Like Tree43Likes
Old 12-03-2015, 12:21 PM   #1276
nova2015's Avatar
Has anyone tried the new Ride XR tyres yet? Curious to get some people's thoughts.
nova2015 is offline   Reply With Quote
Old 12-03-2015, 02:05 PM   #1277
Send a message via ICQ to Cartman
First experience poor plastic, ripped the centre out of a rear on a light tap.
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 12-04-2015, 02:18 AM   #1278
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
Seen that during our last race. Friend reported yet another case...
"If you no longer go for a gap that exists, you're no longer a racing driver"
Ayrton Senna
Acid_CZ is offline   Reply With Quote
Old 12-13-2015, 06:53 AM   #1279
rack's Avatar
Trader Rating: 64 (100%+)
Has any body looked into what parts it would take to upgrade our car to 2016 specs.
rack is offline   Reply With Quote
Old 12-13-2015, 10:38 AM   #1280
Trader Rating: 32 (100%+)
Send a message via AIM to JDCrow Send a message via Skype™ to JDCrow
373512-K X1 COMPOSITE ADJUSTABLE REAR WING - BLACK
379701 XRAY X1'16 1/10 FORMULA BODY
376230 X1'16 Servo Holder
375258-o X1'16 Alu Servo Mount
371075 X1'16 Rear Brace
371093 X1'16 Plate for mounts
373548 X1'16 Rear Pod Upper Plate
378141 X1 Side Linkage Tube (2)
378153 Composite Linkage Shaft (2)
372650 Ball End 4.2mm
296540-o Alum Nut M3 (4)
JDCrow is offline   Reply With Quote
Old 12-13-2015, 01:56 PM   #1281
rack's Avatar
Thank you
Old 12-13-2015, 04:58 PM   #1282
Default Strip spur
Xray X1 - Formula One Car-image.jpgJust got the X1 and I kept stripping the spur gear. It actually happened twice less then one minute into a run. I tried resetting the gear mash several times and did it correctly with very slight play I also made sure the mortor screws were done in tightly. I Click image for larger version
ID:	1334868can't seem to figure out why this is happening. Also check the pod to make sure all the screws were done tightly. It seems when I try to tighten the motor screws the motor itself keeps moving back towards the spur gear and won't stay in place. I also have to hold the motor in place as I screw it in an order set my pinion to spur gear mesh.
astgerma52sp is offline   Reply With Quote
Old 12-13-2015, 05:02 PM   #1283
Strange, this normally only happens when you blow a bearing.
DavidNERODease is offline   Reply With Quote
Old 12-13-2015, 05:31 PM   #1284
NutDriver's Avatar
Trader Rating: 15 (100%+)
It was on an Exotek F1R2, but the plastic bearing carrier didn't fit tightly in the aluminum block and that caused mine to strip as you described. As David described, check the bearing as well for slop. I would also consider putting a washer on the screw before you put it through the block to see if that would stop the "walking" as you tighten the motor screw.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 12-13-2015, 07:12 PM   #1285
Default Strip spur
Thanks for the feedback. I plan on going through the entire car and will check all the bearings to make sure that's not the problem. Will also add shims between the screws to help the motor from moving.
Old 12-14-2015, 12:51 AM   #1286
xevias's Avatar
The blown bearing could also be inside the diff housing.
xevias is offline   Reply With Quote
Old 12-15-2015, 09:23 AM   #1287
JayL's Avatar
maybe your axle is moving side to side, as well
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 12-15-2015, 09:35 AM   #1288
RobS's Avatar
Motor screws too long? I've had instances similar to whats being described and it was because the motor screws we just long enough to feel tight, but still allow the motor to move with some force.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 12-16-2015, 07:21 PM   #1289
Just got my new X1 and am looking to see what would be a good pinion to start at? Any suggestions? I run on a carpet track that is fast and flows very well.
Texas.john is offline   Reply With Quote
Old 12-16-2015, 09:30 PM   #1290
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
What motor? If blinky 21.5, 2.7-3.0 ratio is a good start depending on motor and track size. Pinion size 32-35T 64P
Dan is offline   Reply With Quote
