Like Tree47Likes
Old 01-11-2016, 11:55 AM   #1351
Originally Posted by PHI2 View Post
Hey guys. I justgot the new front moulded wing(ets) for my x1. What size bolts did you use to mount it?
I have the ETS approved adjustable front aero wing (XRay part #371202) if that's the one you're referring to. I haven't mounted it yet but reckon M4x20 countersunk screws will be needed.
atg849 is offline   Reply With Quote
Old 01-13-2016, 01:22 AM   #1352
That's it thanks
XRAY T14
www.wingsoverthedowns.com.au
PHI2 is offline   Reply With Quote
Old 01-17-2016, 03:25 AM   #1353
acutts's Avatar
Guys building a X-ray X1 16 for low grip outdoor racing and was wondering if the 2mm optional chassis would be a better starting point than the kit 2.5?
Also do you seal only the chassis with CA glue or is it worth doing the upper deck parts and suspension arms as well?
acutts is offline   Reply With Quote
Old 01-17-2016, 08:38 AM   #1354
Trader Rating: 28 (100%+)
Yes it will help especially if the track in not sprayed/prepped with a traction additive, but I don't think it's necessary. You can make the stock chassis work under the same conditions.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 02-07-2016, 07:30 AM   #1355
Toyota Tom's Avatar
Default No body in the x1 2016
Just picked up a Xray x1 16. No body was in the kit. Is there supposed to be?
SoCal
P12/17
M-07
Toyota Tom is offline   Reply With Quote
Old 02-07-2016, 07:47 AM   #1356
F N CUDA's Avatar
Trader Rating: 31 (100%+)
separate from kit box, mine was shipped in a big box, chassis in kit box and body just bubble wrapped.
I posted the same thing, "where's my body?" then I checked the shipping box.
BTW, I'm a Toyota guy too, I wrench their forklifts as a road tech.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 02-07-2016, 09:04 AM   #1357
Toyota Tom's Avatar
bought mine yesterday from Sean at TQ. I'll have to ask him about the body.
I was bugging you at the last winter series race about your set up. Been a 1/12
scale racer forever (almost). One more question, what caster do you run at TQ?
Tom
SoCal
P12/17
M-07
Old 02-07-2016, 01:07 PM   #1358
F N CUDA's Avatar
I think I'm at 3* caster, if not it's 6*
Craig Hammon
Old 02-07-2016, 02:12 PM   #1359
theflyingrc's Avatar
Trader Rating: 36 (100%+)
Congratulations to Jan Ratheisky (Xray X1) for winning the 2nd round ETS F1 in Germany .... Hands up!!!
theflyingrc is offline   Reply With Quote
Old 02-10-2016, 06:13 PM   #1360
RoyB's Avatar
Trader Rating: 16 (100%+)
I have a 15 X1 with Tamiya tube. Would there be any benefit to add the new braces and using 2 Tamiya tubes?
RoyB is offline   Reply With Quote
Old 02-10-2016, 07:18 PM   #1361
ta04evah's Avatar
I've been reading that some people have been replacing the small side shock in the X1 '15 with a Tamiya damper tube.
The small Xray shock is one of the easiest shocks I have ever built, and can usually change the oil in the shock in around 10-15 minutes, and have no air bubbles.
Is there an advantage changing to a a damper tube, and what are the advantages?
I use a Tamiya damper tube on a F113, because the small shock in that was difficult to build without getting air bubbles, and leaked oil no matter what I done to it.
The track I race on is a low grip "painted asphalt" surface, and we use Shimizu soft's front & rear.
If I changed to a damper tube, what weight oil would be good to start with? I use 350cst oil in the small shock atm.
Cheers
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 02-10-2016, 07:31 PM   #1362
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
Takes me only 2-3 minutes to switch to different grease on my Tamiya tube. If you can build the shock consistently all the time, then more power to you.
I just feel the damper tube is a lot easier to be more consistent and quicker to change settings. I use the Tamiya soft and medium damper grease. Rarely will I use the hard grease.
Dan is offline   Reply With Quote
Old 02-10-2016, 07:39 PM   #1363
ta04evah's Avatar
Thanks for your reply, and yes the tube is quicker to change grease/oil.
I just follow the instructions in the manual for the small shock, and 99% of the time it works, but it can get messy with the excess oil coming out.
Cheers
Old 02-10-2016, 08:44 PM   #1364
The guy winning at your track Roy has one tamiya tube.
Team I'm Over It
Old 02-10-2016, 09:09 PM   #1365
ta04evah's Avatar
Just finished changing mine to the Tamiya tube.
I used 3 Racing ball cups, & ball studs which sit at the same height as the Xray ones, (Xray had spaces under ball studs).
Will see how the car performs at my track tomorrow night.
