Like Tree47Likes
Old 03-02-2015, 07:18 PM   #631
Trader Rating: 28 (100%+)
Has anyone in the states run the GRP tires?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 03-02-2015, 09:45 PM   #632
xrayracer1's Avatar
Originally Posted by mtveten View Post
The sweeps are by far the worst tire on the market.
The pit and re branded pit tires are the best performers. Solaris tires also work fine but are slower than pits.
Yeah i'm not impressed with the set of sweep tires i have. But i may try them at a different track.
Gavin.
Converting nitro to electric is utter blasphemy.
xrayracer1 is offline   Reply With Quote
Old 03-04-2015, 12:12 PM   #633
wwddww34's Avatar
Trader Rating: 9 (91%+)
Hudy is making a dedicated F1 setup station.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 03-04-2015, 03:06 PM   #634
xrayracer1's Avatar
Doesn't Hudy already have a setup station for 1/10 pan cars? Wouldn't it be the same thing or am i missing something?
Gavin.
Old 03-04-2015, 03:43 PM   #635
Axle size is different from a 1/10th pan to a F1
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 03-04-2015, 03:45 PM   #636
JayL's Avatar
the pan car setup station uses standard bearings, the F1 one uses metric....
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 03-04-2015, 03:47 PM   #637
NutDriver's Avatar
Trader Rating: 17 (100%+)
F1 front axles are 5mm where TCs are 4mm. Pan cars can be 3/16 or 1/4 (I believe). Not sure about metric pan cars.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 03-04-2015, 03:57 PM   #638
Trader Rating: 20 (100%+)
Okay guys need some setup help.
I'm running the X1 on medium grip asphalt with kit setup and Ride R1's all round.
I'm finding that the car understeer's quite a fair bit into and through the corners. There just doesn't seem to be enough front end grip. Now I have tried Pit 571 and 573 but then the car has way too much steering and oversteers almost to the point that the back end wants to let go every corner, so I am on edge trying to catch the back end. I have setup the car with quite a fair bit of drag brake to get the car to turn in better but I know this is slowing me down.
Can anyone offer any setup advice that would help? I'd prefer to stick with the Ride R1's all round.
Thanks.
bee200sx is offline   Reply With Quote
Old 03-04-2015, 04:19 PM   #639
aussierevo's Avatar
Trader Rating: 14 (100%+)
I wonder if they would release the wheel adaptor separately so those with a 1/10 setup could use that. Or does someone already make them?
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 03-04-2015, 07:32 PM   #640
NutDriver's Avatar
Bee,
I would start by using the 571/572 combo and decrease the drag brake by 1/2. If that makes it better, maybe cut the remaining 1/2 by 1/2. Also, you might look to decrease droop in the rear if it's an off-power oversteer.
USVTA member #111
Old 03-04-2015, 10:30 PM   #641
sbd
Thanks.
Hi Bee,
you may try softer front springs - I use Tamiya soft with the Ride tires. Then change the battery position to front-aft orientation to have a little more weight on the front and move the ackerman to the front holes. I have also mover the spacer under the front of the shock to the back so I have 0 spacers under the front and 6 mm under the back. It still plows but is better than before. Also you can try to sauce the front tires a bit longer than the rear. All in all the Ride fronts are not that great.
sbd is offline   Reply With Quote
Old 03-05-2015, 12:34 PM   #642
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
The adapter is just a tube with 5mm ID and 10-12mm OD. Anyone with a small turn can make this for you for few bucks or even for free..
"If you no longer go for a gap that exists, you're no longer a racing driver"
Ayrton Senna
Acid_CZ is offline   Reply With Quote
Old 03-05-2015, 03:18 PM   #643
bd581's Avatar
Or use a couple of bearings.
Haven't tried on the X1 yet, but my touring car setup station works on my TLR 22.2 that way.
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 03-05-2015, 04:45 PM   #644
Thank you all for your advice I will try it out this weekend.
I see Xray have released softer front springs.
Does the Tamiya front springs work on the X1? Are they the same dimensions?
Old 03-05-2015, 10:07 PM   #645
sbd
I am wandering if the setup station is really necessary to set the X1. The only adjustment which is not set by changing inserts is the Toe.
I consider the fact that X1 does not need setup station for one of the Luxury features of the car.
@bee200sx: Yes, Tamiya springs are direct fit.
