Like Tree34Likes
Old 10-18-2016, 03:53 AM   #1711
T3_PASSION's Avatar
Default ets front wing
can anyone tell me how to fit the ets approved front wing
xray t3,X1,XB4
LRP FLOW, X20, Savox, Nano Tech Batteries
protoform mazda speed 6
GO BRONCOS
TRCCC member
T3_PASSION is offline   Reply With Quote
Old 10-18-2016, 04:48 AM   #1712
It is a direct fit. remove the front wing (black plastic) and fit the new one. Yo might need to make new bodypost holes on the body if the body post is not fitted in the same position.
Best regards
Javier
jimjav is offline   Reply With Quote
Old 10-18-2016, 05:22 AM   #1713
shortcut's Avatar
Trader Rating: 49 (100%+)
Default Protoform front wing
Is anyone else running the new protoform front wing ? I tried it this weekend and it drags even though I have shimed it 1mm.
shortcut is offline   Reply With Quote
Old 10-18-2016, 07:09 AM   #1714
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
I got mines but haven't raced with it yet. I don't think its a good choice for carpet since it sits very low/flat and the side end droops downward. I'll probably save it for asphalt to test.
Dan is offline   Reply With Quote
Old 10-19-2016, 04:52 PM   #1715
Has someone a comparison between the side springs(X1 2015) and the side damper tubes(X1 2016)? Does it make sense to convert the "old" car?
dreckschleuder is offline   Reply With Quote
Old 10-19-2016, 06:35 PM   #1716
PACaSteel's Avatar
OK, I've lost stump the dummy.
Trying to set up an F1 for the first time and have a terminal push. I started with Jan's last set Snowbirds set up. I run on a technical track on black CRC carpet. To stop traction rolls, I've thickly glued the front tires and the rear outside walls; raised the side tubes 4mm, and went to harder front springs. I've tried 1 -1.5 camber; 6 - 9 camber; raised the side links 1mm; and tried every side spring I own. I've also worked with the center shock angles and diff tension from fully locked to so loose it slipped on any throttle. As the traction came up, the car pushed worse, and times slowed.
What am I missing?
PACaSteel is offline   Reply With Quote
Old 10-19-2016, 06:48 PM   #1717
Dan
Dan's Avatar
Are you running the wide Exotek wheels?
Old 10-20-2016, 04:16 AM   #1718
Trader Rating: 33 (100%+)
I still run the 15' and can place in the top 5 of every race I go to. The only changes I did to the 15 was get rid of the side dampener shock and replaced it with the Speed Passion's dampening tube.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 10-20-2016, 05:32 AM   #1719
What am I missing?
I believe on that carpet you are supposed to go with the softest springs and ride height below 3.5mm.
astgerma52sp is offline   Reply With Quote
Old 10-20-2016, 06:15 AM   #1720
ByteStream's Avatar
What am I missing?
Is it an on-power or off-power push?
What tires are you running?
What is your tire prep routine?
I run regularly at 5280 Raceway (Black carpet) and ran at this year's IIC (Black Carpet) and my setup is not that far away from the kit setup with a good amount of steering and no-sign of trying to traction roll.
Tire Prep - is huge in F1. The car can go from traction rolling to being extremely pushy just by what you do to the front tires. I normally start with glueing only the bead of the front tires (where the tread meets the sidewall) and saucing 1/2. Between runs I will clean the rear tires and not touch the fronts. Before it's time to run, I apply sauce to the rears and 1/2 the front (right over the dirty tire) and then wipe only that section off. If the car immediately rolls, then I apply more glue to the fronts. If it is slightly tippy - then less sauce, not enough steering - then more sauce.
You can definitely go to far with the glue and then end up struggling to get steering back into the car.
BTW .. Jan's Snowbird's setup is a little soft IMO on anything other than a very high grip open layout.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 10-20-2016, 05:13 PM   #1721
PACaSteel's Avatar
The tires I'm running are the Schumacher premounts from A-main which I believe are Pits 571 Fronts and 572 Rears.
As for the glue job. We built up the sides on a previous session where it traction rolled at less than half throttle and would knife edge on any power on corner. It is thicker than we need in WGT-R but about what many drivers had at last year's birds. One thing here is when we went from traction rolling to pushing, it was without adding any glue to the side walls. Not saying that it isn't the glue job, just that something else has to be going on too.
There are actually two problems at this point but I think I understand one of them. The car will push under brakes up to a point when it just hooks into the corner. I think adding some front droop will aid with the turn in. That will leave the wicked power on push coming out the corner. That is why I removed the droop out of the rear and angled the center shock.
The black carpet is last years blend, (I understand the IIC is a newer weave), laid over literally last year's Snowbirds subfloor. The push seemed to get worse late in the day when the traction came up. I'm kind of working on a theory that I need to loose rear traction rather than look for more front traction.
One other minor thing. I thought minimum height was 4mm.
I do appreciate your help
Old 10-20-2016, 05:20 PM   #1722
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
How tight is your diff? And are you runnin soft side spring?
micrors4guy is offline   Reply With Quote
Old 10-20-2016, 08:00 PM   #1723
PACaSteel's Avatar
I tried the diff from locked to slipping freely but it didn't solve the push. It did let the car rotate but soon as you eased on the gas out you'd go. Does let you be predictable but not so much for lap times.
It's the kit side springs.
Old 10-20-2016, 10:43 PM   #1724
PACaSteel's Avatar
Thanks to your questions, I did find one thing tonight. Apparently I abused the fronts so much the inside bead had let go. Not sure what this does to an F1 but on my TC it will sure make it squirrely. Reglue; Rebalance; Try it again.
Old 10-21-2016, 06:51 AM   #1725
ByteStream's Avatar
Correct .. they are the Pit 571/572 Combo on Tuning Haus Rims. Make sure to always check the glue job, it's not the best from the factory and will cause and ill handling car.
1. Make sure your brakes are not so strong that you are locking the wheels up.
2. Rear droop effects turn in and if you go too far (too much) then the car will hook into the corner while off power, so it sounds like you had too much rear droop. I run about 0.5-1mm of rear droop on the black carpet.
3. Removing front droop will help with on-power steering (add a 0.5 spacer to the very top of the kingpin). Also going to a stiffer center spring (2.4) will help with on-power steering.
It is normally 4mm at 99% of tracks .. Snowbirds is the exception which was 3mm.
