Like Tree34Likes
Old 04-21-2015, 11:17 AM   #826
wwddww34's Avatar
Trader Rating: 9 (91%+)
Originally Posted by Skiddins View Post
What was Drew's carpet setup?
I talked to Drew while at MHIC and asked what his setup was. This is what he told me:
  1. Caster = 12
  2. Camber = 2.5
  3. Tires = Pit Shimizu - TCS spec tires
  4. Side Shock Oil = 350 cst.
  5. Mono Shock Oil = 400 cst.
  6. Mono Shock Spring = Kit spring C2.2
  7. Width of car (measured between outside walls of tires) = 190mm
  8. Ride Height = 4mm
  9. Front Wing = Tamiya F104 wing, part no. 51383
I tried this setup on my X1 but found out it had way too much steering for my liking.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 04-21-2015, 12:32 PM   #827
JayL's Avatar
Originally Posted by racenut123 View Post
I get what you are saying. Side loads are one thing but hitting stuff and expecting them to survive it quite another. Could it be the actual Xray bearings or is this happening with all other bearings?
I haven't seen or had an axle bearing failure from a hit since the F104 came out, and I have owned almost every brand/version F1
could be the xray bearings, installing AVIDS now, then again the sidewall is SMALL, be easy to make it alittle bigger, the bearings already exist, just a new little plastic part
Don't get me wrong the car is GOOD!
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 04-21-2015, 01:59 PM   #828
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
I replaced broken bearing with another xray bearing from the spares I ordered. Same spur gear side blew out. Haven't used any other brand yet. I will next time though.
Josh-n-ya is offline   Reply With Quote
Old 04-21-2015, 02:10 PM   #829
Trader Rating: 28 (100%+)
Well I had issues with smaller XRAY layshaft bearings back in the FK04 and FK05 days so bearing issues come up from time to time. I am gonna order some extra Avids. As far as ride height pills go,yeah that may be a solution but it would be interesting to see if anyone in Europe where they run races like the f1 masters or ETS series on bigger tracks to see if they have issues with failure/longevity of these bearings.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 04-21-2015, 03:08 PM   #830
Trader Rating: 18 (100%+)
  1. Caster = 12
  2. Camber = 2.5
Looks like I'm going to try lighter oil in the mono shock. Switched to the Tamiya Side Damper and it was unreal how much better it was.
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is online now   Reply With Quote
Old 04-21-2015, 03:51 PM   #831
Skiddins's Avatar
  1. Caster = 12
  2. Camber = 2.5
How on earth did he get any steering with that much caster?
Is there any video of the F1 finals?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-21-2015, 04:14 PM   #832
https://www.youtube.com/watch?v=oEjs8R5Gus8&t=21m45s
setup worked very well for the high grip conditions.
Team I'm Over It
Old 04-21-2015, 05:26 PM   #833
Skiddins's Avatar
Yep, it certainly does look good there, only problem is I never see grip that high on carpet here
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-21-2015, 10:27 PM   #834
Trader Rating: 33 (100%+)
Yeah, grip was pretty high at the race last weekend. We had traction roll issues early on and found going lighter in the side shock or tube helped tremendously. I usually run no shims for camber gain at home and at the club race Thursday night, but the weekend traction was way too much. Also, tire prep and timing of traction compound are a major tuning aid to driving style. As for Drews setup, not many can drive it, lol.
chensleyrc1 is offline   Reply With Quote
Old 04-22-2015, 01:37 AM   #835
Skiddins's Avatar
Which shims are you reffering to regarding camber gain?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-22-2015, 01:49 AM   #836
Hi all I 'm wondering does the X1 fit Tamiya body? THX!!!
loman15 is offline   Reply With Quote
Old 04-22-2015, 08:07 AM   #837
Jack Kloeber's Avatar
the 3 that dont control ride height..... low grip remove those shims from under those 3 posts
Jack Kloeber
Jack Kloeber is offline   Reply With Quote
Old 04-22-2015, 08:46 AM   #838
Skiddins's Avatar
The Tamiya bodies don't fit properly as they tend to narrow near the back, where the side links are on the car.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-22-2015, 01:21 PM   #839
What Jack said. It is the three in the middle front suspension mount. Not the shims under the arms.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
Old 04-22-2015, 01:31 PM   #840
wwddww34's Avatar
... As for Drews setup, not many can drive it, lol.
I agree. Drew is a 'freak of nature' who can drive the most unstable car setups.
