Like Tree34Likes
Old 02-18-2016, 02:26 PM   #1381
Trader Rating: 22 (100%+)
Originally Posted by matrix101 View Post
Can I ask where you sourced this sheet from? Been through the manual for my '15 X1 and it does not have this sheet.
Its not in the manual. Its from the X1 Facebook group. Lots of info there including Jan's recent setups. He also answers questions regularly there.
littleZEN is offline   Reply With Quote
Old 02-27-2016, 10:16 PM   #1382
Nuno Gancho's Avatar
Hi, so far which body works best at xray x16, what have you tested?
Front and rear wing use original or ETS wings best
Thanks.
Nuno Gancho is offline   Reply With Quote
Old 02-28-2016, 01:57 PM   #1383
Can anyone suggest a starting gear ratio for a 13.5 1s setup for a short indoor carpet track?
simple is offline   Reply With Quote
Old 02-29-2016, 02:50 PM   #1384
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Be careful of that X1 setup attachment. There are inconsistencies and vagueness in some of the explanations. I would not follow it too closely. There are other 1/12th setup guides that are more accurate in their explanation.
Dan is offline   Reply With Quote
Old 02-29-2016, 07:37 PM   #1385
MaxSp97's Avatar
Here is the link.
http://site.petitrc.com/reglages/xra...6_SetupHelper/
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 03-08-2016, 11:34 AM   #1386
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
Could you be more specific?
"If you no longer go for a gap that exists, you're no longer a racing driver"
Ayrton Senna
Acid_CZ is offline   Reply With Quote
Old 03-09-2016, 10:01 AM   #1387
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Do all the protoform f1 bodies fit the 2015 or 2016 X1?
Which body should I get for asphalt tracks?
lagcisco is offline   Reply With Quote
Old 03-09-2016, 10:31 AM   #1388
JayL's Avatar
2016 Xray body is the best body, fits well and handles well. Also, since the driver is molded in it lowers the center of gravity and makes the car lighter.
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 03-09-2016, 11:43 AM   #1389
It is however, in my humble opinion, the worst looking body. Mon-Tech, Protoform, WRC and TRG bodies: they all have good looking bodies that fit just fine on the X1 and don't have moulded in driver heads, which I personally like 10x better because it gives a more realistic look.
(and yes, all protoform bodies fit on the X1, but the Fifteen needs quite a bit of cutting at the rear to make it fit)
Thaan is offline   Reply With Quote
Old 03-10-2016, 03:17 PM   #1390
nova2015's Avatar
I've seen a couple of cars using these beautifully moulded rear diffusers in F1.
Has anyone tried one, was there are discernable difference? If so, where do you find them?
nova2015 is offline   Reply With Quote
Old 03-10-2016, 08:24 PM   #1391
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
2015 X1 owner
It is necessary to have the flowing steering on your 2015 ?
it is worth the time to converter to one or two damper tube shock?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 03-11-2016, 05:21 AM   #1392
SMcD's Avatar
Trader Rating: 61 (100%+)
^ I have the same question ^
Will be racing outdoor asphalt.
Anyone?
We Shall See
The Track Raceway, RCRNV, JMR
Team Jacobs Racing
YouTube: looking for turtles entertainment
B6D, X-1 2016, T4 2014 VTA, SCX-10 II
SMcD is offline   Reply With Quote
Old 03-11-2016, 09:16 AM   #1393
JayL's Avatar
Steering: not unless you have a very bumpy track
dual rear dampers: imo yes, more rear grip , more consistent, last longer between needing re-lube
A sinlge rear damper tube replacing the shock is also good , but not as good imo
That said, before he posts: I have been beat by a car with a single damper tube well 'outqualified' I should say hehe
Old 03-11-2016, 06:37 PM   #1394
Trader Rating: 28 (100%+)
I am running a 16 JayL. Now Jaime has beat you with a 15😜
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 03-11-2016, 07:09 PM   #1395
Dan
Dan's Avatar
Unless he means me, then I have outqualified Jay....ok, only once.
