Like Tree34Likes
Old 12-12-2016, 06:23 PM   #1846
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Originally Posted by TheYellowDart View Post
I can't get this link to work - Anyone else having problems?
Hope you didn't try to login because that link was a phishing link.
If you did try to login, I suggest you change all of your accounts that share the same password as FB.
lagcisco is offline   Reply With Quote
Old 12-12-2016, 08:20 PM   #1847
Shoot....
TheYellowDart is offline   Reply With Quote
Old 12-13-2016, 06:00 PM   #1848
Has anyone set up there front end with dynamic caster and played with side link roll centre?
Friulimotosport is offline   Reply With Quote
Old 12-14-2016, 09:14 AM   #1849
Sorry about the bad link. I posted a new one and tested to confirm it works.
astgerma52sp is offline   Reply With Quote
Old 12-15-2016, 09:01 AM   #1850
Thanks for the help astgerma52sp -- I picked up a ride height gauge to do some measuring and found myself at 3mm on the left side, 4mm on the right side and 3.5 in the back. My roller I bought doesn't have any of the shims to adjust it so I am still thinking of buying the 17 x1 today
Old 12-15-2016, 01:16 PM   #1851
The Captain's Avatar
I bought these shims for mine
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 12-17-2016, 12:41 AM   #1852
Got myself a 2nd hand '16 spec and I'm currently rebuilding for outdoor asphalt, generally low grip.
may be a silly question but could anyone recommend 64p spur/pinion/diff balls for me to run?
I'm only really used to hopped up Tamiya diffs..
We only use Tamiya 540 silver cans (only rule)
I'm happy to stick with 96t spurs.. the car came with one but it's pretty beat up.
Thanks for any advise.
Tamabuchi Corp is offline   Reply With Quote
Old 12-17-2016, 05:22 AM   #1853
shortcut's Avatar
Trader Rating: 49 (100%+)
I run 39-88 with a maclan 25.5 on a 140x70 asphalt track. I'm also using a crc 16 ball spur with ceramic balls, very smooth.
shortcut is offline   Reply With Quote
Old 12-17-2016, 06:52 AM   #1854
Thanks for the info!
Old 12-18-2016, 06:23 AM   #1855
shortcut's Avatar
Will the addition of the front sway bar be more of a benefit on carpet or asphalt ?
Old 12-19-2016, 12:05 AM   #1856
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Maybe benefits carpet due to higher traction. All three qualifying top spots at our carpet race today were 2017 X1's.
Dan is offline   Reply With Quote
Old 12-19-2016, 04:39 AM   #1857
Trader Rating: 33 (100%+)
Do those three driver usually take the top 3 spots or was this a improvement for them?
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 12-19-2016, 07:47 AM   #1858
Dan
Dan's Avatar
Well, we used the previous winner and TQ as benchmark (2016 X1). He was 4th in qualifying this time. Still need more testing but worth noting. I would say take it as a grain of salt just because its only one race so far. We had all just built up our 17's last week.
Our track was setup with a 180 turn at the end of the straight. Real test of the swaybars will be on a long sweeper after the straight for no traction roll.
Old 12-19-2016, 10:40 AM   #1859
Cool, keep us updated please. If this helps the roll in the sweeper I might be implementing them onto mine.
Chris Lockhart
Old 12-19-2016, 10:51 AM   #1860
sbd
I was just wandering, what would make a swaybar more beneficial than progressive front springs....
sbd is offline   Reply With Quote
