Like Tree34Likes
Old 02-10-2016, 09:20 PM   #1366
evochick's Avatar
Originally Posted by ta04evah View Post
Just finished changing mine to the Tamiya tube.
I used 3 Racing ball cups, & ball studs which sit at the same height as the Xray ones, (Xray had spaces under ball studs).
Will see how the car performs at my track tomorrow night.
The new TRG roll damper looks good for not letting grease out.
http://www.redrc.net/2016/02/trg114-...n/#more-108103
You will be happy to know Rob I have fixed my poor initial braking issue, someone had an incorrect setting on her radio... oops... (not that I am running F1 on Friday at this stage)
UnRetired
evochick is offline   Reply With Quote
Old 02-11-2016, 01:45 AM   #1367
ta04evah's Avatar
Awwwww, now who am I going to chase on Friday night
That's a neat looking damper tube. I used 50K oil in the tube and it still feels like there's not much resistance, may have to go higher?
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 02-11-2016, 06:23 AM   #1368
Ph3nyx's Avatar
50K you may feel some resistance ! maybe you didn't fill the tube properly ?
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 02-11-2016, 07:04 AM   #1369
Skiddins's Avatar
When the tubes are mounted in the car you won't feel much resistance.
When they're in your hands you should definitely feel the resistance.
I managed to run one of my ETS qualifiers accidentally with both damper tubes detached (Lol, don't ask) and it didn't make the biggest difference, although it did makew the car want to 'wander', along the straights in particular.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-11-2016, 09:31 AM   #1370
On the damper tubes, we typically use diff grease. From 5k all the way up to 50k. The thickness depends on the mounting of the tube (car type) and the amount of resistance desired.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 02-13-2016, 01:13 AM   #1371
ta04evah's Avatar
Well I raced the car with the damper tube, and at first it didn't feel much different than the shock, but when the track gripped up it did feel more stable than it did with the shock, if anything a little too stable, and not as responsive, as it used to be, maybe too thick of oil?
Will try again with thinner oil next week, and see how it goes.
Old 02-13-2016, 01:15 AM   #1372
xrayracer1's Avatar
Hey Rob what damper tube are you using?
Gavin.
Converting nitro to electric is utter blasphemy.
xrayracer1 is offline   Reply With Quote
Old 02-13-2016, 01:46 AM   #1373
ta04evah's Avatar
Using a Tamiya one.
http://www.rcmart.com/tamiya-aluminu...h=595_744_1528
Old 02-14-2016, 05:39 AM   #1374
How do you guys tune these cars. I'm so used to touring cars. What is the benefit of stiff side springs. What is the benefit of a stiff or softer main shock absorber
illmatic94 is offline   Reply With Quote
Old 02-14-2016, 07:53 AM   #1375
Default Setup helper
See attachment.
astgerma52sp is offline   Reply With Quote
Old 02-14-2016, 09:13 AM   #1376
Originally Posted by astgerma52sp View Post
See attachment.
What is the side damper ?!
Old 02-14-2016, 09:17 AM   #1377
They might be referring to the side shock or tubes. Just my guess.
Old 02-14-2016, 08:34 PM   #1378
Regional Moderator
disaster999's Avatar
The '15 comes with a shock damper where as the '16 comes with 2 damper tubes for the rear pod damping. Pretty much the same concept for tuning as described in the attachment.
disaster999 is offline   Reply With Quote
Old 02-16-2016, 06:44 AM   #1379
BardSmith's Avatar
Trader Rating: 61 (98%+)
I just listed a 2016 for sale.
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 02-18-2016, 12:28 PM   #1380
Trader Rating: 43 (100%+)
See attachment.
Can I ask where you sourced this sheet from? Been through the manual for my '15 X1 and it does not have this sheet.
matrix101 is offline   Reply With Quote
