Like Tree34Likes
Old 11-25-2015, 09:17 AM   #1261
mbykerman's Avatar
Trader Rating: 45 (100%+)
Default Option parts
Does anyone know where I can get the aluminum option bushings for the X1 and the front aluminum body mount plate? I have looked all over and no one in the states seems to have them. Thanks
mbykerman is offline   Reply With Quote
Old 11-25-2015, 11:14 AM   #1262
robk's Avatar
Trader Rating: 22 (100%+)
aluminum bushings...not xray though
http://shop.rochercusa.com/index.php...product_id=173
Old 11-25-2015, 11:32 AM   #1263
JayL's Avatar
I'm thinking he means the camber caster ones... ?
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 11-28-2015, 06:44 PM   #1264
NutDriver's Avatar
Trader Rating: 15 (100%+)
I have an X1 2015 that I've recently begun racing after campaigning Tamiya cars. I'm wondering if I missed installing a part during construction. I seem to have more droop in the rear pod than I should. With the front, middle, and rear ride heights at 5mm, I can raise the chassis at the main chassis/rear pod junction to nearly 8mm ride height. While this is great for putting power down, it's not to great on the on-power steering. Did I miss a shim that should be inside the shock? I've put more preload on the spring collar for the rear shock and this has improved the balance, but I'm not sure that this is the correct answer.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 11-28-2015, 09:59 PM   #1265
Skiddins's Avatar
First things first, have you definitely got the centre piece of carbon the correct way around? I have had to wind my rod end off my shock rod slightly, so about 1mm of thread is showing to get what I needed.
Can you take a pic?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-30-2015, 12:48 PM   #1266
I didn't see anything in the spec sheet but just wanted to confirm...the wheelbase of the x1 is not adjustable correct?
littleZEN is offline   Reply With Quote
Old 11-30-2015, 01:13 PM   #1267
NutDriver's Avatar
No, the wheelbase is not adjustable.
USVTA member #111
Old 11-30-2015, 04:35 PM   #1268
nova2015's Avatar
I have just started running my X1 (2015), and have noticed occasionally abrupt power-on oversteer. Corner entry and mid corner the car feels solid, however it steps out aggresively under throttle on corner exit. Car is currently in stadard trim, running Ride R1 premounts.
I'm thinking reducing rear ride height will help, but don't want to compromise the corner entry and mid corner too much. Suggestions?
nova2015 is offline   Reply With Quote
Old 11-30-2015, 04:46 PM   #1269
Skiddins's Avatar
Try loosening the diff slightly and double check the side springs are set properly
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 11-30-2015, 05:14 PM   #1270
nova2015's Avatar
OK, I will give that a try. Regarding the side springs, are they adjusted via the 1.5mm grub screws or via the plastic spring retainers?
Old 12-01-2015, 02:10 AM   #1271
Skiddins's Avatar
The plastic retainers should be fully wound onto the grub screw, you then adjust the springs using a 1.5mm driver from above
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 12-01-2015, 12:15 PM   #1272
wwddww34's Avatar
Trader Rating: 9 (91%+)
New adjustable Xray wings for the X1.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 12-01-2015, 01:14 PM   #1273
RonF's Avatar
The F104 stock rear wing already has this...
VBR,
Ron
F104pro, Turnigy Turbo 80amp, 21.5 trackstar, LRP esc and Rs 540
RC10 original, RC10 graphite, RC10 4wd MIP SP1 version, RC10T
RonF is offline   Reply With Quote
Old 12-01-2015, 04:24 PM   #1274
eR1c's Avatar
AWESOME!
eR1c is offline   Reply With Quote
Old 12-03-2015, 06:11 AM   #1275
Send a message via ICQ to Cartman
Default Something i wrote for a UK magazine
http://site.petitrc.com/reglages/xra...topher_Review/
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DirkW
