Like Tree34Likes
Old 12-17-2015, 05:06 AM   #1291
I will be running a killshot rpm 21.5 in blinky mode. Thanks for the help.
Texas.john is offline   Reply With Quote
Old 12-18-2015, 01:00 AM   #1292
xevias's Avatar
Follow Dan's advice. I'm at 2.75 on a huge carpet track with a Motiv 21.5. Blinky. No fan.
Had it full throttle for about 20% of the lap aside from the straight.
xevias is offline   Reply With Quote
Old 12-18-2015, 04:48 AM   #1293
sbd
At ETS with hobbywing 21,5 motor and blinky, the winner run as high as 39 pinion which is 2.46 with the new Ride XR tires. Last year the max was 2.55 with the R1 tire which are larger a bit.
sbd is offline   Reply With Quote
Old 12-18-2015, 06:43 AM   #1294
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
That is with a fixed timing motor. Plus on the huge Hudy arena track, they were running as high as 2.2. XR tires are also smaller in diameter than pit tires too so I usually gear it a tooth or two higher.
My 2.7-3.0 recommendation is primarily for adjustable timing motors.
Dan is offline   Reply With Quote
Old 12-18-2015, 09:04 PM   #1295
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Is anyone's is using the alum bottom chassis and rear pod for carpet?
or it is unnecessary hop up?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 12-18-2015, 09:52 PM   #1296
Dan
Dan's Avatar
X-Ray driver Jan ran it on the latest ETS race and won. His car looked a bit loose though.
I lost a slight bit of grip and steering when swapping from carbon to aluminum. The car felt more consistent though and after a few setup changes, I was almost as fast as my carbon car. I will tell you this though, it is nice having all that weight down low. While other F1 cars were traction rolling that day, I didn't have that problem at all. I'm still working on the setup to regain some speed.
Old 12-18-2015, 11:15 PM   #1297
OVA
OVA's Avatar
would it been better if you just softer the side springs, Not sure ,But will it help the from traction rolling?
Old 12-19-2015, 08:31 AM   #1298
Has anyone tried out the sweep v2 tires on carpet? If so what compounds are you running on the front and back? I'm looking at getting some that are preglued because I hate glueing tires. Are there any other f1 tires that come preglued?
Old 12-19-2015, 02:06 PM   #1299
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Anyone looking for 2016 X1 kits I have a couple left!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 12-19-2015, 02:42 PM   #1300
sbd
Yes, fixed timing. Do you know what the fix of the Hobbywing is. I am guessing 27,5 degrees but I am not sure. With variable timing motor what endbell timing you would suggest to run with 2.7 ratio?
Old 12-19-2015, 09:47 PM   #1301
Dan
Dan's Avatar
I can't suggest a specific timing degree since all motors are a little different.
Old 12-20-2015, 08:36 PM   #1302
xray2050's Avatar
Trader Rating: 14 (100%+)
Super soft rears and medium fronts on a medium to high bite carpet.
Tires seem to be very good. Could even go to a hard front.
Pete Elphinstone
RC America, HUDY, XRAY, JACO, Performance Hobbies, WERKS RACING, www.speedzoneusa.com, Sweep Racing USA
xray2050 is offline   Reply With Quote
Old 12-20-2015, 09:12 PM   #1303
xevias's Avatar
Same here. My aluminum chassis felt great at the Masters race in Shenzhen. Pit tires on some weird non-CRC carpet. I popped in softer front springs and it had plenty of steering. Testing on ETS carpet next week.
I've tested them on the older CRC carpet and found the Med-Front + Soft-Rear are balanced like the Pit 571/572 combo. I will test the Super Soft-rears on our new ETS carpet soon. I could see Hard-fronts working on some cars. I doubt you will see people running anything other than soft or super soft rears.
I just ordered a set of pre-glued Pit 571/572 from The Boarder.com. They are mounted on Tuning Haus wheels.
I've got my Motiv 21.5 and R1 21.5 set to lower-mid 40 degrees as measured on an analyzer. These two motors really don't have a "sweet spot" so you can up the timing to whatever amp draw (heat+battery capacity) you're willing to accept.
Old 12-27-2015, 05:10 PM   #1304
Trader Rating: 114 (100%+)
I need to run CRC F1 tires here.. are these Wheels correct for the X1 2016? Concerned about offset.
Rear:
http://www.tqrcracing.com/shop/produ....asp?p_id=7485
Front:
http://www.tqrcracing.com/shop/produ....asp?p_id=7481
Chris Furman is offline   Reply With Quote
Old 12-27-2015, 05:50 PM   #1305
Dan
Dan's Avatar
Yes, but you'll want the Tamiya versions, they are of much higher quality.
