Like Tree34Likes
Old 04-14-2015, 12:16 PM   #766
Trader Rating: 33 (100%+)
I'm using a Speed Passion Tube on mine. Have you found that going lighter in the tube sometimes fixes traction roll or diffing out?
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 04-14-2015, 06:41 PM   #767
Trader Rating: 14 (100%+)
I can't tell from the pictures or instructions but do these use shorty lipo packs or standard ones?
Also is the servo size standard or the mini ones like in the x12?
Thanks.
Slippery Dan is offline   Reply With Quote
Old 04-14-2015, 06:43 PM   #768
Jack Kloeber's Avatar
Yep helps
Jack Kloeber
Jack Kloeber is offline   Reply With Quote
Old 04-14-2015, 06:52 PM   #769
xrayracer1's Avatar
Ok, so what are the advantages of using a damper tube over an oil filled damper?
Gavin.
Converting nitro to electric is utter blasphemy.
xrayracer1 is offline   Reply With Quote
Old 04-14-2015, 09:28 PM   #770
wwddww34's Avatar
Trader Rating: 9 (91%+)
I prefer the damper tube simply because it's easier to change tube grease than it is to change shock oil.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 04-14-2015, 09:45 PM   #771
Trader Rating: 22 (100%+)
This. Thats the only reason im running a tube rather than the shock. I can change weight of tube lube in about a minute, as opposed to rebuilding a shock.
The shock stays more consistent over a longer period, you do have to relube the tubes
goneracin is offline   Reply With Quote
Old 04-15-2015, 01:09 AM   #772
Skiddins's Avatar
Thanks.
They use 2s Shorty or 1s lipo's.
The servo is standard TC size, although most use the 'slim' TC servos to ensure they stay neatly within the bodyshell.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-15-2015, 01:13 AM   #773
Skiddins's Avatar
Maintenance and adjustment as the others have mentioned, plus it's impossible to end up with air bubbles ruining the damper tube the way side shocks always do.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-15-2015, 03:36 AM   #774
xrayracer1's Avatar
Would the damper tube from the Xray X12 fit?
Gavin.
Old 04-15-2015, 04:19 AM   #775
Skiddins's Avatar
Sadly, no, they're too long.
You really want a larger diameter tube anyway, as you only have room for one tube and the F1's weigh a lot more.
Tamiya's tube is almost exactly the same diameter as the original shock.
Not sure about the Serpent etc that others are using.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-15-2015, 04:45 AM   #776
xrayracer1's Avatar
Dang it! Oh well ill just have to look for a Tamiya one.
Gavin.
Old 04-15-2015, 06:56 AM   #777
mbykerman's Avatar
Trader Rating: 45 (100%+)
Tuning Haus makes one also. Available at Tqracing.com. I haven't gotten one yet but been thinking about it.
mbykerman is offline   Reply With Quote
Old 04-15-2015, 08:15 AM   #778
Trader Rating: 28 (100%+)
Before buying the Tuning Haus tube, just so you know because of it's internal diameter and tolerance between tube and plunger, you have to run a really thick fluid/grease in comparison to the tamiya tube to get a similar feel to the stock shock. Maybe Tuning Haus' own fluids are the trick, but when trying a bunch of different fluids in his, my friend said it had too thin of a feeling.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 04-15-2015, 09:01 AM   #779
emacrimes's Avatar
does the F104 bodies fit the X1?
Agama A215
Ko Propo | Highest RC | Team Orion | Sweep |
emacrimes is offline   Reply With Quote
Old 04-15-2015, 09:22 AM   #780
mbykerman's Avatar
Thanks!!! I appreciate the information. Hate having to buy stuff over cause it doesn't work like I want it too.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
