Xray X1 - Formula One Car >
Like Tree304Likes
Old 07-17-2017, 07:16 PM
  #2161
mtveten's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Giorgio
Mackin
why you state to not use it outdoor?
The best "Stress test" we've ever had is a 12 hours endurance race, outdoor of course...
12 hours of continuous use and looks brilliant.
I've some guy in Holland that use our Gear Diff even when racing in the wet...
What would you suggest for lube on low to medium grip asphalt? On All but green carpet your diff as worked very well for me with couple of drops of dry lube but on asphalt it feels a bit less stable than a conventional ball diff resulting in slightly less oncsistant & slower laps.
mtveten is offline
Old 07-18-2017, 12:23 AM
  #2162
Giorgio's Avatar
Dry fluid will make car a little temperamental...;-)
If you feel the car twitchy, you can start to use syrups.
Heavier the syrup more easier the car will become, start from 500K.
Remember, you don't have to "fill" the diff as touring one. 4 dabs of syrup on the internals are all you need.
Any issue you might have, just let me know
Giorgio is offline
Old 07-18-2017, 02:15 AM
  #2163
amurray85's Avatar
any suggestions on brand of 'syrup'?
amurray85 is offline
Old 07-18-2017, 10:56 AM
  #2164
Giorgio's Avatar
Sure. Mugen, Xray, Core are excellent in my experience
Giorgio is offline
Old 08-02-2017, 08:25 PM
  #2165
this picture caught my intention, never bump on those thing before. extended shock ball joint (not sure what to call it though) maybe still prototype thingy.
ultraspeed is offline
Old 08-03-2017, 01:12 AM
  #2166
Ph3nyx's Avatar
Lot of guys are using this here in France. It gives more steering on and off power without compromising the rear grip. Very usefull tip !
Ph3nyx is offline
Old 08-03-2017, 06:02 AM
  #2167
That is intereseting
Any one have any more pictures
tekin112000 is offline
Old 08-03-2017, 06:09 AM
  #2168
Trader Rating: 93 (100%+)
looks like a t4 standoff to a aluminum turnbuckle into a ball end. you can probably flip the front front carbon top plate and use a countersunk screw through a nut with an xray ball stud.
Markus is offline
Old 08-03-2017, 06:17 AM
  #2169
MD
MD's Avatar
Trader Rating: 136 (100%+)
That sounds like a good call. I think the X12 has the ability to extend the shock. I think there were some old school pan cars with a similar extension.
MD is offline
Old 08-03-2017, 06:47 AM
  #2170
sbd
This is exactly the way I have had my car for 4 months now. Apart from the T4 standoff though - I have a 6 mm x 35mm generic standoff.
sbd is offline
Old 08-03-2017, 07:10 AM
  #2171
Ph3nyx's Avatar
42mm total length with the shims
Markus and forFREEDOM like this.
Ph3nyx is offline
Old 08-03-2017, 09:41 AM
  #2172
Trader Rating: 26 (100%+)
hmmm
phatboislim is offline
Old 08-03-2017, 10:07 AM
  #2173
xevias's Avatar
How does the extension give more steering?
Is it adding front flex, or changing weight transfer, or something else?
xevias is offline
Old 08-03-2017, 07:00 PM
  #2174
may i know the product code? since it's not available at my local hobby shop, even in offical teamxray website i cant find it.
Old 08-04-2017, 06:33 AM
  #2175
Ph3nyx's Avatar
it's just a 38mm aluminium tube with 3mm thread and 2x2mm spacers.
It's all about weight transfer, it is way more reactive
Ph3nyx is offline
