Like Tree34Likes
Old 10-26-2015, 08:37 AM   #1171
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Not unless Xray makes new pod plates that allow the rear wing brace to be mounted (Top Rebel F1 style).
Dan is offline   Reply With Quote
Old 10-26-2015, 09:25 AM   #1172
corally's Avatar
Originally Posted by Skiddins View Post
Yes, they seem quite good, better than the old Ride tyres.
On carpet?...some indication how modify setup ?
....at now on from first race on italy ...seem no good respect old one...
corally is offline   Reply With Quote
Old 10-26-2015, 11:07 AM   #1173
yumlailai's Avatar
I have a issue on the side link when i build the care. Even I unscrew all 4 screws that tighten the ball end in the side link. The rear pot will not move unless I use my hand to move it (the car is half built and I just put the rear pot)It is still not smooth. I have already
1. check if the screws are overly tighten
2. check if the middle ball end is over tighten
I removed the chassis screws for the side links and the rear pot move freely
I removed the centre screw (that link the chassis and rear plate) and the side links move freely
It feels like the when I tighten all 3 point together (side links and centre link), the rear pot will not move freely
If I just have the centre link or the side link (both sides), the rear plate will move freely
What else can I check? I am using the aluminum chassis and rear plate
Thank you
yumlailai is offline   Reply With Quote
Old 10-26-2015, 11:56 AM   #1174
sbd
Thank you
As stated in the manual, loose the center pivot screws such that the whole assembly could slide forward and backward. Then tighten the side links pivot. You can check if the pod moves freely. Last tighten the center pivot to the plate.
sbd is offline   Reply With Quote
Old 10-26-2015, 01:09 PM   #1175
Thank you
I had the same issue.. You have to leave a little bit of play in the centre pivot ball - do not fully tignten the M3x6 screws in the plastic pivot ball holder assembly. After I did that the rear end was perfect and it stayed that way.
TC(17.5) - USGT - F1(21.5) - 12th(17.5) - USGT(FWD) - VTA
--MTC1----T4'17----X1'15-------X12'17-------FF17--------TA07
DavidNERODease is offline   Reply With Quote
Old 10-27-2015, 02:53 AM   #1176
sbd
Default X1 2016
https://www.teamxray.com/teamxray/sh...83cb6b6984e3e#
First image of the new car. Should the image be indicative, the only difference which can be spotted is a new rear wing and different body...
Old 10-27-2015, 07:36 AM   #1177
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
Looks like TRG rear advanced wing, which is nice, but not very durable wing. Cool if they made it from better material, sucks if not..
"If you no longer go for a gap that exists, you're no longer a racing driver"
Ayrton Senna
Acid_CZ is offline   Reply With Quote
Old 10-27-2015, 09:13 AM   #1178
sbd
Looks to me the pot is X12'16 style. Hope I am wrong as it may be weaker than the original X1 one.
Old 10-28-2015, 09:01 AM   #1179
mes
Has anybody here fitted a TOP Racing Type 1 or similar old-school body (Serpent?) to the car with the battery across? At best it seems to be a tight fit...
mes is offline   Reply With Quote
Old 10-28-2015, 12:41 PM   #1180
Chaz955i's Avatar
Originally Posted by RC MARKET View Post
New ETS Approved Wing
Will front wing mount up without the aluminum adaptor?
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 10-28-2015, 01:41 PM   #1181
So are these new wings made by Xray? (yes I can see that they are in an Xray package - only Montech and Serpent are on the ETS list)
Old 10-28-2015, 01:45 PM   #1182
They appear to be brand labeled from Mon-Tech
Mon-Tech Racing
Front Wing Black – 015-006
Front Wing White – 015-009
Rear Wing Black – 015-007
Rear Wing White – 015-008
simple is offline   Reply With Quote
Old 10-28-2015, 01:52 PM   #1183
Mon-Tech Racing
Front Wing Black 015-006
Front Wing White 015-009
Rear Wing Black 015-007
Rear Wing White 015-008
Well they better be more durable than Serpent wings eh Simon!
Old 10-28-2015, 06:36 PM   #1184
Skiddins's Avatar
Re-packaged Montech, so Xray can sell them as well I would guess.
Avoid Serpent, they break too easily.
Others have said the Montech seem to be strong
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-29-2015, 03:18 AM   #1185
The MonTech are quite a lot better and most definitely stronger!
Thaan is offline   Reply With Quote
