Like Tree45Likes
Old 03-12-2015, 03:08 PM   #691
NutDriver's Avatar
Trader Rating: 16 (100%+)
I hadn't thought about the tolerance of the bearing. THAT makes sense. Thanks.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 03-12-2015, 04:21 PM   #692
JoJo1241's Avatar
Originally Posted by wwddww34 View Post
How big are the balls?
the balls are 3,175 mm.
JoJo1241 is offline   Reply With Quote
Old 03-13-2015, 08:32 AM   #693
ta04evah's Avatar
Another couple of questions (Sorry if I'm asking too many )
The steering tie rods, what size spanner will I need for them, as I want to get proper tools for them to minimise any chance of damage while building/setting up.
Also, I would be right in assuming that the rear axle is also imperial? ie 1/4 inch diameter?
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 03-13-2015, 08:36 AM   #694
wwddww34's Avatar
Trader Rating: 9 (91%+)
Originally Posted by ta04evah View Post
The steering tie rods, what size spanner will I need for them?
4mm spanner.
Yes, 1/4 inch O.D. on the rear axle.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 03-13-2015, 08:41 AM   #695
NutDriver's Avatar
CRC is the only one with a 1/4" axle to my knowledge. All others have 6mm (with very rare exception).
USVTA member #111
Old 03-13-2015, 09:04 AM   #696
robk's Avatar
Trader Rating: 22 (100%+)
Vbc and Top are 1/4 as well
Old 03-13-2015, 09:14 AM   #697
Skiddins's Avatar
Rear axle is definitely 1/4" as the bearings are 1/4 x 3/8 x 1/8.
Same as almost every 1/12 as well.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-13-2015, 09:55 AM   #698
NutDriver's Avatar
Holy cow! Maybe I can get F1 tires on my pan car with stuff other than CRC parts! Thanks, guys!
USVTA member #111
Old 03-13-2015, 11:31 AM   #699
sbd
Yes this is what I have been thinking regarding my X10. I think what I need is the X1 left and right rear hubs and X1 steering blocks and axles. Though I have the feeling the rear end of the X10 would be too narrow with the F1 tires.
sbd is offline   Reply With Quote
Old 03-13-2015, 03:29 PM   #700
I'm pretty sure they're 3mm.
One more strike and you are not allowed to play anymore!
simple is offline   Reply With Quote
Old 03-13-2015, 08:13 PM   #701
ta04evah's Avatar
Thanks for the answers guys.
The 3 Racing F113 has a 1/4" rear axle & uses 2 of 1/4th x 3/8th x 1/8th flanged bearings in the diff as well.
Rob.
Old 03-13-2015, 09:27 PM   #702
Trader Rating: 28 (100%+)
what length sensor wire is needed if you run the battery across and ESC on the left front of chassis?Help!
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 03-14-2015, 02:20 AM   #703
Half way through the build but I did a quick measure and I think a 120mm sensor cable minimum with the battery mounted side to side.
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 03-14-2015, 07:31 AM   #704
Thanks Luda!
Has anyone else tried the Tuning Haus Damper tube in place of the roll shock yet?
Team I'm Over It
Old 03-16-2015, 05:24 AM   #705
Built and ran the car this weekend for the first time. FUN FUN FUN.......... but looking to start a little slight tweaking on the kit setup. I run at Thunder RC in Nashville and our current layout is like the snowbirds which many Team Xray guys came to prior to snowbirds to get some track time. its high grip most consistently. I installed the Shimizu 571 and 572 grip was good in the straights. I am looking to improve on steady and power steering; it pushes till you roll off the throttle then turn in I'm spot on. Corner exits the rear lift up and has tire spin. I pretty sure that me and throttle overload. Im an older returning Rc hobby lover and don't remember 12th scale tuning as they have change a lot. Ive been looking through the threads on hear and X-rays web site. have got a lot of options to look at. I feel the car is good now; just the slight controlled push from the kit setup.
freebird is offline   Reply With Quote
