Like Tree34Likes
Old 05-08-2015, 03:37 AM   #871
R Dodge's Avatar
Originally Posted by Evo 13 View Post
Hey guys,
What aftermarket spur gear works on the x1? I'm looking for a 76t.
EA sells the LeeSpeed line of gears, and he does have the 76T in stock. I haven't used them on a pan car yet, but I have in TC. I've been very happy with them in everything from 17.5 to 4.5T. They are very "true" which makes setting mesh very easy. Durability has not been an issue either. You can find them at: http://www.teameamotorsports.com/ind...product_id=124
I prefer to use the LeeSpeed pinions and spur gears together to ensure maximum efficiency. Some other companies' pinions & spurs do not feel smooth when you spin them on each other, but that is not the case with the LeeSpeed stuff. Even if you use a LeeSpeed spur with a different brand pinion, it can feel rough. Other brands that are also well-known for their quality in relation to being true, smooth & efficient are Xenon and Panaracer.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 05-08-2015, 12:37 PM   #872
Evo 13's Avatar
Thanks guys.
I am beginning to really like these F1 cars, x1 in particular, because they force you to improve your driving skills. Getting some decent speeds without that baby fishtailing requires serious focus and sensitivity on throttling.
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 05-09-2015, 08:43 AM   #873
Trader Rating: 28 (100%+)
Originally Posted by eR1c View Post
-Thanks!
(are you a Groundpounder racer too)?
Not a local but have raced there.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-09-2015, 08:48 AM   #874
Evo 13's Avatar
So I took the car out this morning. For the first time I was able to really open it up. I was driving on outdoor asphalt (park) and was able to really push the car. I noticed with the foam tires, the car had no grip and just fish tailed on throttle, but with the rubber Ride R1's, she was planted, even on high speed sweeping corners. So I want to know, do you guys run any weights on the car and if so how does it affect performance? What could I do to plant the rear a bit more? I'd like to push a bit harder. Hey, I can't help it, driving this car makes me feel like Ayrton Senna at Monaco and Adelaide!
Does anyone use the sweep racing v2 f1 tires on asphalt? Would you recommend them?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 05-10-2015, 05:33 PM   #875
wwddww34's Avatar
Trader Rating: 9 (91%+)
Congratulations to Tomasz for taking the win with his X1 in the 5th annual PMMSRC (in Poland). I love the way he setup his car with the trophy in his pic.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 05-11-2015, 12:41 AM   #876
Sebbo's Avatar
I'm running the LCG-Shortylipo from Muchmore, which is 50g lighter than a "normal" Shortylipo. So i have to add 50g on the Chassis to make the minimum weight of the ETS-Series. I put the weight under the steering rack, which gives the car more steering, while still having a planted rear! The X1 really handles very well on the Ride F1 rubber tires...i can push the car and laptimes are getting better and better! Saucing and heating the tires is absolutely neccessary plus keeping the trigger under control...
Awesomatix A800, Mugen MTC-1, Team Associated F6
www.mst-estenfeld.de
Sebbo is offline   Reply With Quote
Old 05-11-2015, 01:36 AM   #877
spencehotbodies's Avatar
Default Weight under the steering
Hello
Didn't 't you find the front push with the weight there? We tried it but changed it back.
spencehotbodies is offline   Reply With Quote
Old 05-11-2015, 02:26 AM   #878
Sebbo's Avatar
For me it worked really well...improved steering! Could keep up with some of the 17.5 Blinky-guys at my hometrack with some tight corners in the infield. Didn't notice a push... I'm running the softest front and side springs from xray. I will play with the weight position the next training sessions...maybe it's getting even better!?
Old 05-12-2015, 04:09 PM   #879
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Going to try running inline this weekend. Anybody else tried? Disliked or liked?
Josh-n-ya is offline   Reply With Quote
Old 05-12-2015, 04:46 PM   #880
I found inline to be better than across the chassis. It definitely suited the way I drive and setup a car more.
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 05-12-2015, 04:47 PM   #881
yeah try it!
Team I'm Over It
Old 05-12-2015, 05:08 PM   #882
Rampokker's Avatar
Inline works better for me too. I could just not get enough steering with battery across the chassis.
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
Old 05-12-2015, 07:10 PM   #883
Trader Rating: 27 (100%+)
for your inline lipo setup test, are you talking about carpet or asphalt track?
Awesomatix-Vbc-Hudy-Orca-motiv-Tsr-
pat5b is offline   Reply With Quote
Old 05-12-2015, 08:02 PM   #884
That's odd. What tire combo are you running? I run transverse.Plenty of steering. Carpet and asphalt.
Team I'm Over It
Old 05-12-2015, 08:56 PM   #885
Rampokker's Avatar
Currently running Pit Shimizu 573 Front / 572 Rear on Ashphalt. Inline battery and soft front springs have got the steering to almost where I like it. Still understeers slightly for me. Other guys at my track reckon it has too much steering for them though
I have some different front/rear combinations I'll be trying next time.
