Like Tree34Likes
Old 05-11-2016, 07:05 AM   #1456
Trader Rating: 33 (100%+)
Originally Posted by Potoczak View Post
Going to start out on high bite carpet then switch over to medium bite asphalt when it warms up more here on the east coast.
If it is the new black carpet, I recommend the aluminum chassis and pod plate.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 05-11-2016, 07:35 AM   #1457
Skiddins's Avatar
Originally Posted by SMcD View Post
Does the track have a rule about the front wing? If not, I'd stick with the stock wing for durability on the carpet. Otherwise, you need a wing, at least.
I disagree with the kit front wing, the polycarbonate wings are rubbish and get caught on corners too easily.
Get a Tamiya F104 front wing (J parts)
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-11-2016, 08:24 AM   #1458
ByteStream's Avatar
Going to be picking one of these up in the next few days. Any option/spare parts I should keep on hand or get before the build??
I would replace the wings .. the front wing isn't legal at some races, and there are some more durable options, Mon-Tech, Tamiya, etc. The rear wing is a bit soft, so if you find spur gear marks on it or if your spur is chewed up, it's because it flexes into the gear if you rollover/crash. Also most people will modify the rear wing so it mounts directly to the back plate (remove the standoffs and cut the wing so it mounts flush). With the Rear Mon-Tech wing you don't have to modify the wing, it will already sit flush.
The car otherwise is pretty durable - I've only broken wings.
Needs:
371290 Universal Body Mount
338586 Shim 5x7x0.5 (widen the car)
Spares:
1 x Bottom Arm
Options:
Mon-Tech Front Wing
Mon-Tech Rear Wing
Enjoy
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 05-11-2016, 08:42 AM   #1459
Side and front springs. I loose them and need to replace at least once a month. I'm not a fan of gluing the side springs on.
astgerma52sp is offline   Reply With Quote
Old 05-11-2016, 12:35 PM   #1460
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Maxxican View Post
Any of you X1 owners make the change to 25.5T motor? If so how are you gearing? For outdoor asphalt medium large track.
Reedy M3 25.5T
50* timing
32/90 as a starting point. The Reedy has a 12.5 rotor, so you will probably get away with a bigger pinion than a motor with a 12.3 rotor.
Old 05-11-2016, 03:17 PM   #1461
Maxxican's Avatar
Trader Rating: 65 (100%+)
Ok thx I'll start there.
Carlos F.
RoadRunnersRC.com
RC AMERICA || XRAY || HUDY|| ACTIVRC || HOBBYWING NA || PROTOFORM
Maxxican is offline   Reply With Quote
Old 05-11-2016, 03:31 PM   #1462
JayL's Avatar
Seems like if people are going to switch to 25.5 they should run ROAR approved motors, which is only Team Scream or MOTIV......
I like the Montech front wing, the rear wing, not so much
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 05-11-2016, 05:08 PM   #1463
Potoczak's Avatar
Trader Rating: 111 (100%+)
Thanks for all the suggestions guys. Much appreciated! But I'm going to be converting the car to the lemans style body. Like this
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 05-11-2016, 05:36 PM   #1464
Trader Rating: 28 (100%+)
Fun! Just finished mine.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-11-2016, 10:57 PM   #1465
charlessito's Avatar
what body shell fit x1 when batt is place across?
YOKOMO DRB . MugenSeiki . SCRT10 . Kyosho GT2 . MST RMX-VIP
charlessito is offline   Reply With Quote
Old 05-12-2016, 05:39 AM   #1466
The stock 15 and 16 both fit. But I think some have gotten one of the Protoform bodies to fit as well.
Chris Lockhart
Old 05-12-2016, 04:42 PM   #1467
JayL's Avatar
You body looks horrible John! hehe
So tempted to build one but don't want to dilute f1 into yet another class
Old 05-12-2016, 08:26 PM   #1468
Potoczak's Avatar
Anybody know who has the hiro seiko screw kit for the X1 in stock??
Pete Potoczak
Old 05-12-2016, 08:47 PM   #1469
For you guys at speedworld,I understand. Most at wsr have 2 f1's so there is at least 6-7 guys who have them built and will run both classes. If my car is as fast as USGT locally, I could always run it with them for giggles.
Team I'm Over It
Old 05-13-2016, 08:13 AM   #1470
Trader Rating: 29 (100%+)
EA normally has them but the site shows out of stock right now. RCMart is always an option if you don't mind shipping cost and wait time.
Looks like Apex has a few screw kits in stock...
https://www.apexrc.com/en/parts/scre...loy-screw-set/
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
