.54mm (Hinge pin). I have ordered a reamer just because.
I did not check the rear carriers, however I suspect they hinge pin holes will be similar in under sizing and will require reaming as well. At this point I just said screw it and threw back on the OEM plastic C-Hub.
The pieces themselves look nicely machined in general, however the fit is unacceptable. I would not recommend them unless you want to fiddle about to make them fit, like I will have to do. And could they not have anodized them in blue? That was nearly a non sale point for me, and I wished I would not have caved.... Oh well, add it to my pile of life lessons.
Old 11-21-2014, 10:05 AM   #1565
ViperZ-
I'm disappointed to hear that these items did not meet your expectations. I would appreciate the chance to exchange these for other Tuning Haus items you might use or ?
Send me a PM or e-mail at bill@tuninghaus.com and let me figure out a way to create a satisfied customer. Thanks!
Bill
Bill Jeric is offline   Reply With Quote
Old 11-21-2014, 11:51 AM   #1566
ViperZ's Avatar
Originally Posted by Bill Jeric View Post
ViperZ-
Bill
Thanks Bill! PM your way.
Old 11-21-2014, 11:58 AM   #1567
Default Aluminum spur gear pulleys
I've been looking for a pair of the TA aluminum spur gear pulleys......
Has anyone actually seen or have these?
Any idea how long they'll be out of stock everywhere?
Are there aftermarket pulleys like the associated ones that will fit?
Just like shinny things
CG3
chipgibbs is offline   Reply With Quote
Old 11-21-2014, 12:06 PM   #1568
ViperZ's Avatar
CG3
Yes, I have them, they are a nice looking addition..
Old 11-21-2014, 02:37 PM   #1569
DARKSIDE's Avatar
plus 1...same issues...it takes some work to get them to work properly... I will test them Sunday at the track and see if it was worth the effort
also the pulleys work great....Ive got them on all my TC6 series cars
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
'17 USVTA Summer Slam @ The Gate
July 28th-30th,2017
DARKSIDE is offline   Reply With Quote
Old 11-21-2014, 02:43 PM   #1570
NutDriver's Avatar
Trader Rating: 15 (100%+)
I've always thought Bill Jeric was a good guy and upstanding businessman. Thanks for reinforcing that point. I look forward to further updates on this situation.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is online now   Reply With Quote
Old 11-21-2014, 02:45 PM   #1571
DARKSIDE's Avatar
here are some pics old and new
Team Associated TC6.2 Touring Car-chub.jpg   Team Associated TC6.2 Touring Car-chub2.jpg   Team Associated TC6.2 Touring Car-20.jpg   Team Associated TC6.2 Touring Car-21.jpg
July 28th-30th,2017
Old 11-21-2014, 05:43 PM   #1572
ViperZ's Avatar
Darkside, what did you resort to solve the binding of the steering blocks?
Thanks!
I certainly appreciate Bill's initiative here....
Old 11-21-2014, 09:57 PM   #1573
ViperZ's Avatar
I mounted a new Franksbodies LTR-C to the TC6.2 themed with all the stickers I got with my tools. Added to maintain the theme are the red anodized Protoform wing mounts, and red Tuning Haus wheel nuts.
Old 11-22-2014, 07:59 PM   #1574
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I haven't heard anything about Franksbodies in nearly 10 years, glad to hear he is still around. Definitely one of the most talented painters in the world.
Old 11-23-2014, 04:15 AM   #1575
ViperZ's Avatar
Good to hear he's a mainstay in the hobby! His work is excellent indeed!
