Like Tree43Likes
Old 11-29-2016, 07:00 PM   #1786
xevias's Avatar
Originally Posted by Friulimotosport View Post
Looking for away to eliminate the tape and use a band. Is there anything that is available?
Mon-Tech has a clip that rotates/slides off of the shock support post. I like it.
http://www.the-border.com/Mon-Tech-L...1-015-011.html
xevias is offline   Reply With Quote
Old 11-30-2016, 07:27 AM   #1787
Early days but has anyone got a comparison/or some feed back about thr 17 spec? Particularly on asphalt..
Tamabuchi Corp is offline   Reply With Quote
Old 11-30-2016, 09:11 AM   #1788
Do I need to get two sets?
Friulimotosport is offline   Reply With Quote
Old 12-01-2016, 08:08 AM   #1789
Default 2016 Xray X-1 F1
Delete
Spektrum - Dynamite - Horizon Hobbies - MaxPower - RCAmerica - Alpha Raceway
skipstr is offline   Reply With Quote
Old 12-01-2016, 03:02 PM   #1790
What size of spur gear is everyone using?
Old 12-01-2016, 03:52 PM   #1791
shortcut's Avatar
Trader Rating: 49 (100%+)
I run an 88
shortcut is offline   Reply With Quote
Old 12-02-2016, 07:17 AM   #1792
88 also
thatrccarguy is offline   Reply With Quote
Old 12-02-2016, 07:23 AM   #1793
Thanks. I had figured the 96T was to big.
Old 12-02-2016, 07:53 AM   #1794
wkderf's Avatar
Trader Rating: 18 (100%+)
I ran a 92 spur with no issues.
XRAY MOTIV LRP ORCA SPEKTRUM HUDY
wkderf is offline   Reply With Quote
Old 12-02-2016, 09:51 AM   #1795
The Captain's Avatar
Mine came with a 96T in the box, so thats what I built (running for the first time tomorrow). Whats the issue with the 96T?
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 12-02-2016, 10:09 AM   #1796
Zerodefect's Avatar
Nothing. Just has the motor farther forward.
Small spur can move it back a hair. Try it either way and see what you like.
Zerodefect is offline   Reply With Quote
Old 12-02-2016, 10:12 AM   #1797
Trader Rating: 312 (100%+)
No issue. Just look at Jan set ups and size of the tracks.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 12-02-2016, 11:28 AM   #1798
In regards to motor wire 14G or 16G ?
Old 12-02-2016, 11:38 AM   #1799
This might have been covered here but I can't seem to find an answer.
I have a 2015 X1 and the front camber isn't the same when I place the same spacers in both sides. I'm using a Hudy setup station to check the camber angles. I have checked all the bushings and related ball joints, measured the distances with calipers to the centerline of the car to the kingpin hole on each side but for some reason I just can't seem to find where the discrepancy is. I read on here that this chassis is subject to tweak so my next step was to take off the wheels and tighten it up on a setup board but, I have almost a full 1 degree of camber difference side to side before this. In order to get the camber the same, I needed to use the two dot on one side and the one dot on the other. That gave me a 2 degree setting finally.
Also, I have made sure all the spacers on the kingpin are identical with calipers.
Any suggestions at this point are welcome. It's just driving me nuts trying to find the issue.
I'm as fast as that guy in a straight... just sucks when we have to turn!
Useless RC info is offline   Reply With Quote
Old 12-02-2016, 12:35 PM   #1800
Trader Rating: 33 (100%+)
I run TQ16 to the motor with a TQ sensor wire. I do 14 to the battery.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
