Like Tree34Likes
Old 03-16-2015, 06:03 AM   #706
Originally Posted by racenut123 View Post
Thanks Luda!
Has anyone else tried the Tuning Haus Damper tube in place of the roll shock yet?
Got one, but haven't tried it yet. As far as Freebird. It takes a different driving style. You have to really be smooth. The stock carpet setup works really well. We have been running them at The Gate pretty much with the stock set up. The diff is critical and should be just locked up. Other than that just keep running the car and get used to it.
chuck
mackin is offline   Reply With Quote
Old 03-16-2015, 07:09 AM   #707
wwddww34's Avatar
Trader Rating: 9 (91%+)
I replaced the roll shock with a Damper tube simply because it is much easier to change the weight of tube grease than it is to change shock oil. Right now I have 20K grease in the tube but I can easily change it to 25K or 30K grease if the rear tires lift on corner exit.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 03-16-2015, 08:29 AM   #708
Skiddins's Avatar
Can you tell what rating of grease/oil is roughly equivalent to the kit oil in a side shock?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-16-2015, 08:36 AM   #709
Trader Rating: 28 (100%+)
which tube?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 03-16-2015, 09:24 AM   #710
wwddww34's Avatar
which tube?
I just used the Tamiya Roll Damper from my old F104X1. It is Tamiya 54413.
The 20K Tube Lube feels closest to the kit oil in a Xray side shock.
Old 03-16-2015, 03:48 PM   #711
xrayracer1's Avatar
I see a lot of people changing to damper tubes. Are these better than the oil filled roll damper?
Gavin.
Converting nitro to electric is utter blasphemy.
xrayracer1 is offline   Reply With Quote
Old 03-16-2015, 05:56 PM   #712
Ph3nyx's Avatar
more consistent and easyier to maintain. You gain a lot of time doing setup with tubes
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 03-16-2015, 08:58 PM   #713
ta04evah's Avatar
Gavin, I use one on my F113 when I race at Castle Hill. As others have stated, it's easier to change the oil/grease with the tube, than it is with the shock.
That being said, I'm going to try the shock on my Xray when I build it to see if I can get similar dampening properties.
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 03-16-2015, 09:29 PM   #714
xrayracer1's Avatar
Rob.
Will you have it built by the 27th of this month? Because thats when im cominf down next.
Gavin.
Old 03-17-2015, 01:04 AM   #715
ta04evah's Avatar
Hopefully yes, as I'm wanting to get it built before the NSW state titles, and will try to get start on it this weekend.
Will still bring the trusty old F113 though as I know that car works there.
Rob.
Old 03-17-2015, 02:40 AM   #716
xrayracer1's Avatar
Rob.
Awesome mate!
Gavin.
Old 03-19-2015, 08:20 AM   #717
Just mounted a set of TCS tires on Exotek rims. I really like the Exoteks as they are much easier to mount up. Has anybody tried to balance their tires yet? If so what did you use? The rears would be no problem, but how about the fronts?
thanks
chuck
Old 03-20-2015, 03:22 AM   #718
Hello from France,
as always, I rewiewed some chassis and now, it's time fr the Xray X1 formula 1.
Enjoy!!
Au revoir.
Romuald.
http://www.automodelisme.com/index.p...&topic=48961.0
romuald31 is offline   Reply With Quote
Old 03-20-2015, 03:58 PM   #719
rcfiend's Avatar
Trader Rating: 29 (100%+)
I got a chance to briefly run my X1 last week. I'm heading back to the track Sat. Last week I had an issue with the car traction rolling at the end of the straight away going into the sweeper. I'm running the kit setup, any suggestions where I can start to correct the traction rolling. New to F1.
Thanks.
rcfiend is offline   Reply With Quote
Old 03-20-2015, 06:22 PM   #720
Robby368's Avatar
Trader Rating: 14 (100%+)
Thanks.
Did you glue the sidewalls? Also reduce your camber to 1.5 or 1.0
Before you judge someone, walk a mile in their shoes. Then you'll be a mile away and have their shoes.
Robby368 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
rubezzz
