Like Tree43Likes
Old 11-10-2015, 01:37 PM   #1231
Here's a picture of the new XRAY ETS approved wing 371202 on my X1 2016 Specs:
Here's the car itself:
Thaan is offline   Reply With Quote
Old 11-10-2015, 02:33 PM   #1232
DirkW's Avatar
Xray ETS approved wing? According to the ETS rules page for 2015/2016 only the Montec and these Serpent wings are legal...?
Mon-tech:
Front Wing Black #015-006
Front Wing White #015-009
Rear Wing Black #015-007
Rear Wing White #015-008
Serpent:
Front Wing Black #411352
Front Wing White #411353
Rear Wing Black #411369
Rear Wing White #411370
Dirk
Current cars: Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): (Xray T4'18) | Xray X1'17(8) | Yokomo YZ-2 DTM | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 11-10-2015, 03:00 PM   #1233
JayL's Avatar
it is a repackaged montech
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 11-11-2015, 03:23 AM   #1234
Skiddins's Avatar
Have you run it yet, and what does the floating steering do on carpet, or have you attached the servo to the chassis?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-13-2015, 11:07 PM   #1235
millbank's Avatar
Hi
Right I'm struggling with the rear of the car cocking a wheel through the bends causing the car to sound like the diff is slipping. Car is pretty planted but could be quicker if I wasn't losing traction from the rear lifting.
Any help would be appreciated
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 11-14-2015, 02:32 AM   #1236
spencehotbodies's Avatar
Originally Posted by millbank View Post
Hi
Hello
For the 15?
Destiny RX-10s - Xray X1- Spec-r- nosram -Trinity-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 11-14-2015, 04:33 AM   #1237
Skiddins's Avatar
New Montech, ETS wings fitted;
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-14-2015, 07:33 AM   #1238
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Hi
A fast guy taught me how to play with the side sorings on my carpet car.
Start with medium stiffness spring just touching with car sitting at ride height then screw them down 2 turns preload.
Drive car, rear wheel lifting? Too stiff, back off spring preload 1 turn.
Still lifting? go to lighter spring and start again, 2 turns preload etc.
If/when front wheels lifting, side springs too light, go back the other way.
So basically, turning the preload no more than 2 turns up or down tells me when to go to a different spring
This worked well for me
Now when it grip rolls it's both wheels lifting at the same time.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 11-16-2015, 11:12 AM   #1239
millbank's Avatar
Old 11-16-2015, 12:02 PM   #1240
Trader Rating: 28 (100%+)
Anyone have some insight on the comparison of the original x1 and the 2016 on track?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 11-16-2015, 03:21 PM   #1241
sbd
First said, I am not the best driver ever.
I have the feeling the new car is smoother. Out of the box with standard setup it easy to drive, but the original one was also. Seems the side tubes provide better feel lacking snaps. There is no tweak and due to the machined piece superseding the two front end rear upper plate studs, it is harder to through the front out of alignment on smaller crashes. The rear axle provides the same excellent action as the original one. Of course, some of the feel may have been given by the newly assembled kit as my old one, although maintained, has been raced weekly for 10 months.
All in all, with the touches it got, it is a better car than the original.
sbd is offline   Reply With Quote
Old 11-16-2015, 04:55 PM   #1242
Nice. This is the typr of feedback I was looking for.
Team I'm Over It
Old 11-17-2015, 09:16 PM   #1243
ta04evah's Avatar
Thanks for this tip, I actually thought it was the other way around, tightening the side springs to prevent the wheel lifting. Will try this technique this weekend to see how it goes.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 11-17-2015, 09:45 PM   #1244
xevias's Avatar
How does the tube damper oil thickness change (or does it) when using this spring tuning method?
xevias is offline   Reply With Quote
Old 11-18-2015, 10:09 PM   #1245
F N CUDA's Avatar
I gotta mention that this carpet track is high to higher grip, traction roll city.
On lower grip, could all be different. Just telling what worked for my car.
I haven't touched the kit setup fluids, shock or side damper
Craig Hammon
