Old 10-29-2014, 02:19 PM   #1486
What shock pistons are you using?
Surrey is offline   Reply With Quote
Old 10-29-2014, 03:14 PM   #1487
wtcc's Avatar
I have put a thin layer of plastic underneath the piston. The layer lets three holes open. Because it is so thin it bows away under pressure from the piston when the shaft moves upward and lets the oil pass. If the shaft moves down, the pressure presses the layer against the piston and closes the holes.
Here is a fast scribble I made when the idea struck me:
The pistons are these:
http://www.reflexracing.net/RSD-10mm...es_p_1600.html
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 10-29-2014, 07:32 PM   #1488
NutDriver's Avatar
Trader Rating: 14 (100%+)
RPM used to make dual pistons very similar in concept to this.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 10-29-2014, 08:49 PM   #1489
ViperZ's Avatar
Had a good practice session tonight! Definitely improving and getting a bit more consistent in lap times.
My AE motor cooling fan packed it in. Looks like the fan blade may have tagged the mount during a board hit. It smelt like burnt electronics when I pitted, and the fan was out of alignment to the shroud. I was able to get it back in place and the fan ran afterward, but it was really noisy and certainly not at full speed
I removed it, ran another practice session. Motor temp was at 174F after more than 8 minutes, at +50 degrees timing. I may back it off until I get a replacement fan, or not
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 10-30-2014, 10:14 AM   #1490
chevtech23's Avatar
The AE fan that comes with the cool mount has a short life span, I haven't seen anybody get more than two races out of it. but the bracket is cool
chevtech23 is offline   Reply With Quote
Old 10-30-2014, 01:24 PM   #1491
AE-Reedy
I know it is not optimum but mounting the fan on the bracket backwards help the life out a lot. It does still help cool the motor just maybe not as much.
Sean Cochran is offline   Reply With Quote
Old 10-30-2014, 02:54 PM   #1492
I don't have the setup in front of me right now but does anyone use a aftermarket fan in replacement? Do all these fans give out after a time?
TC7 TC6.2 Tamiya Mini RC12r5.2 Reedy FUTABA RSD
irvinew is offline   Reply With Quote
Old 10-30-2014, 03:34 PM   #1493
chevtech23's Avatar
yes, right now I have a Viper in one car, Muchmore in the other, the size is the same.
Old 10-30-2014, 06:56 PM   #1494
DARKSIDE's Avatar
Ive been running mine since AE released the fan and mount, and I can say its holding up pretty well...Ive got the AE fan in one car and an R1 in the other...both are getting it done
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 10-31-2014, 07:10 AM   #1495
Conrad's Avatar
Nice simple execution wtcc, I know it's be done a few times over the years by different people/companies but how did you find the change on car in handling?
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 10-31-2014, 08:16 AM   #1496
ViperZ's Avatar
^^^ That's intense
So this fan situation. That it's a common failure, what's a person to do? Get a motor heat sink mounted one like I have on my TC6.1?
I picked up a replacement Muchmore at my LHS, however it was not a thick. It seems to have a similar RPM by sound, however I don't think it moves quite as much air. I also ordered a few Yeah Racing Tornados to have on hand as replacements.
For the Muchmore, I placed a small 1mm washer between the fan mount and the fan. I may try a 3mm. This should keep the fan blades from tagging the mount, which is what I'm sure happened last time.
1mm spacer
Compared to the Associated fan
I readjusted my chassis to Cartwright's settings, even though I'll have to do it all over once the Yokomo springs arrive. Surprisingly I wasn't too far off, with exception of the droop. Seems I had more droop than the 5.5 as I set it up as a ratio of ride height, as instructed by a fellow member. It was about 7-8mm
Old 10-31-2014, 08:43 AM   #1497
samnelso's Avatar
I use the AE fan mount and have not had any fan issues. Using the WTF fan currently. Yeah racing fan is good too.
Nice photos as always Viper.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 10-31-2014, 09:00 AM   #1498
ViperZ's Avatar
Thanks Sam!! Great to hear on the fan. I learnt of those WTF fans after I ordered mine. I may get a few for I'm always a sucker for fans You should see my out of control collection of PC fans from my PC modding days, it's ridiculous and embarrassing ....
Old 10-31-2014, 09:56 AM   #1499
I'm (I think) one of the few that uses the plain old droop gauge. Make sure you measure to the notch on the arm like the instructions say and not the bottom of the arm.
The yokomo springs are a big difference to me. I'm not sure exactly why but after trying AE, RSD, Tamiya etc, they are more consistent and easier to drive hard. RSD came close.
That setup rolls a fair amount. I'm testing a slightly more aggressive setup now. I'll get some more time this weekend finally
Andrew Cartwright
A_Cartwright is offline   Reply With Quote
Old 10-31-2014, 12:31 PM   #1500
ViperZ's Avatar
Awesome, Thanks for posting in Andrew! Hmmm, I'll have to check to be sure I did it right.
So a more aggressive set-up would be what? Higher rate springs?
