Like Tree34Likes
Old 03-08-2015, 06:09 AM   #661
37/96 indoors on carpet at The Gate which is 40-84 with good to high bite.
chuck
mackin is offline   Reply With Quote
Old 03-08-2015, 09:24 AM   #662
Regional Moderator
CarbonJoe's Avatar
I love this car. 6 races with it, 6 TQs with 5 victories and 1 second due to contact. Only changes from the kit setup were moving the rear wing from the standoff mount to the inside of the pod brace, and from 2 degrees of camber to 1.5 degrees of camber. On a high grip track, the car turns like a 1/12 scale.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-09-2015, 02:41 AM   #663
sbd
Hi Joe,
what tires do you run?
sbd is offline   Reply With Quote
Old 03-09-2015, 03:09 AM   #664
ta04evah's Avatar
RCFormula1.com.au X1 review, sounds promising
http://www.rcformula1.com.au/index.p...xray-x1-review
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 03-09-2015, 05:50 AM   #665
Originally Posted by sbd View Post
Hi Joe,
We've been running the Tamyia TCS tires with SXT at The Gate.
chuck
Old 03-09-2015, 05:54 AM   #666
10 F1 cars at The Gate last Saturday. 4 were Xrays. Tq and the win 2nd, 5th, and 8th. If everyone would show up on a given day we would have close to 20 cars.
chuck
Old 03-09-2015, 06:44 AM   #667
Regional Moderator
CarbonJoe's Avatar
Hi Joe,
Tamiya TCS F104 spec tires, Tamiya part numbers
Front 1031 soft (same as Shimizu 574 soft fronts)
Rear 1032 hard (same as Shimizu 572 hard rears)
Old 03-09-2015, 06:52 AM   #668
Robby368's Avatar
Trader Rating: 14 (100%+)
What motor/esc are you guys running for indoor carpet? I have a killshot 21.5 at 68-70 degrees timing but it still seems a bit slow on top end.
Before you judge someone, walk a mile in their shoes. Then you'll be a mile away and have their shoes.
Robby368 is offline   Reply With Quote
Old 03-09-2015, 06:55 AM   #669
Trader Rating: 33 (100%+)
Just picked one up yesterday, was very impressed. I was .2 faster than my CRC right out of the box, using the same equipment. The car just drives fast easily, didn't need to push it to get fast laps and was able to put 5 of my fastest laps back to back within .1 of each other.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 03-09-2015, 07:17 AM   #670
sbd
Thanks Joe and mackin
Old 03-09-2015, 07:22 AM   #671
Chaz955i's Avatar
I've been running the Trackstar 21.5 max timing with a 37/96 gear. In three races I have two seconds and a DNF due to a sensor wire popping out after a hard hit. I race with CarbonJoe and Mackin. The Trackstar doesn't have as much top end as the Team Scream motored car I drove but is solid everywhere else. I've no intention of changing motors at this point unless something amazing comes out before I start up again in the fall.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 03-09-2015, 07:41 AM   #672
Regional Moderator
CarbonJoe's Avatar
I'm running an almost 2 year old SchuurSpeed 21.5. I'll have to check the gearing and timing when I get home.
Old 03-09-2015, 07:52 AM   #673
I've been running a Team Scream 21.5 with about 35 degrees of timing and 37/96. One thing if you haven't tried it is to move the rear wing to the inside of the rear pod. It gives it a little more steering. Speeder is a Hobbywing Just Stock.
chuck
Old 03-09-2015, 09:54 AM   #674
Aren't the Tamiya TCS tires the 571 front and 572 rear? They certainly don't drive like 574 fronts.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 03-09-2015, 11:22 AM   #675
NutDriver's Avatar
Trader Rating: 15 (100%+)
I was going to ask the same thing, Inspector Gadget.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
