Like Tree44Likes
Old 07-12-2015, 08:06 PM   #1021
wwddww34's Avatar
Trader Rating: 9 (91%+)
Originally Posted by team_tamale View Post
How many of you would be interested in a Team Tamale aluminum chassis and lower pod plate for the X1? Just trying to gauge the interest to decide if this would be worth pursuing.
Hey Larry, I am definitely interested. I will see you at DMS next Saturday.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 07-13-2015, 01:38 AM   #1022
Originally Posted by luda View Post
Hi Jay,
The bladder I received was so large it did not fit inside the shock and the shock was unbuildable. I am not sure what issue you are talking about before but the bladder I received was completely wrong for the shock body. I would expect that the bladder provided would actually fit in the shock body as standard issue. This was my problem. Xray authorised the replacement. It was just never shipped. So regardless of what the issue was the slackness of HEI meant that I never received what even Xray themselves thought I should.
Which was my entire point. No problem with Xray. My problem is with HEI who are the distributor in Aus.
HEI is doing a great job in service and customer support, unfortunately this issue got missed. However once the request has been re-send, HEI promptly responded and is sending you the replacements. We apologize once again.
XraySupport is offline   Reply With Quote
Old 07-13-2015, 08:38 AM   #1023
INFERN0's Avatar
I am looking for a gently used X1 if anyone is selling.
Proudly driving for Kyosho America, Team Maclan and RC Pitstop
INFERN0 is offline   Reply With Quote
Old 07-13-2015, 08:50 AM   #1024
JayL's Avatar
Hi Jay,
Gotcha. Glad it got replaced. The early kits had a different bladder than the later kits, wanted to be sure you knew about this, same kit possible to get two different bladders
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 07-13-2015, 02:32 PM   #1025
eR1c's Avatar
raced my X1 for the first time this past weekend. This was my first F1 race (have raced other classes for several years). But first time w/ an F1 and certainly a first w/ the X1. We only ran 1 main, had about 8 entrants ...I actually ended 5th out of 8ish ...for my first attempt at F1 I felt that was a good result. Was very pleased w/ my car, I don't have other F1's to compare it to, but it felt good. Errors were all on my part and lack of experience finessing the X1. But love my new wheels!
One complaint/wish I didn't do:
I purchased an Exotek heat sink for the motor ...waste of $20. Everytime you slightly nudge a wall the heat sink dislodges and rubs against the rear axle making a horrible sound. I yanked it off during warm-ups and never looked back. Anyone want to buy my Exotek heatsink? It's really nice? --JK.
eR1c is offline   Reply With Quote
Old 07-13-2015, 02:44 PM   #1026
Trader Rating: 27 (100%+)
[QUOTE=eR1c;14093365]raced my X1 for the first time this past weekend. This was my first F1 race (have raced other classes for several years). But first time w/ an F1 and certainly a first w/ the X1. We only ran 1 main, had about 8 entrants ...I actually ended 5th out of 8ish ...for my first attempt at F1 I felt that was a good result. Was very pleased w/ my car, I don't have other F1's to compare it to, but it felt good. Errors were all on my part and lack of experience finessing the X1. But love my new wheels!
Did you race on carpet or asphalt?
Awesomatix-Vbc-Hudy-Orca-motiv-Tsr-
pat5b is online now   Reply With Quote
Old 07-13-2015, 03:09 PM   #1027
eR1c's Avatar
asphalt, ...newly sealed, fairly high traction, warm day outside ...track was about 90degrees. The car stuck to the track nicely, ...mostly I gave it too much throttle and the rear would want to kick out ...i was able to control it and managed a decent place. Yet I literally came from racing my TC only a few minutes earlier ...where I could just throttle and point and it went... F1 takes softer/easier/smoother controlling.
Old 07-13-2015, 03:23 PM   #1028
Nice! You are so lucky to have permanent outside/asphalt track,
you run shimizu or ride tires?
mine is not already finish, and it will be a carpet setup!
Old 07-13-2015, 03:45 PM   #1029
eR1c's Avatar
shimizu tires, ...like I said, this is my first F1 car so I don't have experience w/ any other tires. The Shimizu tires were nice and sticky, really kept my car planted on the track. They are on par w/ a great set of TC tires.
I run the 771 and 772's (I think that is the correct part number ...but at work so can't look it up right now).
Old 07-13-2015, 03:57 PM   #1030
Compared to touring car how do they drive?
illmatic94 is offline   Reply With Quote
Old 07-13-2015, 04:03 PM   #1031
eR1c's Avatar
uh, not sure I follow exactly.
I am no expert, i've only started racing my X1.
Speaking of the Shimizu tires I used:
They compare to a nice set of TC tires in that they stick to the road really well and keep the X1 planted on the track, no sliding or drifting.
Speaking of the X1 and how it compares to driving a Touring Car:
Totally different driving experience. That is the nature of F1's from what I've learned. Typical TC's are 4wd, F1's are RWD. The rear of the X1 (and probably most F1's) wants to kick out if you get on the throttle too hard. Also you really have to slow down to take tight turns otherwise it will really push and you'll not make the turn. TC's can take tight turns much easier.
Again, I preface w/ this as saying I have experience racing other types of cars, but not much when it comes to the X1. I am very low/early on the X1 learning curve.
Old 07-13-2015, 05:11 PM   #1032
do you run with drag brake or A. B.S ?
Both?
Old 07-13-2015, 05:38 PM   #1033
I use this heat sink.
I put a dot of shoe-goo on the rear most tab before popping it onto the motor and it has never moved the whole season.
simple is offline   Reply With Quote
Old 07-26-2015, 01:01 PM   #1034
INFERN0's Avatar
Doesn't the shoe goo act as an insulator though? I would think you'll still get heat dissipation but the shoe goo won't be as effective as something designed to conduct heat no?
Old 07-26-2015, 02:56 PM   #1035
Of course it does, that is why I said "just a dot", only on the back edge. You only need a tiny bit to keep the heat sink from shifting. You don't need much at all to do the trick.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DavidNERODease
