Old 12-08-2014, 02:28 PM   #106
it is a Montech F13 body
Rally-game proto Clo-products - Toro 150a - HW 2250kv - Turnigy a-spec - Futaba 3PKS
Tamiya M03S mini cooper - Novak 410M1C - Orion Core 27x1
Kyosho Mini-Z MR03 and MA015
Xray T4-2014 - Hobbywing V3.1 - LRP X20 spec 10.5 - Turnigy ultimate
Xray X12-2014 - Reedy Mach2 6.0
christophed83 is offline   Reply With Quote
Old 12-08-2014, 02:44 PM   #107
fox88gt's Avatar
Originally Posted by RCBuddha View Post
I'm guessing it will be over 300. But it will be "Luxurious" and "Optimized".
I'd be suprised if MSRP is below $400 to be honest. This is Xray after all. I love Xray touring cars but this one is gonna have to be a "game changer" for me to go away from Tamiya F1 cars.
"When you no longer go for a gap, you are no longer a racing driver..." Ayrton Senna
"I dont like being overtaken. It's a sign of weakness." Jeremy Clarkson
"Leave me alone....I know what I'm doing." Kimi Raikkonen
I don't always race RC....but when I do....I prefer road course.
fox88gt is offline   Reply With Quote
Old 12-08-2014, 02:54 PM   #108
mtveten's Avatar
Trader Rating: 27 (100%+)
The car pictured either has the battery inline like nearly every other car or has been the battery near the middle of the chassis giving a similar weight distribution to the other link cars on the market. A 103 style rear battery across the chassis would not fit under that shell.
Although I never found a single bellcrank steering setup to be an advantage It did make Ackerman adjustments easier. The only downside i found was that I had to add a fair amount of weight over the front end to smooth the car out over bumps that wasn't needed with the servo in the normal position.
mtveten is offline   Reply With Quote
Old 12-08-2014, 05:19 PM   #109
wwddww34's Avatar
Trader Rating: 9 (91%+)
I believe that Martin Hudy designed the X1 to use a shorty Lipo battery across the back between the 2 side links.
If I recall, the Tamiya F103 held a 6-cell NiMH stick pack across its back, just under the solo shock and big damper disks (like the one in the pic below).
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 12-08-2014, 07:28 PM   #110
mtveten's Avatar
i have a 103 i run with a shorty pack but that body looks narrower in the rear than a shorty pack is long.
Old 12-08-2014, 09:03 PM   #111
wwddww34's Avatar
This picture of Francesco Martini's X1 prototype is a little fuzzy, but it shows how the shorty pack Lipo battery is situated in the car.
Old 12-08-2014, 10:27 PM   #112
mtveten's Avatar
The prototype pictured clearly shows the battery is wider than the pod but the curvature of body pictured is narrow than the pod. The setup under the body is not the same as the prototype shown. Its possible the production cars configuration allows for a transverse battery that fits some bodies and inline that fits all. The only thing we can be sure of is that the 2 cars pictured are not using the same configuration, the body posts are even in a different location.
Old 12-08-2014, 11:22 PM   #113
Mark, isn't that wide black section part of the body?
-Mike
Old 12-09-2014, 12:24 AM   #114
mtveten's Avatar
-Mike
yep, if you watch the video you can see the links under it, its just not large enough to accommodate a battery underneath. its hard to tell in that photo but side view photos of the car show that its a little less than 1/2 the height of the side pod and just over .5"" long or at its highest point so it would need a battery no taller or wider than .75". a regular short pack is approximately 1" tall and 1.7" wide.
Mounting the battery across requires a shell without a skinny and/or low profile rear end. Most of the older 90s era bodies work fine. I use jordan 191 and tyrell 019 bodies for that configuration.
Old 12-09-2014, 08:35 AM   #115
CBear3's Avatar
I'd side with mtveten, doesn't look like a shorty 2c could fit there, although the transition from the white to flat black area doesn't look as severe in the XRay picture. There just looks like too many compound cruves to flare that with a heat gun though.
CBear3 is offline   Reply With Quote
Old 12-09-2014, 09:44 PM   #116
wwddww34's Avatar
Here's a pic of a nice red X1 geting ready to race at ETS round 1 in Hrotovice.
Old 12-09-2014, 09:56 PM   #117
RCBuddha's Avatar
Trader Rating: 33 (100%+)
So Tamiya bodies will not fit at all?
RCBuddha is offline   Reply With Quote
Old 12-09-2014, 10:02 PM   #118
The bodies above are so ugly! I use a f109 body on my f103 with shorty pack across the car. Should easily fit the xray at a guess
ixlr8nz is offline   Reply With Quote
Old 12-10-2014, 01:38 AM   #119
You couldn't be more wrong.
That in fact is a Yokomo YF001 driven by a friend of mine at the ETS finals in Trencin / Slovakia.
Why Xray is using this as a title picture is beyond me
MarkusW is offline   Reply With Quote
Old 12-10-2014, 02:08 AM   #120
The F104 Pro body should fit, as long as you don't use the undercut side pods.
terry.sc is offline   Reply With Quote
