Like Tree47Likes
Old 04-23-2016, 08:27 AM   #1426
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by j.d.roost View Post
Can somebody explain how the front roll center adjustment works?
I understand the shims change it...but what does adding and removing the shim thickness do to the suspension and to the grip level of the front?
Does is work like tc ...thicker lower arm shim should...in theory raise the roll center (increasing grip)?
Also can I lower the r.c. by adding shims under the front arms?
Can I also add reactive castor by adding offset shims to the upper arm?
IT pretty much works like a touring car. And yes, tilting the upper arm adds reactive caster.
Old 04-23-2016, 09:05 AM   #1427
mbykerman's Avatar
Trader Rating: 45 (100%+)
I put Jan'so snowbird setup on my car,but having a problem getting the correct ride height on it. His setup sheet says he has 4mm shims under the arms and he is using the Pit tires and his front ride height is 3.8, but with 4mm shims under the arms on my car and with either the Pitts tires or the CRC tires I still only get 2mm ride height. Everything else is the same. Am I missing something or is his setup sheet wrong?
mbykerman is offline   Reply With Quote
Old 04-23-2016, 10:37 AM   #1428
your front springs have probably collapsed. I had 4mm on front with mine at the 'birds with the same shim pack... its all about the springs too.
freebird is offline   Reply With Quote
Old 04-23-2016, 04:39 PM   #1429
mbykerman's Avatar
OK I will look into that. Thanks
Old 04-25-2016, 01:46 AM   #1430
sbd
Also you may check the status of your lower balls . If they are worn, the front will drop significantly. With the plastic balls the wear could be fast especially if you run ourside.
sbd is offline   Reply With Quote
Old 04-28-2016, 02:38 PM   #1431
nova2015's Avatar
I recently noted on Facebook, somebody had set up an oil filled gear diff for the X1. Anyone have any further thoughts or info on this?
nova2015 is offline   Reply With Quote
Old 04-28-2016, 02:56 PM   #1432
Send a message via ICQ to Cartman
I don't think it was sealed, so not oil filled
Cartman is offline   Reply With Quote
Old 04-28-2016, 04:39 PM   #1433
JayL's Avatar
Oil coated
They are out of stock, so I can't get one yet
http://www.fenixracingshop.com/index...product&cid=20
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 04-28-2016, 05:11 PM   #1434
nova2015's Avatar
looks like the spur gear is integral to the diff housing, which will likely limit the selection of gears..
Old 05-02-2016, 05:56 AM   #1435
sbd
Looks very similar to the old HPI F10 gear diff. I personally didnt liked it as it is sensitive to rear side impacts as the inwards axial force was taken purely by the planet gears.... And you would be limited to only Fenix specific spurs...
Old 05-02-2016, 06:55 PM   #1436
nova2015's Avatar
I wonder how a diff from a HPI F10 would go, got a complete one in the spares box at home..
Old 05-03-2016, 03:50 PM   #1437
nova2015's Avatar
On another note, has anyone tried the Sweep F1 tyres?
Old 05-03-2016, 04:49 PM   #1438
Trader Rating: 28 (100%+)
On carpet? No. On Asphalt? Yes. I ran the v2's. Pretty good. About .1-.2 slower then Pit Shimizu 71/72 combo I like. I would compare them to Rides v1. Don't get squirmy like Pits can get when overheated. Just my observation for outdoors.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-07-2016, 07:49 AM   #1439
spencehotbodies's Avatar
Default Xray x1 2016 for sale
Hello
Any body in the market for x1 2016?
spencehotbodies is offline   Reply With Quote
Old 05-07-2016, 11:32 AM   #1440
j.d.roost's Avatar
I have tried the sweep tires indoors as well have some of my Co racers. They worked "ok" but honestly not as grippy and consistent as the pit/tcs/crc.
Hope that helps.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
