Like Tree46Likes
Old 12-19-2016, 12:20 PM   #1861
303slowdown's Avatar
Trader Rating: 24 (100%+)
Swaybar should pull up on the opposite side when suspension compresses and put less pressure on the outside wheel. The progressive springs would just get stiffer on one side and increase pressure.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-20-2016, 01:38 AM   #1862
Hi I'm considering a 2015 X1 but i wanted to know the major differences between the X1 2015 and the 2016 (and even 2017 if it's released).
Can the 2015 car be easily updated to latest spec? What updates/ mods would you say are worth doing?
Is there a good performance gain with the 2016?
thanks
hannhann00 is offline   Reply With Quote
Old 12-20-2016, 01:52 AM   #1863
sbd
I am not sure, I understand what you say. A swaybar adds roll stiffness which could be accomplished by stiffer springs also. I cant see how a progressive spring would have different force distribution effect than adding a sway bar to soft springs.
sbd is offline   Reply With Quote
Old 12-20-2016, 02:44 AM   #1864
Ph3nyx's Avatar
thanks
if you run on carpet the 2015 is still very very performing. on asphalt the floating steering of the 2016 is an avantage
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 12-20-2016, 02:54 AM   #1865
ekt
ekt's Avatar
thanks
The 16 comes with damper tubes instead of a side shock and has the parts to run a floating servo.
The 17 comes with new parts that allow the use of a front sway bar and has a couple more tuning options.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 12-20-2016, 02:56 AM   #1866
sbd
thanks
Hi,
the prefered car for me is 2016. It has some differences to 2015 which make it more durable and working on it easier.
The 2015 could be updated relatively easily to 2016 - You just need to buy the 2016 parts which are direct fit.
As for performance both 2015 and 2016 perform the same...
Old 12-20-2016, 03:41 AM   #1867
I'm still waiting for my 17. If you have the original 15, stick with it.
cheapskate.brok is offline   Reply With Quote
Old 12-20-2016, 05:52 AM   #1868
When a progressive spring compresses it gets stiffer providing more traction, a sway bar doesnt stiffen the suspension it equalizes it and takes traction away from that end. This is just my opinion on what happens, every time ive tried progressive springs on high traction it gives me bad results. It will be something you'll have to just try.
Ryan Borgheiinck
Old 12-20-2016, 06:11 AM   #1869
Nice
jason trandell is offline   Reply With Quote
Old 12-20-2016, 07:33 AM   #1870
cool thanks guys
Old 12-20-2016, 04:55 PM   #1871
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
Exclamation
Hey guys ive been working on this chassis for the x1 for over a year now and this is the first pre production prototype. Ive been running a earlier version of this design last year with great results and the few changes have made it even better. I wont get into to many details right now as i need to test this a little more but want to gauge the interest in a conversion kit available around the start of February. I cut the carbon fiber in house.
Chassis is 2mm thick
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 12-20-2016, 08:55 PM   #1872
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
If you make one in 2mm 7075 aluminum, I'm in...
Dan is offline   Reply With Quote
Old 12-20-2016, 09:24 PM   #1873
Already in the works......
Colin Roussel
Old 12-20-2016, 09:38 PM   #1874
Dan
Dan's Avatar
Awesome! If you incorporate some of the '17 front center shock posts holes, I think you would sell even more.
Old 12-21-2016, 04:01 AM   #1875
Hi what are the benefits of these after market chassis over the stock, obviously performance related but I'm surprised xray and all their expertise seem to be outdone but several after market options?
Also can someone explain the benefits of the alum chassis vs the stock carbon options as I've seen them used widely in TC and F1 (but not so much in pan car)?
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Fastfreddy74
