Like Tree34Likes
Old 12-02-2016, 12:38 PM   #1801
Trader Rating: 33 (100%+)
Originally Posted by Useless RC info View Post
This might have been covered here but I can't seem to find an answer.
I have a 2015 X1 and the front camber isn't the same when I place the same spacers in both sides. I'm using a Hudy setup station to check the camber angles. I have checked all the bushings and related ball joints, measured the distances with calipers to the centerline of the car to the kingpin hole on each side but for some reason I just can't seem to find where the discrepancy is. I read on here that this chassis is subject to tweak so my next step was to take off the wheels and tighten it up on a setup board but, I have almost a full 1 degree of camber difference side to side before this. In order to get the camber the same, I needed to use the two dot on one side and the one dot on the other. That gave me a 2 degree setting finally.
Also, I have made sure all the spacers on the kingpin are identical with calipers.
Any suggestions at this point are welcome. It's just driving me nuts trying to find the issue.
I run the 15 as well and noticed it too. I found I could get it close by loosening the front end screws on the top deck and moving it around until it is close, then tighten the screws.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 12-02-2016, 12:45 PM   #1802
The Captain's Avatar
Originally Posted by chensleyrc1 View Post
I run TQ16 to the motor with a TQ sensor wire. I do 14 to the battery.
Same here.
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 12-03-2016, 11:55 AM   #1803
Ph3nyx's Avatar
Most of the time it appens when one of your aluminium mount is twisted or the carbon is damaged underneath , you should check it.
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 12-03-2016, 06:13 PM   #1804
xevias's Avatar
Originally Posted by Friulimotosport View Post
Do I need to get two sets?
No, only one is needed. The countersunk holes are drilled so it fits on the right side post. You keep the plastic battery retainers in front. I had to move my electronics slightly to allow the clip to "swing" in place.
xevias is offline   Reply With Quote
Old 12-04-2016, 04:48 PM   #1805
Customworksking's Avatar
Trader Rating: 73 (100%+)
come on x1 17
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-04-2016, 06:49 PM   #1806
Need help in getting rear end to stick better. Running on grey carpet on sweep tires. What ajustsments can I make ex. axle,side springs, centre shock oil and spring.
Friulimotosport is offline   Reply With Quote
Old 12-04-2016, 07:01 PM   #1807
mtveten's Avatar
Trader Rating: 27 (100%+)
Use better tires, the sweeps are garbage. The standard setup is shimuza 571/572 with the crc and tcs tires being interchangeable. Shimuza 574/575 tires also work well.
mtveten is offline   Reply With Quote
Old 12-04-2016, 07:10 PM   #1808
Tires came with the car. I'll pick up a set of shimuza before next outing.
Old 12-05-2016, 05:46 AM   #1809
I have been running a Fenix gear diff in my X1 and love it. 7 of the 30 cars in F1 at The Indoor Champs were using the diff. Something else to consider.
chuck
mackin is offline   Reply With Quote
Old 12-05-2016, 08:21 AM   #1810
tunerjetta29's Avatar
I ordered a X1 2017 but can't seem to find in the manual or easily online the maximum battery dimensions. Can anyone help me out?
Currently Running:
Serpent Project 4X , 17.5 Motor, Team Orion R10.1 ESC
X-Ray X1 2017, 25.5 Motor, Hobbywing X10 Pro ESC
X-Ray X1 2016, 25.5 Motor, Hobbwing X10 Stock ESC
Ko Propo EX-1 V3
tunerjetta29 is offline   Reply With Quote
Old 12-05-2016, 09:18 AM   #1811
IAmGreatDane's Avatar
https://teamxray.com/x1/2017/en/download/
Hope it helps :-)
Best Regards,
I Am GreatDane c'',)
IAmGreatDane is offline   Reply With Quote
Old 12-05-2016, 09:25 AM   #1812
Originally Posted by IAmGreatDane View Post
I looked through the manual already and parts lists and do not see maximum battery dimensions for the chassis anywhere. That's what I was looking for help with specifically.
Currently Running:
Ko Propo EX-1 V3
Old 12-05-2016, 09:51 AM   #1813
eR1c's Avatar
have you tried loosening the diff'? I found that when mine was too tight the rear had a tendency to want to swing out, especially if I accelerated a bit hard. I loosened my rear diff', much more than what the manual recommended and now it handles really well to the point where it is difficult to get it to spin out or lose traction.
eR1c is offline   Reply With Quote
Old 12-05-2016, 12:26 PM   #1814
JayL's Avatar
Shorty Pack
Never seen a SHORTY pack that wont fit
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 12-05-2016, 12:58 PM   #1815
Originally Posted by JayL View Post
Shorty Pack
I typically check the actual dimensions just to be on the safe side but if there is enough margin for any SHORTY pack to fit then I'll just order some. Thanks
Currently Running:
Ko Propo EX-1 V3
