Ho can you read caster on a hudy Setup bord
How can you read caster on a hudy setup bord not camber.
On one pair of "wheels" there should be a scaling on the side, where it bolts to the axle. This when put on the right way round, and lined up with the "kingpin" will show you caster. I think on the Hudy it relys on you lining up and determining the reading.
I don't think i've put that very clearly, but i can't think of a better way!! hope it helps |
Try this..................http://www.hudy.net/products/setup/images/hudysetup_instructions.pdf
oh sorry, did not set the url right...........:cry:
