Like Tree43Likes
Old 06-05-2015, 10:29 AM   #946
eR1c's Avatar
so close to getting this car running.
Got the servo and receiver yesterday, will install this week ...won't be able to race it this weekend (which was my goal) ...but that is fine, i'll get some practice in before the next race.
eR1c is offline   Reply With Quote
Old 06-05-2015, 10:31 AM   #947
eR1c's Avatar
The 9650 might be a bit small for this application. I believe that's more of a 12th scale servo. You want a low profile servo like a Futaba S9551 or KO Propo RSxone10 Response. With these cars compared to 12th scale, you are moving and trying to hold a much bigger, heavier tire.
-if you opt for the Futaba S9551 I have a code at Tower for $79, and another for $10 off, which would make it $69 and free shipping. ...PM me.
(I just got that servo ...have always had good results w/ Futaba).
Old 06-05-2015, 11:54 AM   #948
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
I like the transverse setup for both low and high traction. I tune with different front tires and minor changes to spring/alignment depending on traction. I have seen guys be incredibly fast in either battery configuration.
Dan is offline   Reply With Quote
Old 06-07-2015, 07:07 AM   #949
Thank you for the info on the servo.
I am going to run on asphalt. Im going to start with the. 571/572 combo. What offset rims should I start with?
wcrotty is offline   Reply With Quote
Old 06-08-2015, 10:45 AM   #950
wwddww34's Avatar
Trader Rating: 9 (91%+)
Here's a winning setup from Milan who won the Polish Championships Rd3.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 06-08-2015, 09:12 PM   #951
Trader Rating: 19 (100%+)
Just out of curiosity has anyone tried the 2.0mm chassis and rear pod yet?
Just been looking around and they aren't cheap!
I'm planning to use it on the medium grip asphalt setup.
Thanks.
bee200sx is offline   Reply With Quote
Old 06-09-2015, 02:11 AM   #952
all,
Just got the X1 and have never raced F1... what parts should i always have on me? How is the car's durability? Sorry about the repeat question but i can't find any answers...
thank you,
Jose'
junior1178 is offline   Reply With Quote
Old 06-09-2015, 02:27 AM   #953
I run low grip and medium grip asphalt and the kit carbon chassis is ok. I haven't run the 2mm chassis but can't see the need atm. The X1 seems to generate enough tire temp even on the cold days (australian cold) we have had so far.
As for spares I bought some but haven't needed anything yet. If you don't hit things too hard then the car will hold up well. If you hit things hard then your going to need spares In which case the plastic parts like steering knuckles, links centre chassis parts would be the most likely to break.
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 06-09-2015, 09:16 AM   #954
JayL's Avatar
spares:
steering knuckles,
side links,
and rear axle bearings
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 06-09-2015, 11:14 AM   #955
Trader Rating: 18 (100%+)
I've stripped one spur and broken two front arms. We have a sweeper at the end of the straight away and if you clip the pipe you end up flipping in to the big red wall. It was a wide ass open crash when the arms broke...
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 06-17-2015, 11:10 AM   #956
RC MARKET's Avatar
X1 New Option Parts
Xray X1 - Formula One Car-xr-371005.jpg   Xray X1 - Formula One Car-xr-371149.jpg   Xray X1 - Formula One Car-xr-376256-o.jpg
RC MARKET is offline   Reply With Quote
Old 06-17-2015, 12:06 PM   #957
eR1c's Avatar
X1 New Option Parts
yeah!
Old 06-17-2015, 01:35 PM   #958
Evo 13's Avatar
This car is incredibly durable. I was testing different braking points today at track I never drove on before and kissed the boards a few times. All she did was bounce off and kept going. I've come to really appreciate the tamiya front bumper too. lol
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 06-18-2015, 07:12 PM   #959
eR1c's Avatar
brought my X1 out to the track today for some practice and to get it dialed in.
I feel it is mostly there.
The diff' is the only thing I had to really keep adjusting. Too tight and the rear wants to swing out, too loose and you lose power ...I found a nice middle ground. I was at an indoor track, so sounds echo a bit, ...the car is super quite. Yet around corners when the diff is being spun there is a noticeable sound made. Kind of a whinning sound ...is this normal? I am used to TC which are silent (probably because the diff's are closed).
Also, taking tight turns you really have to slow down, -not like a TC. Your turn radius is reduced greatly when at higher speeds. ...just something I have to get a little used to.
Love the car though, once the tires warm up it really sticks to the ground nicely.
Old 06-18-2015, 09:13 PM   #960
Trader Rating: 28 (100%+)
eRC1,
I see you went to Delta. Was it hot in the building? Anyways, its a pancar and it will make a whirring sound from the pinion and spur but it should not be too loud. Normal. As far as corner speed,if there is a bunch of traction on that track, your car should turn very well. Sounds like a setup issue. Easily remedied. Try a bit more drag brake also. Maybe our paths will cross at the track at some point. Thanks again on the 9551 deal.
John
Team I'm Over It
racenut123 is offline   Reply With Quote
