Like Tree34Likes
Old 04-19-2015, 10:53 AM   #811
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Not this red car! The other one....
Dan is offline   Reply With Quote
Old 04-19-2015, 02:42 PM   #812
Skiddins's Avatar
Anyone else finding that making changes on asphalt seems to do next to nothing
Best 'tuning' so far seems to be choice of front wings and rear wing position.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-20-2015, 09:55 AM   #813
JayL's Avatar
Originally Posted by Josh-n-ya View Post
Anybody else having rear axle bearing issues? I blew out two of them today. Found out another guy blew out 3. Mine were on the spur side in pod. Tried with a small amount of axle slop and other with none. Also striped two spurs today. Rough first time out. lol
Every one I've seen had killed the rear bearings, they have such a small sidewall
I bought a ten pack with my X1 kit
Has anyone found a alum servo arm with same length and offset as the stock saver?
cant seem to find the hudy offset one
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 04-20-2015, 10:09 AM   #814
sbd
I have experimented some change with the front. Changing spring rate (softer) has some effect. Changing angles I think, has smaller effect. Probably because the front is quiet flexible.
sbd is offline   Reply With Quote
Old 04-20-2015, 01:58 PM   #815
wwddww34's Avatar
Trader Rating: 9 (91%+)
Here's a pic of my X1 on the Tech Table at 2015 Mile High Indoor Championship in Denver, Colorado last weekend. This car managed to finish in 2nd place in the F1 B-Main. Not too bad for being the first weekend I ever drove the car.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 04-20-2015, 02:03 PM   #816
wwddww34's Avatar
Here's a pic of Drew Ellis' X1 on the A-Main grid at the 2015 Mile High Indoor Championship. Drew's car ended up winning the A-Main. Mario Ficco finished 2nd with his CRC WTF1 and Robert Bakoczy finished 3rd with his VBC.
Old 04-20-2015, 02:21 PM   #817
Skiddins's Avatar
What was Drew's carpet setup?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-20-2015, 03:18 PM   #818
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
I know who's car it was. Lol. He must of fell asleep again.
Yup! Ordered!
Josh-n-ya is offline   Reply With Quote
Old 04-20-2015, 03:41 PM   #819
JayL's Avatar
re: rear axle bearings:
Maybe we can get Bill Jeric at Tuning Haus, or Exotek Mike, to make a rear ride height insert that will take a bearing with a BIGGER outer diameter.....
please!!!
Old 04-20-2015, 05:03 PM   #820
Dan
Dan's Avatar
The bearings may be fine for 1/12 but doesn't look like its enough for 1/10th rubber! You know X-Ray can't make the car too perfect, they have to add it as a feature on the new X1 2016 car coming out in 8 months. (optimized)
Old 04-20-2015, 06:08 PM   #821
Trader Rating: 28 (100%+)
Why not just buy some AVID bearings and replace them when needed? At a dollar a bearing it's not a big deal. I just checked my stock bearings.They seem fine. Plenty of run time on them.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 04-20-2015, 10:50 PM   #822
Trader Rating: 23 (100%+)
hi guys, just about to put in a big rc order and am going to start getting serious about running my x1. Any suggestions on what parts break easily that I should stock up on?
Also what front wing are most people running? I've been looking at the tamiya J-parts front wing. Is this any good?
Many thanks
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 04-21-2015, 09:43 AM   #823
JayL's Avatar
done that.
But the bearings get killed DURING a run, rather that didn't happen if all it takes is a slightly bigger outer diameter bearing.
Every X1 I have seen has failed to finish a race due to this issue at least once, at my track.
Big difference between a ~100' track and a ~200' track, as far as the speeds and g's a rear axle takes a hit and blows the bearing, it is not from wear....
Old 04-21-2015, 10:13 AM   #824
I get what you are saying. Side loads are one thing but hitting stuff and expecting them to survive it quite another. Could it be the actual Xray bearings or is this happening with all other bearings?
done that.
Team I'm Over It
Old 04-21-2015, 10:25 AM   #825
sbd
done that.
The Xray rear flanged bearings are not great at all. I use the Avid bearings - much better. I have not a failed one yet.
