Like Tree47Likes
Old 04-06-2017, 10:56 AM   #2071
Simplifying my question: could you help me with recommended/initial 48p spur and pinion for 21.5 blinky asphalt racing?
X-Ray T4 2016, X-Ray X1 2016, Team Asso RC10R5, LC Racing EMB-T
Sanwa MT-4S
Yorick is offline   Reply With Quote
Old 04-07-2017, 06:55 AM   #2072
Ph3nyx's Avatar
it depends on your track and also the motor you use. A good start is around 2.5 Ratio
so 72 spur 29 pinion is ok
if you run on a large track you can go to 2.1 2.2
Yorick likes this.
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 04-09-2017, 05:24 PM   #2073
So what kind of spare parts are good to have for an Xray F1 car?
I just got this car and I do alot of travel races, so having just the essential spares would be great
GT CRUSING is offline   Reply With Quote
Old 04-10-2017, 12:04 AM   #2074
ha5
ha5's Avatar
front arms, side links, king pin, flanged rear axle bearings and rear insert.
Xray-Marka Racing-Rc Prostyle
ha5 is offline   Reply With Quote
Old 04-10-2017, 11:19 AM   #2075
RobS's Avatar
Originally Posted by mstrfahrenheit View Post
Sorry for all the questions, getting better though. Best day so far today.
More of a technique question than an X1, but how do you all brake? I got a chance to watch a lot of the touring cars today and they way the slow entering a turn is something I can't replicate. I noticed many were pushing on the trigger for brake. I've got Drag brake set to about 20% on my esc, but I haven't been using trigger braking at all and when I do, since I haven't really set it, it's kind of all or nothing.
I'm carrying too much speed into the turns and it's pushing something fierce
I've been experimenting with hand breaks a lot lately on my X1. Our carpet track has long straights into tight 180's so something more the drag break was needed. Compared to my touring car (which uses 95-100% hand break, 15% drag) on the same layout on my F1 I only use 65-70% hand, (20% drag) with a lot of expo to smooth it out. I'm able to break heavily without getting the car out of shape. It still takes a different driving style compared to Touring Cars though.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 04-10-2017, 11:56 AM   #2076
Spur gears. If you keep it rubber side down, the wing won't hit the gear. We all speak from experience.
Tony Vega is offline   Reply With Quote
Old 04-20-2017, 11:36 AM   #2077
celt's Avatar
Default sway bar
Seeing an advantage/difference with the add of the swaybar?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 04-26-2017, 05:44 AM   #2078
sgp-chris's Avatar
Default Detailed clarification/help regarding tweak
Hi Guys,
I have a question regarding the tweak of this chassis. I have now read all 139 something pages of this thread, and have found small posts here and there regarding tweak which impacts left/right ride height in the middle position. But I have yet to find a post which explains in detail what the issue is.
My hope is that some of you kind Xray guys, will take the time, and help me to understand what my problem is, where it's coming from, and how I can fix it.
I have tried to loosen all screws in the top and bottom of the front end, and tighten them again. This does not help.
I have about 0,4-0,6 difference L/R in ride height in the middle position. I would really like to have that as close to zero as possible.
The front springs are brand new, I have just changed them because i thought one had collapsed maybe. This is not the case.
I hope you can help me out Any help will be much appreciated!
Br.
Chris
Xray-shop.dk - Xray T4'17 - Xray X1'17 - #PHUB
sgp-chris is offline   Reply With Quote
Old 04-26-2017, 06:41 AM   #2079
Trader Rating: 33 (100%+)
Originally Posted by sgp-chris View Post
Hi Guys,
Br.
Chris
Chassis will never be perfectly flat because of tweak balancing and rubber tires and insert inconsistency's. At least that is my experience. I have rotated tires and the offset chassis followed. Plus, I have had it perfect flat then adjusted tweak for balance and it was off again.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 04-26-2017, 07:39 AM   #2080
ByteStream's Avatar
Hi Guys,
Br.
Chris
To make sure I understand, when you measure in the 'middle' position - where are you specifically measuring? At the front of the rear pod plate or somewhere else?
I measure ride height in 4 places:
  • Front - under the front arm mount
  • Front of Side Link - under the front pivot ball
  • Rear of Side Link - under the rear pivot ball
  • Rear - from the back of the pod plate (left and right side)
There are a number of things that can cause tweak:
General
Tires - F1 tires have thin inserts and a large air gap - the more you run them, the more uneven they get. They tend to cone like foam tires with heavy use. I mark my tires and don't rotate them for racing. On the bench, you can rotate them and see if that causes any tweak or put on a new set and see if there is a difference.
Balance - Make sure the car is balanced left to right when ready to run. Remember that the side of the battery with the plugs is lighter than the other side.
Wires - Make sure wires are not causing any pressure on the rear pod. I use TQ1000 (14g), anything more is not necessary. Make sure the sensor wire is not putting pressure on the rear pod - I cut the sleeve off and twist them.
Chassis - double check it is flat.
Front End
Bent Arms - The arms (especially the lower arm) tend to bend and become soft over time. Take the arms off and lightly flex them, if they show signs of being overly soft or not returning to neutral by themselves then replace them.
Collapsed Springs - One spring has collapsed.
Rebuild - For a quick or partial fix, loosening the screws (especially the castor plate) may work, however, I tear down the entire front end. It doesn't really take that much time (~10 min) and allows me to check that nothing is bending, binding or broken and solves 99% of front end issues.
Front/Middle
Servo Mount - I run the car with the direct servo mount position. I will loosen these screws and retighten.
Middle/Rear
Tweak Springs - Check that they are not collapsed, or crooked (the set-screw is not in the carbon straight). I use a 2mm shim between the spring holder and carbon plate as a starting point with kit springs - this makes the springs just touch the chassis. I will tweak the car from there.
Side Links - Make sure they are free - a slightly tight side link on one side of the car is a tell tale sign that the rear pod is tweaked (re-adjust the pivot ball assembly).
Pivot Ball Assembly - check the pivot ball movement - too much slop (up and down) will cause odd ride height issues.
Rear
Pod Plate - make sure it's not bent, cracked, etc.
Inserts - On a rare occasion, the ride height inserts have developed some slop up and down - after a blown and locked up bearing in my case.
Tires - Usually the case, as mentioned before - they wear down and become soft. When replacing with new tires, I have gained 0.5 - 0.7 of ride height.
Overall
Even with a perfectly flat setup, after a couple of hard hits you may start to notice some tweak - 0.5mm is not too bad - 1mm or more and I'd start looking for the issue.
Hope that helps. Let us know.
Yorick and forFREEDOM like this.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 04-26-2017, 10:16 PM   #2081
sgp-chris's Avatar
I measure it just in front of the rear pod.
Thank you very much for you're explanation, I will investigate a little further, and begin to accept the fact that it won't be 100% from L/R
Old 04-30-2017, 11:10 AM   #2082
Trader Rating: 27 (100%+)
Default Rear Pivot ball
Anyone having a problem with the rear pivot ball being real loose in it's socket. Mine will go up and down a few thousands?
hobbyten is offline   Reply With Quote
Old 04-30-2017, 12:00 PM   #2083
sbd
If you measure at the front of the rear pod where the links are connected and have different heights L/R, it is possible the left bulkhead is slightly bent ftont/aft from a hit. The bulkhead must have the two areas touching the lower plate in one plane otherwise the lower plate will get twisted.
sbd is offline   Reply With Quote
Old 05-01-2017, 08:15 AM   #2084
ByteStream's Avatar
Yes, unfortunately it's common (in the X12 and x10 as well). A common replacement is the AE or Kyosho pivot assembly w/ respective pivot balls, however you do want a very slight amount of play to prevent binding.
hobbyten likes this.
Old 05-01-2017, 08:54 AM   #2085
RobS's Avatar
Has anybody actually measured their camber? With the 2 degree inserts (triple checked to make sure I had the correct ones in the proper direction) my car actually has just over 2 degree's on the right and almost 4 on the left. Loosened everything off and re-tightened but there is still about a degree and a half difference.
Rob Say
