Like Tree34Likes
Old 03-09-2015, 02:14 PM   #676
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by InspGadgt View Post
Aren't the Tamiya TCS tires the 571 front and 572 rear? They certainly don't drive like 574 fronts.
It's 571 and 572 for sure.
Old 03-12-2015, 12:55 AM   #677
Trader Rating: 23 (100%+)
Hi all, i'm looking to replace the lexan front wing of my x1 with a plastic front wing because i've damaged the lexan wing (screws ripped holes in the lexan in an accident). Which wing gives the most downforce and fits well? (prefer not having to modify the wing too much)
Also what tires do people have the most success with? I run on low-med grip asphalt, 30-40 deg track temp. Currently running R1's all round but I have heard that it may be better running Shimizu's up front and R1's in the rear? (or was it the other way around...)
Thanks for any input
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 03-12-2015, 01:56 AM   #678
Ph3nyx's Avatar
Build vidéo for www.rcf1.fr
+ YouTube Video
for the front wing i've replaced mine with the tamiya f60 wing , but i've to drill it a bit.
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 03-12-2015, 02:22 AM   #679
Skiddins's Avatar
Anything for the Tamiya F103 or F104 will fit with the mounting screws (although they may need to be slightly longer than kit), but the bodypost will be in the wrong place.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-12-2015, 07:31 AM   #680
NutDriver's Avatar
Trader Rating: 15 (100%+)
Speed Passion sells lexan front wings for the SP-1 that may be a cheaper alternative.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 03-12-2015, 08:05 AM   #681
ta04evah's Avatar
+ YouTube Video
Great video, good to see some of the parts in close up detail.
Another question I have is, are the diff balls in the kit steel or ceramic?
Hopefully getting my kit next week
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 03-12-2015, 08:16 AM   #682
Ph3nyx's Avatar
Steel balls unfortunatly ...
Old 03-12-2015, 09:53 AM   #683
JoJo1241's Avatar
Rob.
930130 carbide diff balls in the kit.
Not just steel, carbide is much tougher.
JoJo1241 is offline   Reply With Quote
Old 03-12-2015, 10:07 AM   #684
wwddww34's Avatar
Trader Rating: 9 (91%+)
How big are the balls?
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 03-12-2015, 10:18 AM   #685
NutDriver's Avatar
I'm pretty sure they're 3mm.
USVTA member #111
Old 03-12-2015, 10:25 AM   #686
wwddww34's Avatar
I just checked p/n 930130 on Google, they are 1/8 inch diameter balls.
Old 03-12-2015, 10:37 AM   #687
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
For anyone interested Hiro Seiko X1 kits are on the site and ready to ship finally.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 03-12-2015, 11:15 AM   #688
NutDriver's Avatar
Since 1/8" directly converts to 3.175mm, is there an effective difference between the two sizes (that's less than .007")? I've been told that there are, but I have a hard time believing that tolerances are tight enough, especially in a ball diff, for it to be a perceivable difference.
USVTA member #111
Old 03-12-2015, 11:21 AM   #689
wwddww34's Avatar
I have tried using 3mm balls (in lieu of 3.175mm) in the past and it all comes down to how thick the bearing is in the middle of the spur gear. If the bearing is thicker than the diff ball diameter, then the diff plates will not make solid contact with the diff balls and your diff will not work properly.
Old 03-12-2015, 01:30 PM   #690
Also, a standard spur gear intended for use with 1/8 balls will perform awful when 3mm balls are substituted.
I've had some cases where a random 3mm from my Tamiya cars got mixed into my crc parts, and resulted in a confusing and crappy diff racing weekend! The ball was small enough in comparison that the rings wouldn't make contact, and it almost appeared that the the inner thickness of the spur gear was wider than the ball!
Additionally, there was significant slop of the balls in their pockets. Was a pain to attempt assembly when they would fall right through.
As a general rule: don't substitute them, and don't guess. It'll make your racing more enjoyable.
simple is offline   Reply With Quote
