Old 11-15-2013, 01:53 AM   #46
Skiddins's Avatar
Originally Posted by CraigM View Post
...My understanding of the theory is that sweep does increase castor as the car rolls into the corner because the arm is not hinging in a horizontal plane relative to the track....
Having messed around with 'models' (Post-It pads and rulers etc ) I think that sweep wouldn't produce any more difference in castor than is produced without the sweep, i.e. the 'dive' effect of the chassis under braking.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RD Disco
Skiddins is offline   Reply With Quote
Old 11-15-2013, 02:09 AM   #47
Lessen's Avatar
Send a message via MSN to Lessen
Although I do not believe it is this so-called "reactive caster" that gives sweep it's trait, I am having a difficult time seeing how sweep alters caster as the suspension goes through it's motion. To alter caster within the confines of the suspension motion, the angle (or relative heights of both the leading and trailing ends of the outboard pin) would need to change as the suspension moves about. In most of our car's designs, the caster block is mounted at a fixed angle to the a-arm, so outside of a-arm flex (twisting, as softer arms do) the caster angle does not really change as the suspension is compressed, sweep or not. Now pan cars have something different going on because their kingpin angles are not affixed to their suspension motions, which gives them the ability to have true "active caster".
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 06-14-2014, 06:31 AM   #48
niznai's Avatar
Very good explanations, Cristian and Lessen.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is online now   Reply With Quote
SEO by vBSEO 3.5.0
