Like Tree34Likes
Old 05-12-2015, 09:30 PM   #886
Trader Rating: 28 (100%+)
What compound is the 573 if I may ask? Softer then the 571?
Originally Posted by Rampokker View Post
Currently running Pit Shimizu 573 Front / 572 Rear on Ashphalt. Inline battery and soft front springs have got the steering to almost where I like it. Still understeers slightly for me. Other guys at my track reckon it has too much steering for them though
I have some different front/rear combinations I'll be trying next time.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-12-2015, 10:40 PM   #887
Rampokker's Avatar
No, 573 is a medium and 571 is Soft. I'm not sure why I never tried the 571 front with 572 rear, but that is one of the combinations I'll be trying next.
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
Old 05-13-2015, 01:16 AM   #888
Skiddins's Avatar
Originally Posted by Josh-n-ya View Post
Going to try running inline this weekend. Anybody else tried? Disliked or liked?
Preferred transverse (asphalt and carpet), car just seems to be slightly more agile and fewer issues with the rear trying to swing around when on power out of tighter corners.
Would appear it's a personal thing, and possibly something effected by grip levels.
I wouldn't put weight under the steering rack either, you will gain more initial steering, but then the inertia will want to make all that extra weight push as you go through the corner.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-13-2015, 08:08 AM   #889
ta04evah's Avatar
Originally Posted by luda View Post
I found inline to be better than across the chassis. It definitely suited the way I drive and setup a car more.
+1
Tried across the chassis, and the car felt "sluggish" at the rear, with direction changes also feeling slow. Mounted the battery in line and the car felt more agile, and a lot easier to drive.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 05-13-2015, 08:30 AM   #890
This is hilarious. Both sides say the same thing! I went with Jan's preference and have been happy. He has run on low grip to high grip, carpet to asphalt. It must be something for you boys down under and your preference for inline and why your toilets flush the opposite from us in the higher latitudes.
Team I'm Over It
Old 05-13-2015, 09:49 AM   #891
571 works well on low traction asphalt on my x1
andyfox is offline   Reply With Quote
Old 05-13-2015, 10:02 AM   #892
spencehotbodies's Avatar
Default Lipo postion
I have been running the lipo across the chassis, have tried it inline but felt the car lost the rear end more easily. Running the lipo across the chassis I can push in and out of the corner, I have loads of steering and corner speed is very high.
spencehotbodies is offline   Reply With Quote
Old 05-13-2015, 10:15 AM   #893
This makes the most sense to me so far. Inline~ more stable less overall traction. Transverse- more weight transfer, more overall traction. Chose one that makes sense for the conditions you run in.
Team I'm Over It
Old 05-13-2015, 11:36 AM   #894
That's odd. What tire combo are you running? I run transverse.Plenty of steering. Carpet and asphalt.
Tried inline and transverse. Mine pushes like a dump truck...
Sydewynder is offline   Reply With Quote
Old 05-13-2015, 02:20 PM   #895
Thanks! I looked up the compounds and would explain why Rampokker said his car pushed a little bit with 573. I have run 571/572 and 571/575 on carpet and asphalt with good success. I have run 574/575 on carpet and it works very well when the grip is lower. I want to try 574/572 next outdoor race day. Knowing that 573 is harder then 571, I think I will skip that compound. My head hurts now trying to keep these all straight.
Team I'm Over It
Old 05-13-2015, 02:22 PM   #896
pushes both ways? Are you gonna be at Norcal Sunday?
Team I'm Over It
Old 05-13-2015, 03:16 PM   #897
JayL's Avatar
Maybe it depends on where we put the lead to get the car up to weight min, I had to add 60g of lead, I put 20g on right under recv counter balance esc weight and balance the car left to right then I put 20g each side of the battery where the battery would go if it was sideways, not front to back as I have it
or maybe some are running the car WAY under weight
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 05-13-2015, 05:31 PM   #898
Evo 13's Avatar
Default !
I have the Lipo across the chassis and the corner speed is nuts!
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 05-14-2015, 02:10 AM   #899
Rampokker's Avatar
How would you rate the 571/572 combo against 571/575? I found the 571/575 to be pretty safe. Just a tiny bit too much understeer. Let me know what you think of the 574/572. Slight oversteer for me, but it fits my driving style pretty good. Its the combo I'm currently running.
Old 05-14-2015, 07:15 AM   #900
571/572 combo is well balanced. With the Tuning Haus super soft front insert in the 571 it is less aggressive than a 574 but with plenty of steering. I run 1/12 so these cars never feel like I have quite enough steering but that's comparing Apples to Oranges.
Team I'm Over It
