Like Tree34Likes
Old 04-15-2015, 09:44 AM   #781
scirocco14's Avatar
If you want to try a Tamiya friction roll damper cheaply, ask a friend who races a F104V2. There's a plastic friction roll damper on the "W" parts tree that is not used on the F104V2 because it comes with oil-filled dampers. It might be a good way to try it out before spending the $$$ on the TRF friction roll damper.
Mark
Mark C. USVTA #115 TC4 & Xray T4 '13, USGT #115 Xray T4 '13
USVTA-F1 #115 F103/4 & F1R3 & WTF1 FC-16. Tamiya M05 M06
Bush River RC, The RUG at King, Ho B Max Raceway, Easley RC
scirocco14 is offline   Reply With Quote
Old 04-15-2015, 09:49 AM   #782
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
It would not feel even close to the same. Unfair comparison. The aluminum damper is cheap anyways. $10 new.
And for those wanting to use the Tamiya aluminum tube damper, you'll want a longer ball end connector on just one end. The inner tube is slightly more exposed on the X-ray since the two mounting points are wider than on the Tamiya F1's. It shouldn't affect feel too much but there is more surface coverage on the tube with a longer ball end.
I'll post a pic tonight.
Dan is offline   Reply With Quote
Old 04-15-2015, 09:51 AM   #783
Dan
Dan's Avatar
edit
Old 04-15-2015, 09:52 AM   #784
scirocco14's Avatar
Originally Posted by Dan View Post
edit
OK, sorry. Just trying to help.
Mark
Old 04-15-2015, 10:07 AM   #785
Skiddins's Avatar
I used standard Xray Rod ends, but shortened by 3mm at both ends, so it has the same range of movement in each direction (without the plunger coming out too far) as the kit shock.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-15-2015, 10:15 AM   #786
Dan
Dan's Avatar
Good to know! I ended up using Tamiya ball studs with the Tamiya ball connectors. Didn't even bother to build the X-ray side shock.
Old 04-15-2015, 03:19 PM   #787
emacrimes's Avatar
What aftermarket bodies fit the X1?
Agama A215
Ko Propo | Highest RC | Team Orion | Sweep |
emacrimes is offline   Reply With Quote
Old 04-15-2015, 04:55 PM   #788
Skiddins's Avatar
I've got a Protoform Thirteen, not an absolutely perfect fit, but looks good enough;
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-15-2015, 07:22 PM   #789
xrayracer1's Avatar
I just so happen to have a Tamiya F104 Pro V2. I might sift through the box of unused parts.
Gavin.
Converting nitro to electric is utter blasphemy.
xrayracer1 is offline   Reply With Quote
Old 04-15-2015, 08:23 PM   #790
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
That looks great actually. Do you know if the fourteen will fit too?
Josh-n-ya is offline   Reply With Quote
Old 04-16-2015, 01:39 AM   #791
Skiddins's Avatar
I'm afraid I don't. I just seem to recall someone mentioned that Juraj Hudy had said that the Thirteen fitted.
If it wasn't for the ESC on it's side with it's wiring touching the body I could actually get the body even lower
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-16-2015, 04:12 AM   #792
Trader Rating: 28 (100%+)
Charles Lightfoot from TQ runs the 2014 on his X1 I believe.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 04-16-2015, 04:28 AM   #793
No9
No9's Avatar
I have the fourteen on mine and fits just fine.I'll post a pic up soon.
Schumacher Mi5evo/Ko Ex1v2/LRP/R1 wurks
Supported by MRJ RACING.COM.AU
No9 is offline   Reply With Quote
Old 04-16-2015, 07:19 AM   #794
wwddww34's Avatar
Trader Rating: 9 (91%+)
Here's my X1 with a PF Thirteen body on it. I'm ready to race it in Denver this weekend.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 04-16-2015, 12:51 PM   #795
As No9 says: the Protoform thirteen & fourteen both fit just fine on the XRAY X1.
Thaan is offline   Reply With Quote
